Old 04-25-2016, 06:04 PM   #1
interstateflyer's Avatar
2017 25' International
Los Osos , California
Andersen Levelers-Anyone tried them.
I saw an an for a leveling system made by the Andersen Hitch company. Has anyone tried the Andersen 3604 Camper Levelers?http://www.amazon.com/Andersen-Mfg-3...erson+levelers.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 04-25-2016, 06:12 PM   #2
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Yes. They work great for me.
SeaLevel is offline   Reply With Quote
Old 04-25-2016, 06:36 PM   #3
Anyone try them with a 23D? I'm wondering if the wheel spacing is enough to allow placement.
Old 04-25-2016, 07:00 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Thee are several threads on thus subject in this section.
I have been using them for a couple of years. With my 23 I had to cut off a couple of inches on one of the Levelers to stop it from jamming up when rolling off.
MICHAEL
Old 04-25-2016, 07:12 PM   #5
2016 30' Classic
I have them, but have only used once. Honestly, the stackable blocks work great for me. The fit is a little tight and I should cut an inch or two off one of them. Very solid though.
caseywsj is offline   Reply With Quote
Old 04-25-2016, 07:14 PM   #6
Thanks. Glad to hear they worked with modification on your 23D.
BTW.....I searched but couldn't find a thread on the subject. I've been on AirForums since 2006 and still have issues with the search function.
Old 04-25-2016, 11:46 PM   #7
CRH
1995 25' Excella
xxxxx , xxxxxx
I love mine.
CRH is online now   Reply With Quote
Old 04-26-2016, 10:59 AM   #8
2016 26' Flying Cloud
Baltimore , Maryland
Yes, we have them for our 26' and they work fine.
mkr1950 is offline   Reply With Quote
Old 04-26-2016, 11:07 AM   #9
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Those look like they might work.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 04-26-2016, 11:40 AM   #10
abqdor's Avatar
Albuquerque , New Mexico
I have a '25 with 16" rims and Michelin tires. They did not need trimming to fit under both tires. The first time we used them was on gravel and they tended to slide on the gravel. I found some diamond plate rubber tread grippers at Harbor Freight that were cheap and perfect for adding some grip. They are self adhesive and almost the exact size of the Andersen Leveler. I had to trim about 3 inches off of the grippers, but they really help with the slipperiness of the leveler.
'17 Ford F-150 Ecoboost, max tow package
'13 GMC Yukon Denali 6.2L V8
'04 GMC Yukon SLT 5.3L V8
abqdor is offline   Reply With Quote
Old 04-26-2016, 11:47 AM   #11
2008 27' Classic FB
Ontario , Oregon
Anderson Levelers
I used them last season with great success after cutting off an inch of the length. That solved the wedging issues. They are super easy to use, no more guess work on how many blocks to add to the stack.
Shiloh4570 is offline   Reply With Quote
Old 04-26-2016, 11:55 AM   #12
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
They work great, you can get exact height adjustment since it is a ramp. The tips are marked to cut if shorter is needed. They also can be used on one wheel to elevate the adjacent wheel off the ground if you have a flat. The first time I used them I forgot to remove the one between the wheels and it conveniently broke the end off right at the line, so it now fits perfectly!
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 04-26-2016, 12:16 PM   #13
lindaebrewer's Avatar
2015 23' FB Flying Cloud
Sacramento , California
To: AWCHIEF, "I have been using them for a couple of years. With my 23 I had to cut off a couple of inches on one of the Levelers to stop it from jamming up when rolling off."
Which leveler? The one between the wheels?
lindaebrewer is offline   Reply With Quote
Old 04-26-2016, 12:35 PM   #14
DeltaRon's Avatar
2015 28' Flying Cloud
Cumming , Georgia
Anderson levelers
Just one warning. Stupidly, I leveled but forgot to CHOCK. Bad idea as I unhitched and trailer rolled back bending my weight distribution bar as the tongue jack fell off the wood holding it up.
DeltaRon is offline   Reply With Quote
Using Andersen Levelers Gmutt Jacks, Stabilizers, Lifting and Leveling 42 01-05-2017 08:35 AM
Andersen Camper Leveler-anyone tried it? Djimmy Jacks, Stabilizers, Lifting and Leveling 42 05-08-2016 02:23 PM
Andersen levelers and a 25' gpt 2009-2015 Flying Cloud 22 06-12-2015 10:23 AM
OceanAir Cassette Blinds - Tried Them? mstephens Upholstery, Blinds, Walls & Interior Finishes 11 10-24-2012 10:58 AM
SMEV Cooktops? Any one tried them? ronstory Stoves, Ovens & Microwaves 31 03-12-2010 02:33 PM
