Old 04-02-2013, 09:08 AM   #15
2012 25' FB Flying Cloud
mercersburg , Pennsylvania
Class VI
Can you tell me what the actual weight of a class VI and a class V is? Tks.
wpifer is offline   Reply With Quote
Old 04-04-2013, 05:23 PM   #16
Airstreamer67's Avatar
I just put my Class V AirSafe on a scale, and with the balls on it and hitch lock ready for towing, the weight is 77 pounds. That thing is made of very heavy gauge steel. It's made to last. The bags are Firestones, the same as are used on air ride suspensions and lifts and can be replaced if they're ever damaged.
I've been using my AirSafe since 2006 from coast to coast. It provides all the benefits stated on their website. It has stopped the riven-popping and skin-shearing I was experiencing towing with a heavy duty pickup.
I'd buy another one in a heartbeat.
Airstreamer67 is offline   Reply With Quote
Old 05-30-2014, 10:22 AM   #17
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
As an update, the Class 6 has performed flawlessly and in the few years I've had it, I can honestly say this is one great (though expensive) piece of engineering. The 3/4 ton is really hard on the trailer and the 3/4 ton jounce with the rigid connection is virtually non-existent with this in place.
If you have anything more than a 1/2 or equiv vehicle, I can say without question, this is a good piece of equipment to have, though I will admit, I no longer need a heath club membership since mounting and dismounting this from the receiver on the truck....she's a heavy monster, only exacerbated by the fact I have the Enkay mud flaps attached to it too, but well worth it IMHO.
Old 05-30-2014, 11:56 AM   #18
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Completely agree...
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 06-02-2014, 11:01 AM   #19
Air-Texas's Avatar
2004 34' Classic S/O
Waldorf , Maryland
model numbers
Originally Posted by Bluto View Post
That's the way I set mine up. Reese first, then Airsafe. I fooled around with my set up for quite a while. I even ended up taking trips and adjusting it a couple of more times till I was finally satisfied.
Just take your time. It will be worth it.
I am looking at selling my HaHA and getting this setup. Can someone post the model numbers of the reese strait line dual cam wd system.
When I look at them on line, there seem to be many variations of the reese system.
Mike, Miho &
Dallas the Bourbon Boxer
S/OS#069
TAC # TX-33
WBCCI #5702
AIR #60387
"Eva" 2004 Classic Limited 34' S/O
"Wall-E" 2012 Ford F250 King Ranch
Air-Texas is offline   Reply With Quote
Old 06-02-2014, 12:51 PM   #20
2010 27' FB Classic
N/A , Texas
Maybe someone else can field this question for Air-Texas.
The Reese set up I'm using is an old system that is from 1987. It' has the 1000# bars. Of course, the AirSafe hitch portion is only a few years old.
I am not familiar enough with the new Reese products to state which one is right for you.
Old 06-03-2014, 05:23 AM   #21
Air-Texas's Avatar
Waldorf , Maryland
Thanks Bluto, Reese has many different products out there, and I do not know enough about them to pick the right one..
Mike, Miho &
S/OS#069
TAC # TX-33
WBCCI #5702
AIR #60387
Old 06-10-2014, 10:22 AM   #22
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
I may be mistaken, but I think the Dual Cam system is an "add on" to the Reese Staight Line hitch. A year or so, I sold my original Reese Dual Cam with an SOB (Open Range) that I sold.
When I bought the AS that we now have, I bought a new style Dual Cam, for the current AS.
Just make sure that when you buy, to get the 800 pound trunnion bars. Mine came with the 1,200, and even with the AirSafe, it is overkill. I finally found a set of 800 pound bars.....
You will like the AirSafe/Reese set up, especially when you are hooking up, and unhooking...
Larry C
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 06-10-2014, 11:12 AM   #23
Roadtrain O--O~(--ooo--)
ebair's Avatar
2000 34' Limited
1979 31' Excella 500
Miamisburg , Ohio
We put a class 6 on the 3500 Chevrolet in 2008, use it to tow our 34' Limited. Like the others much smoother ride over concrete roads and much less shock transmitted to the coach from the HD suspension of the truck. We have a Reese hitch and use the 600 lb bars. Highly recommended!
'00 34' Classic Limited (LOVSHAC)
'12 3500HD, 4x4 LBZ D/A CC LB
AIR #12881
TAC OH-10
ebair is offline   Reply With Quote
Old 06-10-2014, 01:22 PM   #24
Air-Texas's Avatar
Waldorf , Maryland
Thanks, but are there any model numbers?
Sent from my SM-N900T using Airstream Forums mobile app
Mike, Miho &
S/OS#069
TAC # TX-33
WBCCI #5702
AIR #60387
Old 06-10-2014, 01:27 PM   #25
Aluminut
2004 25' Safari
. , Illinois
You need something like this:
Reese 66082 Weight Distribution Strait Line 600 Trunnion Bar w Shank | eBay
I spec'd out the 600# bars, but this gives you a general idea of whatcha need.
Old 06-11-2014, 06:58 AM   #26
Air-Texas's Avatar
Waldorf , Maryland
Thanks. There are so many model numbers on line, that it's hard to find the right one.
Mike, Miho &
S/OS#069
TAC # TX-33
WBCCI #5702
AIR #60387
Old 06-11-2014, 08:10 AM   #27
jump's Avatar
2013 30' International
lubbock , Texas
Bought my reese straight line from e trailer ... better price than is shown on that eBay sale from carid.
jump is offline   Reply With Quote
Old 09-04-2014, 05:44 PM   #28
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Photos
If possible, would like to see a couple of photos from different angles with the Airsafe and an Equalizer WD hitch. Thanks
tsunami is offline   Reply With Quote
Forced air furnace heating black/gray holding tanks? DearArgosy Waste Systems, Tanks & Totes 8 11-24-2016 12:54 PM
Air Conditioner replacement advice NevaH Furnaces, Heaters, Fireplaces & Air Conditioning 16 05-10-2012 07:16 PM
Air condition 15k Denkim Furnaces, Heaters, Fireplaces & Air Conditioning 4 03-24-2012 12:57 AM
Air Conditioner Hum, advice? Jim & Susan Furnaces, Heaters, Fireplaces & Air Conditioning 25 03-23-2012 01:42 PM
