Old 11-20-2016, 05:13 PM   #1
1972 29' Ambassador
quitman , Georgia
7 way plug inside 72 ambassador
Hopefully I'm asking in the right area. I've searched and unless I'm not saying it right I'm not coming up with much. We have a 72 ambassador 29' and the brakes do not work. Originally when we got it they would lock up with just a 7 pin plug with no controller. I unhooked the white wire from the inside of the A/S I now have a new truck with controller and can't for the life of me remember where the white wire goes. Can anyone help?
Ryocomjr is offline   Reply With Quote
Old 11-20-2016, 05:46 PM   #2
1973 31' Sovereign
Middletown , California
On the trailer back then I think white was ground and yellow was brakes. It seems that you always need to set up your truck and trailer to match each other. There are a few standard color codes to chose from and your truck may be wired to one that is common for travel trailers but you will need to match wire to function for your trailer the first time.
ijustlee is offline   Reply With Quote
Old 11-20-2016, 07:10 PM   #3
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
All the info needed to connect.
https://www.etrailer.com/faq-wiring.aspx
Garry
Old 11-20-2016, 07:24 PM   #4
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
This is from the '72 service manual.
Hope it helps.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 11-21-2016, 12:41 PM   #5
belen , New Mexico
I had 10 vintage airstreams in about 10 years and every single one was wired wrong so you just got to have trial and error and blue is usually the color for breaksome
alantbird is offline   Reply With Quote
Old 11-21-2016, 01:57 PM   #6
1972 29' Ambassador
quitman , Georgia
Thank you guys for the replies. I guess I'll be out with a tester and trial and error
to plug in or to not plug in...that is the questions 4hartungs Batteries, Univolts, Converters & Inverters 39 04-23-2014 03:44 PM
Weird Science (7 way plug, help!) Blakradish Batteries, Univolts, Converters & Inverters 13 08-08-2011 02:57 PM
Inexpensive way to protect your 7-way plug SmokelessJoe Lights - Interior & Exterior 6 03-05-2011 02:08 PM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
