Old 02-10-2015, 07:43 PM   #71
Tao
Tao's Avatar
2013 19' International
Chapel Hill , North Carolina
Am I correct in assuming you speaking of replacing the default Airstream tires with 16" LT tires?
If so, is there any brand that folks have found to be the best for traction and blowout prevention?
Originally Posted by MacPDX View Post
According to this logic, every owner should upgrade:
1. To 16" LT tires, because they never experience blowouts
2. To a one ton dually, because it tows better
It's only money after all.
There are numerous hitches that when setup properly, with conservative driving habits, will provide the same experience. Reese, Blue Ox Sway Pro, Equalizer, just to name a few. Not everyone needs or can afford the most expensive.
The most important thing is the setup.
Tao is offline   Reply With Quote
Does Dodge RAM's Integrated Sway Control Work Well With Friction Sway Control? interstateflyer Towing, Tow Vehicles & Hitches 9 08-13-2014 10:05 AM
Equal-i-zer Sway Control Hitch vs Blue Ox Sway Pro airstreampek Hitches, Couplers & Balls 31 06-18-2014 10:56 PM
Sway bars and sway control phibbs Towing, Tow Vehicles & Hitches 1 09-03-2012 05:48 AM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
