Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 10-25-2009, 04:32 PM   #1
Profile:  Concord , California
Aftermarket cooler ok???
I just found a 5.4 1500 chevy 2006 but with NO towing package I was told pickups of that size engine ALREADY have a larger radiator and tranny cooler. I only need to professionally have a prodigy, and sway braces installed with new hitch. Is that true? Would that be as good as factory??Thank You Dave Gale
dansdad is offline   Reply With Quote
Old 10-25-2009, 04:48 PM   #2
Commercial Vendor
Profile:  Corona , California
Adding a transmission oil cooler, will pay many dividends.
But, don't install the cooler in front of the radiator, or AC heat exchanger.
To remove the heat from the radiator, is great, but you don't want to turn around and put it right back into the radiator.
Install the tranny cooler, below the radiator, behind the bumper, so that it can get plenty of "ram" air when moving.
That installation does 3 things.
1. It removes heat from the radiator.
2. It helps controlling the tranny oil temperature.
3. It helps lowering the engine temperature.
Installing a tranny cooler in front of the radiator, helps with # 2 only.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 10-25-2009, 04:52 PM   #3
Then what you are saying Andy is that 5.4 engines dont just come with proper tranny coolers and larger radiators? Stick with factory only?
Old 10-25-2009, 04:56 PM   #4
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
With out the tow package does the truck have a 7 pin trailer connector or a tow/haul switch?
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 10-25-2009, 04:57 PM   #5
Commercial Vendor
Adding a tranny cooler, is a plus.
Not having one, over and above what might be original equipment, will cause the tranny oil to reach temperatures that will cause harm.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-25-2009, 04:57 PM   #6
No it does not. There is nothing there
Old 10-26-2009, 11:20 AM   #7
What I meant Richard... is that no wiring harness is present. I really want to know if 1/2 trucks come from the factory with a large tranny cooler. If not II will get one. Dave
Old 10-26-2009, 11:30 AM   #8
Commercial Vendor
Dave.
A good tranny cooler will be about 8 x 12 inches and about 1 1/2 to 2 inches thick.
Anything less than that is not adequate for towing a large Airstream.
Hayden makes the best tranny coolers.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-26-2009, 11:37 AM   #9
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
Don't know about other brands, but my Ford did not come with an external transmission cooler. It had one for the power steering pump only.
My only gripe about most of the aftermarket coolers is the cheesy plastic ties manufacturers provide to mount the cooler. We ended up fabricating an aluminum frame to mount ours in.
We had trouble flaring the trans line steel tubing. I ordered some steel compression fittings that did the trick.
It was a six pack project.
Regards,
Kevin
Experience isn't always the best way to learn...You usually get the lesson first...And the instruction afterwards...
Old 10-26-2009, 02:23 PM   #10
SteveH's Avatar
Profile:  2001 25' Excella
San Antonio , Texas
"Normally" there is more to a factory towing package than the tranmission cooler. I'm not up to speed on what Ford installs, but the GM trucks with the towing package come with a transmission cooler, factory trailer wiring harness, a heavy duty radiator, a heavy duty alternator, receiver hitch, and a lower rear end gear ratio...usually a 3.73:1, although the Chevrolet 1/2 tons use a 3.42:1 when I was last looking at the specs.
Aftermarket Breakaway Switch uniquemicro Brakes & Brake Controllers 2 09-19-2009 08:20 PM
Aftermarket solar flmgrip Generators & Solar Power 1 08-09-2009 07:23 PM
Lets see your aftermarket wheels???? LAWFISH Wheels 4 04-20-2009 06:55 PM
Aftermarket Miles Per Gallon Gauge herrgirdner Off Topic Forum 11 05-22-2008 09:32 PM
Dealer/Aftermarket Hitch Equipment Toasty's Dad Hitches 12 12-02-2005 01:18 PM
