Old 10-23-2007, 02:03 PM   #1
Silverton , Oregon
8 Connections for a 7 Pin HELP!
We've added some back up lights to our 1964 Bambi II. The original wiring for the trailer plug includes:
Marker
Brake Light
L Turn
R Turn
Charge Line
Brake
Ground
How do I work in the reverse?
Can-O-Pabst is offline   Reply With Quote
Old 10-23-2007, 02:09 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Marker
Brake Light
L Turn
R Turn
Charge Line
Brake
Ground
Left turn and right turn are the same as the brake light, no separate wire needed. Do you have a plug installed on your tow vehicle? If so, you can determine which pin does what and wire the cable to the trailer the same.
Bill
Just my personal opinion
wkerfoot is online now   Reply With Quote
Old 10-23-2007, 02:20 PM   #3
Silverton , Oregon
What's the deal with three wires coming out of each tail light then?
Old 10-23-2007, 02:32 PM   #4
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
One could be a ground. How many bulbs are there? One should have two filaments. Have someone turn on the turn signals on the tow vehicle and then step on the brakes, you will see that on the turn signal side there is no brake light. If you turn on the parking lights and then the brakes it has the same brightness as the turn signal.
Unless you have a tow vehicle which has the turn signal separate from the brake lights, most european vehicles, then you need a electronic adaptor box to convert the separate signals to one for the trailer.
Bill
Old 10-23-2007, 05:59 PM   #5
richinny's Avatar
2011 34' Classic
Bill
i don't think that's right. the right signal would flash both sides wouldn't it?
Ricky
Old 10-23-2007, 06:34 PM   #6
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Nope, only the brake signal sends current to both sides. The turn signal switch only sends current to one side.
Bill
CG Cable Connections Denis4x4 Audio, Video & TV 1 09-18-2007 05:26 PM
LP Connections - US vs Canada campadk LP Gas, Piping, Tanks & Regulators 0 04-30-2007 10:15 AM
Tow Connections jcferguson Electrical - Systems, Generators, Batteries & Solar 1 02-19-2005 03:34 PM
TV connections Southern Gal Electrical - Systems, Generators, Batteries & Solar 10 07-17-2004 12:06 AM
