Old 05-30-2016, 11:14 AM   #15
HowieE's Avatar
Princeton , New Jersey
Images: 12
Spletkay06
You did not mention your TV. I say this because if you are towing with a a very lightly sprung rear axle vehicle you may not be able to transfer enough weight to the front axle to return to the original steering geometry. The Andersen is clearly designed with sway as the principle consideration as most TV have changed from sedans to trucks.
As for the stated limitation of a few commentators that the Andersen is limited to light trailer I have been towing my 34 fter for 4 years now and have converted my daughters 8,000 lb trailer to an Andersen because of excessive sway she was having while towing with a Reese Straight Line system.
What is your TV?
2004 Excursion 4x4
Old 05-30-2016, 12:22 PM   #16
1991 25' Excella
Stanfield , Oregon
I have a 2015 ram 1500 ecodiesel with full air ride. Im currently not using a wd hitch at all and it tows great front axle is 3400 but rear is axle 4400 so im a little overloaded. My trailer came with a resse wd hitch and it terrible makes the trailer ride horrible. When I first bought it and towed it home 280 miles nothing moved in the trailer and it towed great but then I setup up the wd hitch and everything moves around, it turns poorly etc. All im looking for is to lower the tongue weight a little and some sway control wouldmt hurt.
SpletKay06 is offline   Reply With Quote
Old 05-30-2016, 12:37 PM   #17
HowieE's Avatar
Images: 12
60 lbs is about as low as you can go.
2004 Excursion 4x4
Old 05-30-2016, 12:51 PM   #18
1991 25' Excella
Stanfield , Oregon
60 lbs less tongue weight? Thats not much
Old 05-30-2016, 12:52 PM   #19
N/A , N/A
The extreme issues one user has had seems to be setup related. Otherwise, how come andersen works fine for a heavier, longer 34?
Did you contact Andersen regarding the issues you were having? What did they say/advise?
rostam is offline   Reply With Quote
Old 05-30-2016, 01:28 PM   #20
HowieE's Avatar
Images: 12
Unfortunately early on in the discussion of the Andersen system there was a concerted effort to discredit the system by some that feared the new competition. Even knowing the design intentions of the newer system, sway control over weight distribution, several tried to achieve the historically now unnecessary results of the older systems with the intent of discrediting the Andersen system. However there are very few modern TV that require the WD that older softly sprung cars required. Just do a count of those using the Andersen against those claiming it can't work and then make up your mind.
And yes there is an issue with some of the Atwood couplers failing when using the Andersen. That is not a problem with the Andersen but a design limitation of the Atwood. A type of problem often encountered when a new concept is invented.
Many had to decide what to do with their single cylinder gas engine washing machines when the electric motor came on line. The problem was not in the electric motor.
2004 Excursion 4x4
Old 05-30-2016, 06:00 PM   #21
Vintage Kin
Fort Worth , Texas
Hogwash.
Old 05-30-2016, 11:03 PM   #22
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, how can you blame Atwood when the Andersen hitch is the only one causing this problem????????? Clearly an Andersen problem.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-31-2016, 07:23 AM   #23
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
If your happy with what you're using......it's adequate.
If others are unhappy with what you're using......it's not.
RLC
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel its supposed to be done"..
Amanamus
"Tahawus"
Old 05-31-2016, 08:04 AM   #24
HowieE's Avatar
Images: 12
If one cares to read the above statement I do not say there is a problem with the Atwood coupler I say there is a limitation. If one accepts the dynamics at the interaction of the ball and coupler the limitation would be clear.
In all bar type hitches the coupler rests on the ball. The forces associated with the WD aspects of the hitch are transferred directly to the head of the hitch, forward of the ball, and then to the TV. With the Andersen hitch, while the coupler does rest on the ball, the forces relating to the WD aspects are transferred through the ball shaft with loads on the top and bottom of the ball shaft. It is this significant design difference that results in the failures of the Atwood coupler. It was not designed for that type of load. Not is not a problem, as there was no need to consider such loads when the Atwood was designed, that is a limitation resulting from the newer design.
Think of the limitations we would be under if we insisted that all creative designs comply with all old technology. The phone company worked under such constraints all the way from the hand cranked wall phone up to the 500 type desk set. Then someone invented the cell phone and cut the wire.
That is not "hogwash" that is progress and some adjustment may be required. Or do you really want to drag a wire around behind your cell phone?
The original question asked if anyone had experience with the Andersen. I have. I think my experience may even go a bit further than most using this hitch. I did encounter several questionable aspects but rather than sit back and claim the system could not work I made changes to my Andersen and forwarded those idea to the company. They incorporated the changes. And when my Atwood failed I found a solution and applied it and posted that solution for those who might be interested.
Why not my only other course would have been to return to a system I knew was not as good as the one I was using.
2004 Excursion 4x4
Old 05-31-2016, 10:46 PM   #25
Salem , Oregon
Images: 18
Hi, No; You didn't say there was a problem with the Atwood coupler, you said there was an issue. And now you changed your wording to Limitation. I see that as the same thing and now you are backing out with a play on words. Next you will you use the infamous excuse that we took your words out of context!
I don't know about you, but my cell phone is connected to a cable every night; Your's must be solar powered. And when traveling, I do drag a cable around, called a charger.
2005 Safari 25-B
Old 06-01-2016, 08:12 AM   #26
HowieE's Avatar
Images: 12
I will stand by my original statement and trust that those who read it, without prejudice, will understand my comment.
2004 Excursion 4x4
Old 06-01-2016, 08:51 AM   #27
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I'm dusting off the boxing gloves. End Round 1
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 06-01-2016, 11:56 AM   #28
Anderson WD Hitch
HowieE - I recently went from a Reese Dual Cam to the Andersen for our 19' Bambi, now towing with a new diesel Canyon.
When researching a new wd system, I talked with a fellow at Andersen to inquire about their note about certain Atwood couplers. He said there is not a problem if a close tolerance pin is used on the lock-down lever, so did that. We just returned from our first long distance tow, and am very happy with the hitch's performance.
Curious what you suggest, if I should consider any other changes to improve the ball to coupler connection? I don't want to spend a day searching your posts to find the one you refer to above.
Thanks.
kd7trx is offline   Reply With Quote
Anderson Hitch and Atwood Coupler Siegmann Hitches, Couplers & Balls 11 11-27-2016 11:28 AM
Used Anderson WD Hitch Secguru Airstream Classifieds 0 10-02-2014 09:58 AM
Anderson hitch coupler issue...... catsmith Towing, Tow Vehicles & Hitches 7 09-26-2014 08:01 AM
