11-22-2015, 08:18 AM
2016 25' Flying Cloud
Jupiter
Another rookie towing question
First, hello all. We have been reading the forums for a bit as we research and get ready to buy our first Airstream. We know the one we want, but we just want to get some thoughts on if we would be pushing the capacity of our tow vehicle too far.
Tow Vehicle: Chevy Colorado with trailering package. Rated at 7000# towing capacity, 1547# cargo capacity, and 5800# GVWR. We already have this truck, and aren't wanting to make a vehicle change right now.
We would be traveling mostly east of the Rockies (we live in FL), but would also love to be able to go west as part of a National Park tour.
The model we are wanting is the 25FB, which has a base weight of 5503#, and a GVWR of 7300#. We would be planning on traveling fairly light, meaning not carrying a lot of water weight, and would likely keep the trailer <= 6500#. We would plan on getting a WD hitch.
Are we dreaming, or is it feasible to tow the 25FB with this setup?
11-22-2015, 08:33 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Greetings from the Florida Panhandle
First off, welcome to the Forums. We're glad to have you with us.
As to your question, an Airstream 25FB may overwhelm your Colorado. We have had two 25FB's (2005 and 2015) over the past ten years. We have towed our Airstreams primarily with 3/4 ton Suburbans which have done a very good job. We have also towed with a half ton Tahoe which we considered marginal. Many members here tow 25FB's with 1/2 ton trucks and find them satisfactory.
As to small trucks like the Colorado, you are likely to find this towing combination unsatisfactory.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
11-22-2015, 08:37 AM
2012 25' FB International
Trent Woods
, North Carolina
Agree, I tow with a 1/2 ton just fine but I think you would be too close to the limits of the Colorado.
Larry
11-22-2015, 08:47 AM
Jupiter
Larry
My understanding of a 1/2 ton truck is one that is capable of around three-quarters of a ton payload. 3/4 of a ton is 1500#. My truck (it's not the older pre-2015 one) is capable of 1547# payload.
Does that change anything?
11-22-2015, 08:49 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
The 25FB has an Airstream literature tongue weight of 833 pounds. By the time the Hensley hitch was installed along with street side and rear awnings, a 155 watt solar panel and full propane tanks, our basically new empty 25FB International Serenity trailer had a tongue weight of 1,150, pounds. Your planned tow vehicle would have less than 400 pounds of load capacity left for the driver and passenger let alone any "stuff" in the struck bed.
The literature empty weight most likely not agree with the legally required white weigh sticker that will be attached to the front of the street side of the trailer that is generated on the factory scales as the trailer comes off the line. That weigh process also generates a net payload number that is printed on a yellow label attached to the screen door.
We crossed the scales with the 25FB trailer loaded for camping and the trailer weighed 6,860 pounds out of the 7,300 pound GVW and the tongue weight had increased to 1,175 pounds. Our 2007 Mercedes ML320 CDI diesel was suddenly overloaded on the axles and GVW with the camping ready trailer which caused the acquisition of our Ram 2500HD diesel.
A more appropriate load and size for the smaller tow vehicle could be the 23' models with tandem axles or the shorter single axle trailers.
We also tow a 2015 23D International Serenity with the Mercedes mentioned above and the numbers work.
11-22-2015, 09:31 AM
Venice
I agree with most of the above comments especially Moosetags saying your set up would de marginal. I use a RAM 1500 to pull my 25ft AS. My payload is low as that particular truck with the ecodiesel engine does not have the carrying capacity of one with the Hemi engine, I mention this as all half ton trucks don't have the same capabilities but are adequate to tow a 25 ft Airstream. People use lesser vehicles like smaller trucks or SUVs believing they are "rigged up' properly & good to go, I would call that a false since of security especially on the interstate with 18 wheelers buzzing you on both sides because thats when could find yourself in jeopardy. The Airstream 23ft would probably be a better fit for that Chevy Colorado. Good luck & happy camping.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
11-22-2015, 09:37 AM
Spokane
I tow my 25FB with a half ton Tundra whose numbers are similar to yours. The towing capacity of the Tundra is closer to 10K though and I think that this is because of the power plant.
People on the forum are quick to criticize the Tundra for anything 25 or over. With the Colorado you will be at your limits for sure and keeping things as light as you can is a good idea. You will need a good weight distributing hitch with built in sway. The tongue weight on the 25FB is grossly understated. Mine has two batteries, two propane tanks and a spare tire up front.
If you are not in a place to upgrade your tow vehicle I would suggest you get it set up properly and use it. If you are going to be doing most of your traveling on flat ground you will quickly get a feel for the situation. The hitch will be important but you don't have to go with the most expensive out there. There many here that use others with great success. There are many to chose from.
Best wishes in your pursuit of an Airstream. We really enjoy our 25FB.
11-22-2015, 09:43 AM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
Simply based on the numbers you provided you are not legal to tow a 25' with the truck you now have. Not saying you'd go to jail etc, but if in an accident or stopped by some local who knows what he is doing the only thing that counts are the sticker on the drivers side of the Airstream with the stats and the door sticker on the drivers side frame of your tow vehicle.
Like has been said, legality aside, I believe your intended combination is marginal at best. It not so much towing that's an issue, it's stopping and sway that would concern me. In towing for over 45 years I've always error ed on the heavy side for tow vehicles when selecting one.
Like another poster said, you might want to consider a smaller Airstream for now or go to a larger tow vehicle. A 1/2 ton with tow package can very nicely tow a 25' AS.
Bud
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
11-22-2015, 10:07 AM
I'm In
, Kentucky
Hello and welcome to the forum.
We have a 23' we tow with our 4Runner. The towing capacity is the same as yours, 7,000. Over flat ground and rolling hills it tows quite well and handles (start, stop, curves, crosswinds, semi traffic) nicely over all terrain.
This past summer we went into the Appalachian Mountains and some of those hills dropped the speed on our 4.7L V8 to the low 50s. If you're thinking about crossing the Rockies or any other mountain ranges I'd advise you stick with 23' or less. Don't forget, rolling is only one handling characteristic, you need to worry about emergency stopping, curves, crosswinds, traffic etc.. We would have liked to have had the 25' but after towing the 23' for a couple of years I'm happy we have her. Eventually we'll move up to 25' but we'll upgrade the tow vehicle. Safety first!
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
11-22-2015, 10:09 AM
Len and Jeanne
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley
, British Columbia
We faced a similar question. We towed our 16' 3500 lb. Bambi with a Tacoma. Since the Tacoma was our only vehicle, we wanted a smaller multi-purpose truck. When we replaced the first Bambi with a 19' 4500 lb. Bambi, the Tacoma was marginal; especially because we do mostly mountain driving. Replacing the Tacoma with a Tundra was a really smart move (despite the expense) because it tows like a breeze, even up major passes.
Also, for western desert driving, driving with a full fresh water tank is a really good idea. Many of the coolest national park and BLM campgrounds are dry sites.
11-22-2015, 10:13 AM
Santa Rosa Beach
I know that some have recommended going to a smaller Airstream that can be more easily handled by your tow vehicle. Being a long time avid Airstreamer (ten years/1700 nights camping/140,000 miles towing), I would highly encourage you not to purchase an Airstream simply to accommodate a tow vehicle. This is almost always a mistake.
Remember that the right Airstreams lasts a very long time; tow vehicles, not so much. An Airstream that isn't right for your wants and needs will most likely end up as a very expensive piece of yard art. You will find reasons not to use it.
I would suggest that you get the Airstream of your dreams. Try out your Colorado as a tow vehicle. If it is unsatisfactory, replace it.
Brian
11-22-2015, 10:41 AM
Yertle01.com
2006 22' International CCD
Estes Park
My guess is you won't be happy with that setup. I tow a 22' International with a 2014 Ford half-ton 5.0L. It struggles on the mountain inclines and screams on some declines. I'm not happy in those situations and will go to a larger tow vehicle when I can afford it. If I were towing a 25', I would already have traded up in spite of the expense. And, like others have said here, it's the unusual emergency type situations that can get hairy/scary. It's not worth the risk to yourself and others.
Terry P. Rizzuti, "Yertle"
TRizzuti.com
Yertle01.com
"My two cents is worth every penny."
11-22-2015, 10:57 AM
2000 25' Excella
fallbrook
I tow my 2000 Excella 25 with a Chev Tahoe (2011) . Started with a 2000 and have had 5 over the 15 years. Longest trip was from Socal to Long Island NY and back. Never had a problem!! Patience and driving 55 to 60 on the open highway is the answer for me. Towing package is especially good on my current 2011, built in controlled, connection indicator etc. Good luck and drive safely. BG
11-22-2015, 11:49 AM
2007 25' International CCD FB
The Woodlands
Better to ask the question than find out the hard way. Welcome to the forums!
What does the yellow door sticker on the drivers side frame of your tow vehicle say? I would be very surprised if it does say 1547#. Manufacturers are all guilty of overstating payload in their advertising claims. Don't forget - the number on the yellow sticker is without passengers.
Your truck may tow fine on a flat surface, but may be overwhelmed with the weight of the 25FB when traveling in the mountains or making emergency stops. My 25FB has a tongue weight of 1050# when loaded. Your truck may pull the trailer fine on a flat surface, but please consider the braking capability coming down I-70 if you do head west. Good luck.
11-22-2015, 01:18 PM
Jupiter
"What does the yellow door sticker on the drivers side frame of your tow vehicle say? I would be very surprised if it does say 1547#."
It states 1547#. That is where I got that figure.
11-22-2015, 02:04 PM
Jupiter
Thank you everyone for you insight. Very much appreciated. So here are my current thoughts:
I agree that getting an Airstream that doesn't match our preferences would be a mistake. We had looked very closely at the 23FB first, but after comparing that floorplan with the 25FB Twin, we just think that would work much better for us - extra seating, the ability to more easily seat 4 at the dinette if we have company, the ability to stand in the middle of the bedroom for dressing, panoramic windows at both ends, and the separate bathroom and shower to name a few. We are trying to avoid the "we really should have gotten something a little bigger" syndrome.
I really like the Colorado, and it also works great as a separate vehicle when not towing. We don't plan to be full timers. Plus, we aren't in a position to also replace that right now.
With 1547# payload capacity, minus the weight of 2 passengers, our dog, the WD hitch, and some misc. extras, we'd have ~1060# for the tongue weight. We plan on staying in fairly flat areas around FL and the southeast as we get used to Airstreaming, until we retire in a couple of years. We would mostly be staying where we have shore power, so we'd even be fine with only 1 of the LP tanks. I could just take one out and store it until later. We'd just proactively fill up the one tank as needed.
We would travel light, only bringing what we need. Some of the perishable things we can just purchase when we get to where were going, use them, and never really need to tow them.
After we retire, we can consider swapping out the tow vehicle for something that would allow us to handle the mountains. By then we would have much more experience and be better prepared for a longer journey.
Seem logical?
11-22-2015, 02:41 PM
Trent Woods
, North Carolina
I have to wonder why you bothered to post if your mind was already made up. Most posters told you not to do it but you will do it anyhow. There was a wreck up in Maine when we were there this fall, a TV that was underrated for the TT. I hope you do not become one of those statistics. Oh, I do think your choice of a 25 is a good choice.
Larry
11-22-2015, 02:57 PM
St. Catharines
, South Western Ontario
Seem logical?
So much has to do with the connection and set up. Getting it right, hardware choice and adjustments will make all the difference. You should spend some time researching that part of the equation to be sure you get an optimal connection.
PS... Our payload rating for our car is under 1,000lbs and we are within spec towing our 23.
11-22-2015, 02:58 PM
2014 31' Classic
Apache Junction
It is not getting the rig moving that is as important as getting it stopped, especially in an emergency.
In the heavy Florida rains, it would be easy to hydroplane at an inconvenient time and if the 25FB loaded weighs more than your truck, a jack knife could happen in a heart beat.
You need to actually get inside a 25FB and experience the bed arrangement. Lie on the front edge of the bed and sit up. The non-existent walk space around the front edge of the bed was an issue for us, plus hitting my head if I sat up in bed. Many folks like this setup and some get the 25FB Flying Cloud trim line with twin beds that are in line with the frame. See both models.
11-22-2015, 07:14 PM
1984 34' International
Toronto
, Ontario
That is 100% incorrect. While there might be many a practical reason not to tow with your truck, legal worries aren't one of them.
