Old 05-16-2019, 03:04 PM   #57
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
Originally Posted by gypsydad View Post
Yea; who knows what happened...how old the hitch/condition, tire situation, etc... But, at least he was trying to be safe by using a WDH... Like I said earlier, to each his own...best of luck with not using a WDH and towing with a smaller TV then recommended for the size AS you have! Listen to who you want; follow your own zen...just try not to have an accident that involves others...
My tow vehicle is big enough that I don't need a wd hitch. Actually, a good rule of thumb is that if you need a wd hitch then your tow vehicle isn't big enough to tow safely.
out of sight is online now   Reply With Quote
Old 05-16-2019, 03:04 PM   #58
2007 22' International CCD
Airstream 25RB with 1300 Pounds of Payload on TV?
No, Iím going to strongly and politely disagree.
WD hitch is needed to properly distribute the load across the whole rig. Sway control is needed to control sway.
Just because you have a Ďbigí truck does not mean itís towing safely. Towing is not a ďrule of thumbĒ evolution. Itís all about physics and engineering. Itís not guesswork.
Also, was the rollover victim using some sort of sway control and was it set up properly?
Just having a fancy hitch means nothing unless itís set up right. Even the PPP hitches wonít work right unless set up properly.
Worse, you have to check for decent handling every time you set out. Bad WD adjustments can leave the TV front end too light, and that can easily lead to a loss of control accident. There are a lot of factors that must be just right to tow safely.
rmkrum is online now   Reply With Quote
Old 05-16-2019, 03:23 PM   #59
2014 22' FB Sport
Davie , FL
I achieve near perfect weight distribution across my whole rig without a wd hitch.
Old 05-16-2019, 03:28 PM   #60
2014 22' FB Sport
Davie , FL
I say near perfect because I would actually like a little bit more load on my rear axle. A wd hitch can't do that.
Old 05-16-2019, 03:58 PM   #61
Add a few more things to the truck bed perhaps??
Old 05-16-2019, 04:06 PM   #62
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Sorry, but you don't. Without WD your front axle is significantly lighter than it was engineered empty. That affects both steering and braking, which will become especially evident in any sort of emergency braking or steering maneuver.
While you do not specifically say, is it a correct assumption that you are not using any form of sway control either? If not, you are just doubling down on asking for trouble. I know your response is Airstreams don't sway, but that too is not correct.
thewarden is offline   Reply With Quote
Old 05-16-2019, 04:32 PM   #63
2014 22' FB Sport
Davie , FL
You're wrong. A pickup truck is engineered to take more load on the rear axle than the front axle. That's why your rear axle has a higher load rating. When unloaded it has too much load on the front axle. When loaded it will have a better weight distribution. If you have more load in the front your vehicle won't handle or brake properly. You want more load on the rear.
I can definitely say that my Airstream doesn't sway. I load it properly. Sway seems to be something that hitch salesmen use to frighten people into buying their product. It's not going to happen if your tow vehicle is big enough and you're loaded properly.
Old 05-16-2019, 10:32 PM   #64
bono's Avatar
Mountain View , California
Wow, just wow. I just learnt to keep away from trucks not towing anything as they won't handle or brake properly.
BMW X5
SOB 33 ft trailer
Propride 1400
bono is offline   Reply With Quote
Old 05-17-2019, 07:46 AM   #65
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Rats...
And I thought OOS was OOM...guess I was mistaken, pay no attention, that which is expounded is singular in origin.🤓
Bob...King of useless Platitudes.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 05-17-2019, 08:17 AM   #66
HClews's Avatar
2017 27' International
Portsmouth , New Hampshire
Dan,
Hard to imagine that a Hemi-equipped Ram pickup wouldn't tow a 25-RB with aplomb.
We pull our 27-FB with a 2017 Durango R/T with the 5.7L Hemi. 10,000+ miles over the past two years, Florida Keys to Cape Breton Island - including the Blue Ridge Pkwy. Excellent TV, no hunting with the 8-speed trans, 13.5 mpg ave. Plus, a much nicer car to drive around when not towing - wife doesn't like driving a pickup.
Henry Clews
NH in summer, FL in winter
HClews is offline   Reply With Quote
Old 05-17-2019, 09:04 AM   #67
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Originally Posted by HClews View Post
Dan,
Henry Clews
Nice looking rig; remember, towing isn't the problem for a vehicle; pretty much any vehicle can tow a trailer...it's controlling a heavy TT like an AS, at highway speeds that's more important to consider...also payload....what is the payload of your SUV? What is the tongue weight of your AS? Add that to the total passenger weight and any cargo you carry...are you within the max payload on your driver door sticker?? If so, things are looking good...
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 05-17-2019, 09:04 AM   #68
aftermath's Avatar
Spokane , Washington
And here it is. You can't tow that trailer with your truck! And, you just might kill some of us on the road.
There are a lot of people out there that hook up their new trailer to their existing TV without giving it any thought. You are thinking about all of the issues and, I might add, perhaps over thinking a bit. You will never know your actual TW until you load things up and get it measured at the scales. You like your HA (or PP) hitch and have mentioned it several times. While they claim to provide the best anti sway out there, I don't think they are superior when it comes to WD. I tow a 25FB with my 2017 Tundra and use an Equalizer hitch. My TW, as measured at the scales, is very close to 950.
I have no trouble pulling this set up over the mountains and I have little trouble stopping it. While the braking capacity of the truck is important you must remember that the truck does not stop the trailer by itself. Proper setups will make the braking experience optimal. I am not familiar with the 25RB model but I do know that we have very little "storage" capacity in our FB. How much weight are you planning on putting in storage? How will this affect the TW? I certainly would not choose one model over the other based on this.
You asked for opinions. Here is mine. Your truck will do the job. Your hitch will help distribute the weight nicely. Your tongue weight will be in the 900-1000 pound range. You should go with the 25 over the 23 as no one says "I wish I had a smaller trailer". I have over 40K miles of towing my setup. I used an 08 Tundra before I got my new one. I have never had any issues with sway, travel light as it is only my wife and I. My combo sits level even when we add things like, generator, extra water and a few chairs. Go for it. With your experience towing, you will be just fine.
aftermath is offline   Reply With Quote
Old 05-17-2019, 09:14 AM   #69
gypsydad's Avatar
Well, you seem to be one of the "exceptions" on the road we all want to stay away from for safety reasons! Your AS "doesn't sway"...until it does due to wind or an emergency maneuver....but some lucky people have never experienced this (yet), so maybe that's why you think it will never happen...count your blessings and be safe. Lots of great experienced advice here...but some folks choose not to follow it. As I said earlier, to each his own...
Old 05-17-2019, 09:21 AM   #70
gypsydad's Avatar
Sounds right! (only reason to go with the 23' might be if your single...but my single friend who has a new 23', now says he wishes he would have gotten the 25'!) We had 3 25's and love the size; just didn't like the lounge/dinning set up, which is why we moved to the 28 and a larger TV...I loved my F150 EB with the 25's...thought that size was great match up, but I was over the payload rating...didn't understand that part of the equation till a year or more after I owned it...we are all learning and trying to be safe on the road, while enjoying the AS life! (well, let me clarify that...most of us I think are trying!)
2008 Toyota Tundra and a VTX 1300 hippygypsy Towing, Tow Vehicles & Hitches 4 06-16-2014 02:34 PM
2012 airstream bambi 16 sport 2919 pounds*huge sale* eBay Watch Airstreams on eBay 0 08-25-2011 06:40 AM
2012 airstream bambi 16 sport 2919 pounds*huge sale* eBay Watch Airstreams on eBay 0 08-17-2011 06:00 PM
2012 airstream bambi 16 sport 2919 pounds*huge sale* eBay Watch Airstreams on eBay 0 08-09-2011 01:20 PM
2nd 1300 mile trip home to AZ uneventful silverback Classic Motorhomes 9 08-17-2009 07:41 AM
