Old 02-13-2007, 01:43 PM   #1
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
7 wire cable length ?
I have about 4 extra feet of this big cable doing nothing.
I want to cut it down how much extra slack do I need keeping in mind that when I turn to the right it needs some extra anyway.
'77 Sovereign Intl 31' CB
Old 02-13-2007, 02:44 PM   #2
30' 1999 Excella
Tin Diesel's Avatar
Kingwood , Texas
Send a message via Yahoo to Tin Diesel
take up slack under the frame
How much slack you need will depend on your unit, but mine has a bit less slack than the chains (so it won't come close to dragging) and it does fine. It only sags about half as far as the chains. I have a looped bungy cord permantly in place (where the chains connect to the A-frame) to keep the wire from sagging too much.
Rather than cut it, you might be able to take up some of the slack under the belly of your A/S by loosening the clips, pulling it back, widening any turns, and maybe adding one more retaining clip.
When we got ours, it still had an old style plug. I switched to the new style, but lost a few inches. When we switched to the Hensley Arrow hitch, I needed those few inches plus a few more. Fortunately, I was able to pull out some excess that was looped under the frame.
Hey, its the only way to be sure!
Tin Diesel is offline   Reply With Quote
Old 02-13-2007, 03:05 PM   #3
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I'm with Tin on this - it is much easier to tuck away some excess than it is to splice in more later.
Pat
pmclemore is offline   Reply With Quote
Old 02-13-2007, 03:14 PM   #4
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Oh yea! Tucking is always better than cutting! You can either pull it back into the trailer and secure it from the inside or do what we do and that is give it a wrap or two around the tongue jack.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 02-13-2007, 03:51 PM   #5
ScottW's Avatar
Hernando , Mississippi
I agree with the tucking. Splices are electrical problems waiting to happen, IMHO.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 02-13-2007, 05:37 PM   #6
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Don't cut that cable! Form a service loop under the frame. Get some big ty-wraps. Mine has one turn around the Power Jack. This takes the strain off the entry point to the frame.
This was poinent when I had the accident. It pulled the plug out of the truck with out damaging the trailer.
Michelle TAC MT-0
Sarah, Snowball
Old 03-07-2007, 11:37 AM   #7
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Mag Strap
I found an item in my local autoparts store called a Mag Strap. It's made by the Hoppy people who make a lot of trailer electrical parts. The Mag Strap is just a big magnet with a strap and buckle attached. It works great for keeping the 7-wire cable and the breakaway cable off the road, but because it's magnetic, will pull away in any disaster scenario.
Randy and Pat Godfrey
Florida Airstream Club (027)
WBAC# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Is the 4 wire cable needed for Shore? PhilMateo Electrical - Systems, Generators, Batteries & Solar 1 01-24-2006 06:41 PM
Sewer Hose length? AirHog Waste Systems, Tanks & Totes 16 04-21-2004 02:39 PM
Extra wire susan martin Batteries, Univolts, Converters & Inverters 3 09-21-2002 08:52 AM
Replacing wire harness Les Gilliam Batteries, Univolts, Converters & Inverters 4 08-19-2002 09:25 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 10:54 AM
