Old 03-21-2019, 06:46 PM   #1
2016 25' Flying Cloud
z , Texas
7-Way Connector Queston
I have an 2018 F-250 PSD and 2016 FC FBT, The 7 Pin plug does not seem to go all the way into the socket, It just seems like the tab on the door, is the only thing holding it in and the pins do not actually engage each other, BUT When it is plugged in and the door tab is holding the plugin, the lights do not flicker, they do stay on. that is a good thing but is it right? Mike
5150mike is offline   Reply With Quote
Old 03-21-2019, 06:50 PM   #2
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
Hmmmm…. I'm not quite sure what you're saying/asking.
Sounds like your lights work fine - is that correct? Do the brakes work? All systems working as far as you know? If yes, then sounds like you don't have a problem.
If the 7-way plug goes into the socket far enough that the tab on the door engages with the bump on the plug then that's as far as is going. It won't go any farther. The tab and bump lock the plug into the socket.
Lucius and Danielle
1992 29' Excella Classic
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 03-21-2019, 06:51 PM   #3
DaveP's Avatar
2004 28' Classic
Monument , Colorado
They tend to be kinda loose. Mine is. If the tab is latched on the door and the lights don't flicker, you have a winner.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 03-21-2019, 08:37 PM   #4
2007 22' International CCD
I have to push rather hard to seat my 7-pin. Once it’s solid, the cover latches it and my trailer lights and brake systems work fine. Leads to hand strain and skinned knuckles occasionally, and when I bend down or kneel it’s ‘interesting ‘ to get back up.
I’m going to the EZConnector system to avoid the skinned knuckles. These lock up tight using magnets and gold plated pressure pins. You literally just line it up, and it jumps together and holds tight.
Old 03-22-2019, 05:45 AM   #5
2017 27' Flying Cloud
Fort Worth , Texas
With my 2017 F-250, the connection is also loose. In fact, on the way to FL, I kept getting “trailer disconnected” messages on my dash. Then it would suddenly reconnect. It continued this for awhile. I sprayed the connector with contact cleaner and the messages continued. For some reason, they went away about an hour later.
billrector is offline   Reply With Quote
Old 03-22-2019, 07:03 AM   #6
2019 23' Flying Cloud
Auburn , Alabama
7-way connector
I recently had a similar issue with 'loose' connector between trailer and TV. I ended up replacing the Airstream side connector with a Pollak 12-706. Previously, my TV was a 14 Tundra and did not appear to be 'too' loose. After upgrading TV to a 18 2500 Ram, it appeared the connectors were not fulling engaging. Search revealed the Airstream connector was the issue. see following for full explanation and images: http://www.rambodybuilder.com/2016/d...ConnCompat.pdf
I replaced the Airstream side connector with a Pollak 12-706 and the connecters now to appear to be fully seated. Apparently, the issue was related to the 'molded' trailer side connector, as explained and illustrated at the above link.
martyw is offline   Reply With Quote
Old 03-22-2019, 07:29 AM   #7
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Any One Use the EZ Connector System?
Never heard of this EZ Connector Female To 7-Way Male Adapter system. Does anyone have any experience with it?
DaveP
Old 03-22-2019, 07:38 AM   #8
Mollysdad's Avatar
My Tundra feels the same.
I was afraid the truck half was pushed into the bumper, but it always works.
Some people put a wrap of velcro around the plug/door to insure it stays hooked.
Looks like it adapts a RV plug to a semi-tractor plug.
Old 03-22-2019, 07:47 AM   #9
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
You need to seat it all the way. On my Dodge I have learned that I need to bump it with a hammer to get it to seat all the way in. Nothing wrong with it. Just the rubber to rubber fit plus the pins makes it too hard to seat reliably by just pushing steady.
Old 03-22-2019, 08:13 AM   #10
UncleBad's Avatar
2019 16' Sport
Oro Valley , Arizona
Is this the product?
http://ezconnector.com/rv-trailer-plugs.html
Looks nice - my 7 way currently has no issues but this does look like a slick solution. My only worry would be having a non-standard plug.
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
UncleBad is offline   Reply With Quote
Old 03-22-2019, 09:06 AM   #11
They sell adapters as well as total replacement setups. I’m using adapters for now.
Old 03-22-2019, 10:19 AM   #12
2019 27' Globetrotter
Salem , Oregon
That looks like a great product. Dave
NoResults is offline   Reply With Quote
Old 03-22-2019, 03:24 PM   #13
It is a lot easier to hook up, and gives me just enough extra cable length to keep the umbilical well connected on sharp turns.
Old 03-22-2019, 03:56 PM   #14
2014 25' FB Flying Cloud
Grand Rapids , Michigan
I had the same issue with our 2016 GMC 2500 after a switch from our 2008 Tundra, even worse as they have the plug upside down as far as I’m concerned and the latch is on the bottom.
Switched the original trailer side plug to the Pollak and the issue has been fixed.
MIFC is offline   Reply With Quote
Converter Location Queston sailaw Electrical - Systems, Generators, Batteries & Solar 2 10-12-2012 01:31 PM
E-Z Connector: Upgraded 7-Way slowmover Brakes & Brake Controllers 17 11-02-2011 02:33 PM
'71 Tow vehicle/trailer 7 way connector wiring Lumatic Lights - Interior & Exterior 12 08-15-2010 08:19 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 07:09 PM
2nd Battery/7-way connector wbrownrr Electrical - Systems, Generators, Batteries & Solar 8 05-19-2005 05:22 PM
