Old 09-09-2016, 05:30 PM   #1
Rich and Kat
AIRHEDS's Avatar
Virginia near , Washington, D.C.
Any reason to add an aftermarket brake controller ...
... to a new (2016 RAM 3500)? I saw the sticky Patrick posted about the 2013 Ram not being compatible with aftermarket controllers... But I was wondering if there was any reason to add an aftermarket controller if already equipped with an on-board controller in a late-model TV.
All the talk in a different thread about panic-hitting the trailer brakes to straighten out a fish got me to wondering if anyone has thought enough to add a "remote" brake on the steering wheel or otherwise...?
Rich
Rich
2017 Classic 30', ProPride 3P Hitch, 2016 RAM 3500 Laramie Crew Cab 4x4 SRW w/ 6.7L Cummins Turbo Diesel and Retrax Pro MX Tonneau Cover
KB2ZMF
Save
AIRHEDS is offline   Reply With Quote
Old 09-09-2016, 05:37 PM   #2
SMLJeep's Avatar
2017 27' Flying Cloud
Moneta , Virginia
I find that the on-board controller on my 2015 Ram 2500 works great. See no need to modify/add anything.
SMLJeep is offline   Reply With Quote
Old 09-09-2016, 05:46 PM   #3
Long Island , New York
Rich your OEM controller should have a manual control to enable engaging the trailer brakes in a sway situation, assuming one has the presence of mind to reach down, find the manual control (ours is L/R slide button), and apply it before instinctively hitting the tow vehicle brakes. I try to use the manual control briefly quite often just to train my body to know where it is automatically. This retraining process is difficult I find after decades of driving without a trailer most of the time.
A location on the steering wheel would be closer, but I have not seen any systems set up for this, and adding an aftermarket controller like this -- into the rolling computer that most modern tow vehicles are -- would be difficult IMO.
Good luck.
Peter
Old 09-09-2016, 05:52 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Why add another if your OEM one is working?
MICHAEL
Old 09-09-2016, 05:57 PM   #5
1991 25' Excella
Stanfield , Oregon
The location and function of the factory controller on the new rams trucks is better than any aftermarket controller. There is no reason to change it.
SpletKay06 is offline   Reply With Quote
Old 09-09-2016, 06:14 PM   #6
Rich and Kat
AIRHEDS's Avatar
Thanks guys. I just didn't know any better ... I just wondered if the aftermarket controllers added any value beyond my integrated controller, which has fully adjustable gain, as well as a slider to manually engage the TT's brakes. Don't need one! Thanks!
Rich
KB2ZMF
Save
Old 09-10-2016, 12:20 PM   #7
2002 31' Classic
Houston , Texas
Brake controllers and their proper usage.....
Rich
Rich:
The last four tow vehicles I had were all equipped with a full-fledged operational-with-a-slight-adjustment-setup factory controller, and all of them were (are) essentially the same operation.
The second comment has to do with what I sincerely hope was a shot in the dark by someone when they apparently spoke to the topic of "panic-hitting the trailer brakes to straighten out a fish ("tail", I assume?)". That it a mental/physical conundrum, if one considers the situation(s). Whenever there is a potential jack-knife, I'd be willing to bet that there are VERY few drivers who have the skill or training to do this maneuver in a "panic" situation and make use of trailer-only braking on the fly. If they were able to do that, I don't think they were in a panic. I have been in situations where I anticipated a possibility of some sort of braking problem and placed my right hand thumb and forefinger on the controls in order to prepare to squeeze deliberately for some trailer control but that's prior planning, NOT a "panic". In one memorable occasion that I spoke of in this forum, coming down Raton Pass, I got into a situation at about 40-45 MPH where oscillations started (bad wind gusts, about 4 or 5 of them). Trust me, I *KNEW* where the trailer brake control was, but I couldn't find it, being somewhat involved in the more important problem of steering to stay on the road. All I needed to do was to put just a little drag into the situation, and all would have been okay, and I couldn't find it. I lost both TV and trailer, totaled 'em both when they rolled. Actually, the TV rolled twice, but the AS just laid on its side and more or less deflated.
My first trailer/trailer brake controller setup was one in a case that was banded with hose clamps to the steering column, and had a stainless steel pressure tube that came off the brake reservoir on the engine side of the firewall and run to the controller case. Brake pedal pressure was taken into the controller where a hydraulic cylinder attached to a rheostat produced more or less voltage for the trailer brakes. There was a 6-8" rod that came out of the controller case that could be operated by pushing the rod with your right knee, and operate the trailer brakes independently of the brake pedal, while still pushing in the accelerator.
The factory stuff works better.
Kent
Houston
Kent M is offline   Reply With Quote
Old 09-10-2016, 02:07 PM   #8
Rich and Kat
AIRHEDS's Avatar
Originally Posted by Kent M View Post
Rich: ...
... The factory stuff works better.
Kent Houston
Kent, thanks so much for sharing your experience and comments. Sorry to hear about your previous TV/TT loss ... Hope you all came out of it unscathed. Good info to know. No wondering why manufacturers don't add remotes or a third pedal or something on the wheel to activate the brakes in a high stress situation... Anyway, thanks again for sharing. Take care, Rich
Rich
KB2ZMF
Save
Old 09-10-2016, 05:11 PM   #9
2020 Classic 33 on order
Box Elder , South Dakota
The reports on the 2013 RAMs was basically the controller did not work. Add an aftermarket. Easy enough to test the operation with your Classic.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 09-10-2016, 05:37 PM   #10
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Rich
...you can always buy better if you want to spend the money.
Try it, see if it works to your satisfaction.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel its supposed to be done"..
Amanamus
"Tahawus"
Old 09-10-2016, 09:50 PM   #11
Rich and Kat
AIRHEDS's Avatar
Originally Posted by ROBERT CROSS View Post
...you can always buy better if you want to spend the money. Try it, see if it works to your satisfaction. Bob
Thanks Bob. So, what's the difference then? My integrated trailer has user-set gain control from the computer ... I can adjust it on the fly, while the brake controller has the slider to adjust output to the TT brakes. What features constitute "better" and why "spend the money" to improve what I already have? Sorry in advance if these are elementary questions...
Rich
Rich
KB2ZMF
Save
WARNING!! New 2013 Ram Truck - Brake Controller, Aftermarket Colonial Airstream Tow Vehicles 31 02-25-2019 12:17 PM
Upgrading to Pex...Any reason I cant move WILDRTEXAS Sinks, Showers & Toilets 14 10-23-2009 05:37 PM
Any good reason for oversize tires? Dr.Theopolis Tires 6 06-08-2009 02:16 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
