Old 07-06-2013, 04:18 PM   #1
1975 31' Sovereign
Texarkana , Texas
Airstream will not go backwards
I purchased a 1975 Airstream Sovereign today. When I got it home I tried to back it into place but the wheel locked up. Is there something that I don't know concerning backing up the RV or is there something wrong with the axles?
Thanks in advance
dennis82468 is offline   Reply With Quote
Old 07-06-2013, 04:19 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Disconnect the trailer wiring. Best bet is that the seven way is misfired...a-la old style.
Old 07-06-2013, 04:57 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you have your foot on the brake in the TV. The brakes are being applied on the trailer. One or more of them may be out of adjustment or have mechanical problems.
Old 07-06-2013, 07:12 PM   #4
1988 32' Excella
Robbinsville , New Jersey
The trailer break wire hooked to the TV backup wire is a common way the plugs are miswired so the brakes activate with backup lights.
Old 07-14-2013, 04:30 PM   #5
1972 27' Overlander
Denver , North Carolina
I have a 72 overlandet that had an umbilical redesigned by the po. My TV is a 03 tahoe anyone have a diagram for this? Thanks!
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 07-14-2013, 04:57 PM   #6
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Thanks in advance
Here are the wiring diagrams for the old style and new style 7 pin connectors. As others have said this may be the problem.
7wayplug1966-81.pdf
7wayplug1982-84-1989-02[1].pdf
Hope this helps
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 07-14-2013, 05:09 PM   #7
genearnold's Avatar
1992 34' Limited
Grand Island , Nebraska
Above answers are most likely correct. My old '69 taught me that old Airstreams are not wired to the same schematic that later standard seven wire cords are wired to. I changed my trailer attachment to the new standard with a lot of time and a test bulb. The diagrams sent by Adonh will save you bunches on the time.
'92 Limited 34ft (now sold); '96 Dodge Cummins 4X2, 5speed
genearnold is offline   Reply With Quote
Old 07-14-2013, 05:19 PM   #8
1975 31' Sovereign
Texarkana , Texas
Thanks everyone. This forum is awesome. I appreciate all of the experience
Old 07-14-2013, 06:14 PM   #9
1975 31' Sovereign
Texarkana , Texas
Attachment 190915
Attachment 190916
Hope this helps
when looking at the diagrams...am I looking into the male part of the cable or the female receiver at the truck and trailer
Old 07-14-2013, 06:43 PM   #10
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Well seeing that it is a week later, were you able to back it up once the umbilical cord was removed?
Also you can buy new backing plates for about $60 each. It's really the way to go. When I pulled apart my breaks, some of the return springs had rusted through, and fallen off.
Silverflames is offline   Reply With Quote
Old 07-14-2013, 07:30 PM   #11
1975 31' Sovereign
Texarkana , Texas
Yes...I was able to back up. I found out that my reverse light wire and my brake wire were wired incorrectly.
Old 07-14-2013, 08:59 PM   #12
1972 27' Overlander
I agree with Dennis, you guys are awesome!
