Old 09-19-2016, 10:55 AM   #29
2017 19' Flying Cloud
Central , Texas
Thanks for all the comments and suggestions. My first impression was to just get the WD hitch with integrated sway control. But someone told me this would actually be detrimental to the light trailer and cause it to "porpoise" while driving down the highway. No one has commented on this so I assume no one reading this thread has had this experience(?).
CanonFan is offline   Reply With Quote
Old 09-19-2016, 02:27 PM   #30
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Not sure it would be detrimental or cause porpoising if you got the correct weight bars that correspond to your trailers tongue weight- 400# bars, 600# bars, 800# bars, 1,000# bars, 1,200# bars, or 1,400# bars...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-20-2016, 05:24 AM   #31
1979 23' Safari
Wayland , New York
If anything it will reduce the porpoising. The way it's putting torque between the truck and trailer is in a direction counter to porpoising. For such a small trailer get some light bars, that way they will have a good amount of spring, and be able to flex well.
Old 09-20-2016, 05:27 AM   #32
floridalarry's Avatar
1966 20' Globetrotter
Ormond Beach , Florida
After having a Reese, Andersen and Blue Ox, I prefer the Blue Ox. Just remember that you need at least 1" bend in the weigh transfer bars. Do not use 1,000 # bars on an AS with 750 # tongue weight. You will not get the proper bend. There is a forum dedicated to Blue Ox. You may want to check it out.
I had a terrible experience with the Andersen. Due to so much forward pressure required, it deformed by locking lever requiring a new coupler.
Larry & Linda Scovotto
WBAC #1021
Ormond Beach, FL
1966 20' Globe Trotter
2015 Nissan Frontier SL
floridalarry is offline   Reply With Quote
Old 09-20-2016, 05:29 AM   #33
1973 31' Excella 500
Calgary , Alberta
This is one of the reasons I went with the Andersen No Sway.
It is completely adjustable. It does not have incremental steps like bars do. Also the sway is dependent on how much tongue weight you have.
DaK
DaKs is offline   Reply With Quote
Friction Anti Sway Bar Supports Slip dbj216 Hitches, Couplers & Balls 27 09-27-2016 06:56 PM
Anti-Sway Towing Bar svanpelt Airstream Classifieds 0 05-02-2015 06:39 PM
Huskey Anti-Sway Bar Goal15 Hitches, Couplers & Balls 14 05-28-2011 07:23 PM
Reese friction anti-sway bar broke Phantom Hitches, Couplers & Balls 18 11-28-2009 10:02 AM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
