Old 09-15-2016, 09:51 AM   #1
2017 19' Flying Cloud
Central , Texas
Anti-Sway Bar or WD with Anti-Sway for 19' FC?
We will soon be taking delivery of our very first travel trailer - a 19' FC. We have never towed a trailer of any type.
My tow vehicle is a 2015 5.7L V8 Toyota Tundra (with tow package). The owners manual suggests a WD hitch is not required unless the GVWR of the trailer is over 5000 lbs ( the GVWR for the 19' is 4500 lbs). I've talked with Toyota technical and they have reiterated that the WD hitch is not required, but suggest that the WD hitch "would not inhibit the towing situation." Some people indicate that a WD hitch on this light of a trailer will cause it to "porpoise" while traveling. Other people suggest to "never" use just the anti-sway bar. Others suggest that you use a WD hitch if the GVWR of the trailer is greater than 50% of the GVWR of the tow vehicle (in my case, the 19' would exceed 50% of my tow vehicle GVWR).
What experiences are out there for me to draw from? What are your suggestion/comments regarding the comments I've been given on the use of the Anti-sway and or WD/anti-sway hitches?
Thank you!
CanonFan is offline   Reply With Quote
Old 09-15-2016, 10:06 AM   #2
MsTara's Avatar
2017 16' Sport
Vernon , Arizona
Following as I am also interested in the details :-)
MsTara is offline   Reply With Quote
Old 09-15-2016, 10:31 AM   #3
1977 31' Sovereign
2005 30' Safari
1977 28' Argosy 28
North Port , Florida
As far as needing a WD hitch, I would suggest that you hook your trailer to your truck and see how it reacts. If it jacks the front end up, then yes you need weight distribution to correct that. Sway control is always nice in my opinion. Depending on the truck used, sometimes I use the WD, other times not. i.e the 1/2 ton requires WD, the 3/4 ton does not. My family and I have always used the Reese WD/sway control systems and they work flawlessly. Never tried anything else so I cannot comment on others.
cliffcharb is offline   Reply With Quote
Old 09-15-2016, 10:41 AM   #4
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
Never needed Sway Control with my Tundra & 23' Safari
I towed a 23 foot Safari with a 2006 Tundra and a 2012 Tundra. Towing with the larger 2012 Tundra... the 23 foot Safari was EXCELLENT. (just the cargo limit for the half ton suspension is the limiting factor)
The 23 foot was towed with an Equalizer Hitch that used the chains and bars with the smaller 4.7L Tundra and wheel base. The hitch had, as an accessory that the dealer installed, an anti sway bar that you could tighten or loosen depending on need.
I never 'needed' it. The smaller sized 2006 Tundra pulled the 23 foot Safari with ease. Even strong cross winds in Wyoming... no effect. Passing 18 wheelers you would notice a push and pull when they passed... but sway was never an issue.
The 2014 25 foot International pulled by the 2012 Tundra is currently using the Equalizer with sway bars and weight distribution bar system. Never an issue, although the need for the weight distribution, for sure. No sway at any speed. A win / win system in my opinion.
Although the chain system and bars worked excellent... some push expensive hitches as being your only option. Maybe for a 27 to 34 foot Airstream.
No one wants to purchase a hitch and find out that it was not adequate. So you live with that thought and go for the more expensive hitch as many say 'your trailer will sway to the point of rolling it over as a total loss'.
Following some threads is like a member discussing Nursing Homes and which one treats you best and the rest will rob you and toss you out onto the street. Take all advice seriously, but my experience has been the Tundra does well with my Equalizer hitches.
I am led to believe that a tow vehicle that has a short wheel base is more likely to REQUIRE sway control. As you get into the 'boat class' of pickup trucks... the need is less, if at all. My F350 has enough iron built into the vehicle to handle most any trailer. The Tundra... absolutely a wonderful tow vehicle... just a bit light in the cargo load. Towing with a Tundra... does fine, no sway and braking is excellent. Plenty of power to pull up a mountain without overheating the engine... ever.
Towing with a 3/4 to 1 ton pickup... just do not fall a sleep... as it rides that well!
Cliffcharb had great advice. Try it, you may like it. Start slow and work up to highway speeds to verify that everything feels... right.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 09-15-2016, 11:57 AM   #5
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
Get both...but if for some reason you only buy one get the WD hitch..definitely. jon
B00merang is offline   Reply With Quote
Old 09-15-2016, 12:03 PM   #6
B00merang's Avatar
Hailey , Idaho
...but suggest that the WD hitch "would not inhibit the towing situation." I love that line. When you read this forum it becomes clear that there are two lines of thought: Dem that try to squeeze in weights right up to the limit, and dem that are more prudent. A WD hitch, as your salesman so elegantly put it, cannot hurt and will always help make your ride go smoother...and make your travels safer. The anti-sway bar for your (as well as my) size AS is only icing on the cake. jon
Old 09-15-2016, 12:06 PM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I think I would get the sway control only because it is a single axle trailer.
I don't think you need weight distribution at all, but you can't really know until you set the trailer on the ball.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-15-2016, 12:06 PM   #8
Madison , Wisconsin
Send a message via AIM to jtwind Send a message via MSN to jtwind Send a message via Yahoo to jtwind
I've a new 19' and tow with a Blue ox WD hitch. Tows wonderfully! Used a Reese on my 16' sport and never a issue. I beleive WD payssoff in comfort, handling and wear and tear not to mention peace of mind. Just takes on emergency lane change and you're a believer !
jtwind is offline   Reply With Quote
Old 09-15-2016, 12:41 PM   #9
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
We just towed a 19 ft vintage single axel 1500 miles home on the ball only.
We usually have Reese Weight Distribution and Sway Control on our other trailers.
We are definitely putting them on this new trailer. It wasn't a experiment just a means of getting home. If was not bad but you could certainly tell we were without some of our regular safety equipment.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 09-15-2016, 12:43 PM   #10
Neophyte's Avatar
1967 24' Tradewind
Aurora , Colorado
For the extra $50 that the anti-sway brake costs, it's an insignificant cost for the one time you may need it.
Neophyte is offline   Reply With Quote
Old 09-15-2016, 12:45 PM   #11
2008 20' Safari SE
Ranchos de Taos , New Mexico
I thought weight-distributing hitches were part of a "tow package" on a pickup truck. My 2001 GMC HD ton has one. We tow a 20' Safari SE with it. That much truck is rather a bit overkill, but it was purchased primarily to tow a horse trailer. (No sway control but no sway.)
SafariSarah is offline   Reply With Quote
Old 09-15-2016, 01:09 PM   #12
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We towed our 19' Bambi with a 2007 Toyota Tacoma from the beginning, and have JUST replaced it with a new 2016 Tacoma. We use an Equal-I-Zer Hitch sway control/weight distribution hitch. It's a great all-in-one hitch set up for this size of trailer (and larger). It's very easy to use and keeps us safe on the road. Your Tundra will be plenty of truck for the Bambi and you could probably get by without sway control, but why take that chance? I'd get it. We have never regretted having this set-up...
TB & Greg and Abbey Schnauzer
#3954
Old 09-15-2016, 01:18 PM   #13
1979 23' Safari
Wayland , New York
Been towing an 18' trailer with a f150 (little bigger truck) a lot since May. About 500lb tongue weight.I Wouldn't be comfortable without my blue Ox sway pro. I slacked the bars once to see how it handled without it, lots of porpoising and a bit squirrelly. Trailer movement was much more noticeable. With the hitch set, tows much more smoothly and better control of tv and trailer.
Old 09-15-2016, 01:22 PM   #14
dalecamp`'s Avatar
Pearland , Texas
Bare minimum, please use some sway control, you never know when you will need it. WD hitch is your choice for the trailer and tow vehicle you are talking about. You can get a receiver hitch with ball and ball for sway control, I would always use it, no matter what someone else says, IMO.
Be safe at all costs.
dalecamp` is offline   Reply With Quote
Friction Anti Sway Bar Supports Slip dbj216 Hitches, Couplers & Balls 27 09-27-2016 07:56 PM
Anti-Sway Towing Bar svanpelt Airstream Classifieds 0 05-02-2015 07:39 PM
Huskey Anti-Sway Bar Goal15 Hitches, Couplers & Balls 14 05-28-2011 08:23 PM
Reese friction anti-sway bar broke Phantom Hitches, Couplers & Balls 18 11-28-2009 11:02 AM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 07:11 AM
