Old 04-26-2016, 12:42 PM   #15
Stay CazuaL
cazual6's Avatar
2014 19' Flying Cloud
Reseda , California
I use this. I have the blocks, and blocks don't always get it just right.
This works great.
http://www.amazon.com/BAL-28050-Ligh...leveling+jacks
cazual6 is offline   Reply With Quote
Old 04-26-2016, 02:05 PM   #16
Airstream Fan
rheiniger's Avatar
PARKVILLE , Missouri
They work perfectly for our 30 International although a tight fit with the 16" Michelins.
rheiniger is offline   Reply With Quote
Old 04-26-2016, 02:52 PM   #17
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
Use them and swear by them more often than I swear at them. Two cautions I didn't see noted above (only one of which I learn the hard way... you can guess which): 1. Have someone watch so you don't back off of them... there is no stop to prevent it. 2. When lowering the trailer for departure with tandem axles, be sure to stop precisely, otherwise the leveler between the two tires becomes an obstacle that can get wedged between the tires.
GammaDog is offline   Reply With Quote
Old 04-26-2016, 04:00 PM   #18
merchantmm's Avatar
2015 27' Flying Cloud
Yorba Linda , California
Work so much better than the stackable units. Driving forward onto them is best. We use on 27 ft FC.
merchantmm is offline   Reply With Quote
Old 04-26-2016, 04:02 PM   #19
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Originally Posted by lindaebrewer View Post
To: AWCHIEF, "I have been using them for a couple of years. With my 23 I had to cut off a couple of inches on one of the Levelers to stop it from jamming up when rolling off."
Which leveler? The one between the wheels?
Yes, sorry left that out of the post.
MICHAEL
Old 04-26-2016, 04:06 PM   #20
AWCHIEF's Avatar
Images: 33
Originally Posted by DeltaRon View Post
Just one warning. Stupidly, I leveled but forgot to CHOCK. Bad idea as I unhitched and trailer rolled back bending my weight distribution bar as the tongue jack fell off the wood holding it up.
The Andersens come with chock pieces to keep that from happening. I try to remember to always use them.
MICHAEL
Old 04-26-2016, 04:24 PM   #21
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I love the idea of them, but they didn't work on my 25' with 16" wheels. There wasn't enough space between the wheels. However others have said it did work for them on a 25.
2012 Dodge Durango Hemi/AWD
Old 04-26-2016, 05:02 PM   #22
AWCHIEF's Avatar
Images: 33
See the above post on how to fix that. Cut a couple of inches off the one that goes between the wheels. A modification approved by Andersen.
MICHAEL
Old 04-26-2016, 10:47 PM   #23
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
Mine work great with a 27FB and 15's. I'd have to cut one short if I moved to 16's. I found that they can slide on some surfaces when setting up but stay put when set. I set the parking brake about half in the truck when setting up and move til level. That way it's doesn't move when you go set the chocks. Takes a bit of throttle to move but the 7.3 don't care! Be sure to chock andersons and let trailer settle before placing regular chocks on opposite wheels to avoid pinching one of the regular chocks.
SuperTrouper is offline   Reply With Quote
Old 04-26-2016, 11:01 PM   #24
2015 27' FB International
Gig Harbor , Washington
A concern : when using the full 4" rise, half of the tire is hanging off the leveler. This seems to place a lot of pressure/crease across the tire tread. I'm not comfortable with this stress on the tires. Convenient design, but...
AluminumTube is offline   Reply With Quote
Old 04-27-2016, 06:20 AM   #25
AWCHIEF's Avatar
Images: 33
Never hard of that being an issue while camping, but I suppose It could be a problem if used for long term storage. Maybe one of the authentic tire pros can give their opinion.
MICHAEL
Old 04-27-2016, 07:48 AM   #26
Wayne&Sam's Avatar
Images: 21
I thought about trying that but I was an early adopter and decided to return them instead.
Old 04-27-2016, 08:11 AM   #27
HowieE's Avatar
Princeton , New Jersey
Images: 12
I have long had a 3 ft. wooden ramp slung under the trailer. Yesterday I had to get a tire off and decided to use it and one of the Andersens I had bought for my daughter's trailer. Rolling back on the ramp with 2 tires, a tri axle, and then forward onto the Andersen that lifted the center tire off the ground and made removing the tire a snap compared to using a jack.
An Andersen is now on board.
2004 Excursion 4x4
HowieE is online now   Reply With Quote
Old 04-27-2016, 09:20 AM   #28
Storm Master
Ampman's Avatar
2005 25' Classic
Been using them on a couple of trips now. Works great on 16 inch duals. Wish I would have bought em years ago instead of the cheap Lego blocks.
Ampman is offline   Reply With Quote
Using Andersen Levelers Gmutt Jacks, Stabilizers, Lifting and Leveling 42 01-05-2017 08:35 AM
Andersen Camper Leveler-anyone tried it? Djimmy Jacks, Stabilizers, Lifting and Leveling 42 05-08-2016 02:23 PM
Andersen levelers and a 25' gpt 2009-2015 Flying Cloud 22 06-12-2015 10:23 AM
OceanAir Cassette Blinds - Tried Them? mstephens Upholstery, Blinds, Walls & Interior Finishes 11 10-24-2012 10:58 AM
SMEV Cooktops? Any one tried them? ronstory Stoves, Ovens & Microwaves 31 03-12-2010 02:33 PM
