Old 01-04-2014, 07:41 PM   #1
2011 23' FB Flying Cloud
Augusta , Kansas
7 pin plug
I have a new gmc truck , how can I tell if the battery charge pin is hot and will charge my new airstream battery.? Will it show on the monitor gauge? Since it is a new truck , i amnot sure the batery pin is hot.
submirj is offline   Reply With Quote
Old 01-04-2014, 07:59 PM   #2
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
Start the truck and check the pin with a test light. Turn the truck off and see if the pin is still hot (some vehicles are constantly hot and feeding off of the tow vehicle battery, others turn off the circuit with the ignition).
robert claus is offline   Reply With Quote
Old 01-05-2014, 04:11 AM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Agree, you need to put a test light or voltmeter on that pin and ground. Recent GM trucks, maybe always, have that wire not connected through the ignition so that once connected it is always hot. Beware, that means that you must unplug when not running the truck or you risk running down your truck battery.
My truck came with the towing package and the trailer charging battery connection was connected under the hood. Most descriptions/instructions lead you to believe that this wire is not connected from the factory and tell you how to connect the wire. Plenty of stuff on the internet about how to do it.
Larry
lsbrodsky is offline   Reply With Quote
Old 01-05-2014, 05:05 AM   #4
sb55's Avatar
2018 30' Flying Cloud
South Hero , Vermont
I had to hook up 2 wires to the studs next to the fuse block, and also buy 1 fuse. For some reason , GM leaves out that 40 amp fuse. I found the several videos on e-trailers.com, but every video does not mention that fuse.
sb55 is offline   Reply With Quote
Old 01-05-2014, 05:05 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up The PDC...
The Power Distribution Center, under the hood, left side under the plastic cover.
If yours looks like this.
The charge wire connects to 'stud #2', top right.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
