Old 09-29-2017, 02:07 PM   #1
Beer Snob's Avatar
2006 25' Safari
1966 26' Overlander
Wainscott , The Hamptons, Long Island
7 pin plug question
Hi all:
I've been pulling a 2006 Safari for a number of years. Just this month I've purchased a 1966 Overlander to keep it company. I've discovered the pin- style receiver on my tow vehicle is not compatible with the rectangular shaped receivers on the Overlander plug.
What is the shortest distance to compatibility here? Do they. ( whoever they are) make a simple plug in adapter?
Thanks in advance
ID:	295810   Click image for larger version
Beer Snob is offline   Reply With Quote
Old 09-29-2017, 02:15 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
In my opinion, buy a new style plug and wire it up per the correct specs. Just cut off the old one. If you can't find a plug, buy a short cable and splice it in. There are not so good cables out there. I bought one from Amazon and the connector "sockets" were soft material and were easily bent so as to not make a good connection. You want a connector with metal on both sides of the slot, and the two sides close together and springy.
Are you sure the two parts you showed don't mate? From the pictures, it looks like they should. The pic on the right looks like the single-sided connector I almost bought. It looks like it should mate, but the wiring may not be right.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 09-29-2017, 02:15 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
You may well discover that if nobody has rewired the receptacle on the trailer, that the arrangement/ordering of the wires is not compatible with modern standards as well. I would suggest that the way to fix it is to buy a receptacle, wire it into your trailer, and then you can use a commonly available unbilical to attach to your tow vehicle, or use the one you have for your other trailer, assuming it isn't hard-wired.
good luck!
Old 09-29-2017, 02:43 PM   #4
Beer Snob's Avatar
2006 25' Safari
1966 26' Overlander
I've been able to push the plug into the TV's Receptacle with some difficulty but no lights! Perhaps it IS different wiring.
Here is a shot from the owners manual found in the 66.
Old 09-29-2017, 02:50 PM   #5
Beer Snob's Avatar
2006 25' Safari
1966 26' Overlander
This is the plug on the 2006.... works fine.
Old 09-29-2017, 02:59 PM   #6
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
You'll probably find the ollllld wiring doesn't match up with the new. And if you need cousin jimmy to bring your trailer out to the lake fishing for you, he'll probably need it wired to the newer pattern.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 09-29-2017, 03:03 PM   #7
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If the plug fits into the socket (it looks like it should) then that's not the problem. If this is a brand new to you trailer, I would not *assume* the lights are wired up at all. First step would be some quality time with a couple of wires. Poke 12V here and there and see if the lights ever come on. Yes, you have to be a bit careful about not poking +12 onto the ground pin(s)
uncle_bob is online now   Reply With Quote
Old 09-29-2017, 03:14 PM   #8
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Nevada is right, don't assume the trailer wires on a 66 will serve the function listed. Check each wire on the trailer as to its function and then wire up the plug. My 68 had a couple of wires whose function was not what the diagram said it would be.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 09-29-2017, 03:35 PM   #9
Beer Snob's Avatar
2006 25' Safari
1966 26' Overlander
You guys are great....thanks.
I saw the lights working when I bought sonI know this isn't futile.
And.... I just found a panel underneath with this....
Old 09-30-2017, 05:02 PM   #10
belen , New Mexico
EVERY single A/S I Owned (10) I had to mess with that thing! The best time was when I got the revers lights to work on my 79!
alantbird is offline   Reply With Quote
Old 10-01-2017, 12:03 PM   #11
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
I would clean those contacts, and corrosion proof them.
"Look after your equipment, it will look after you."
"Trailer Trash..................."
MelGoddard is offline   Reply With Quote
9 pin to 7 pin conversion ck21084 Electrical - Systems, Generators, Batteries & Solar 4 06-10-2010 02:58 PM
6-pin connector to AS 7-pin Ruben J Towing, Tow Vehicles & Hitches 6 04-15-2009 10:29 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 07:09 PM
'72 trailer 7 pin vs '99 truck 7 pin wiring? Hawkeye5 Lights - Interior & Exterior 4 08-02-2008 01:34 PM
7 pin plug question JoshuaTonbo Lights - Interior & Exterior 6 06-09-2006 08:56 AM
