Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 01-06-2006, 04:12 PM   #15
mtnman
Profile:  Currently Looking...
Collettsville , North Carolina
Do you have separate brake and turn functions on the Ford's taillights? If you have a separate bulb for each of these functions then you need a tail light converter module installed just upstream of your Hoppy. This will convert the 3-way tail light functions on the Ford to the 2-way operation of the AS. If Ford includes one with the tow package then you it might not be working properly and may need to be replaced.
Ok, I checked the lights and I do not have seperate light functions. I unpluged the hoppy 7 pin from the truck wires and I do have 2 hot pins when I hit the brake lights. Is one of these for the electric brakes, which one? I do not have a charging wire either that I can find? Every thing else looks normal but I will still have 2 poles flashing when I plug the Hoppy back in? I suppose I could cut the Hoppy wires and plce them to work what I want.
mtnman
mtnman is offline   Reply With Quote
Old 01-06-2006, 06:09 PM   #16
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Mtnman,
Here is the color code for a 7-way plug:
Yellow: center for aux. (center)
White: ground (bottom left)
Blue: electric brakes (bottom right)
Red: left turn/stop (center left)
Brown: right turn/stop (center right)
Green: tail/running lights (top left)
Black: hot from TV battery (top right)
Note that these locations are looking INTO the plug from the rear of the TV.
The black should always be hot and the blue should only be on when you depress the brake pedal and your brake controller senses the decelleration.
Hope this helps!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
lewster is online now   Reply With Quote
Old 01-06-2006, 06:51 PM   #17
Jim & Susan
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough , Georgia
Images: 37
Lew,this is the wire breakout for the truck, right?
Guess I'm getting old. Don't recognize any of the famous people in the "Got Milk?" ads any more.
www.nesa.org
Air No. 6427
Jim & Susan is online now   Reply With Quote
Old 01-06-2006, 06:55 PM   #18
mtnman
I called the auto parts place today. The fellow I talk with said they didnt have a tester but said the tester just confirmed each pin with a light, same thing I can do with my test light. He did say if I would bring in the Hoppy 7-pin connector that he would compare it to a new one and if the one I have is bad or different than what the new one was he would switch it with me at no charge.
mtnman
Old 01-07-2006, 04:26 PM   #19
mtnman
OK, I think the truck is all right. Now it’s back to the coach. I pull my tractor up to the trailer and grounded it good with jumper cables. Then I checked each wire one at a time with the tractor battery. The pigtail from the outside to the inside is fine. I learn that from disconnecting all the top wires inside and checking them. I still have a short or something wrong somewhere on the inside. I still have both rear lights on at the same time when only 1 side should be on. I Have 3 wires that all have continuity from the bottom terminal. Counting from left to right, number 3, 4 and 5 all have continuity even when disconnected from this terminal? That would be the Brown, Green and Blue wires. What do you think is wrong? Any suggestions?
mtnman
Old 01-07-2006, 05:54 PM   #20
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
7-Pin connector problem
Greetings mtnman!
mtnman
Based on the schematics that I have, the wires you have listed would be:
Blue -- Main Charge Line
Brown -- Stop and Right Turn
Green -- Tail Lights and Clearance Lights
In addition, the following is listed in the schematic pertaining to the 12-volt Exterior Lights:
Red -- Stop and Right Turn
Black -- Backup Lights
Yellow -- Brakes
White -- Ground
Electrical problems are far from my specialty, but it occurred to me that there might be a problem with the breakaway switch -- I have had problems with the break away switches on both of my coaches where both had shorts in them when I purchased the coaches.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 01-07-2006, 09:49 PM   #21
mtnman
Originally Posted by overlander64
Greetings mtnman!
Kevin
I never thought about the break away switch? I dont know much about it other than it is one on there and it looks like the one that came on it? How do you check the break away switch or disable it?
mtnman
Old 01-07-2006, 09:51 PM   #22
mtnman
Could the break away switch cause the problem I mentioned above or is it isolated from the 7-pin stuff?
mtnman
Old 01-07-2006, 09:59 PM   #23
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
soon to be , on the move again
Images: 58
mtnman
All the greakaway switch does is engage the trailer brakes whe it is actuatede. It shouldn't have any effect on the lights unless it is miswired, and you would notice the trailer brakes locking up when you use the turn signals...
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
Old 01-07-2006, 10:26 PM   #24
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
I think that one of the problems you are seeing is that when you measure continuity on lines to lights you are reading the ground through the filament of the bulb. I would remove the bulbs from the sockets and measure again.
Richard
Charter Member Four Corners Unit
Old 01-07-2006, 10:51 PM   #25
azflycaster
Phoenix , Arizona
Images: 58
The more I think about your problem, the more it sounds like it could be caused by bad grounding. Verify that the ground connection from the connector on the trailer is clean with no corrosion. Also check where the ground for the bulbs attach to the ground. Good Luck and hang it there!
Richard
Old 01-08-2006, 09:07 AM   #26
mtnman
Thanks everyone! I am going to work on it some more today.
mtnman
Old 01-09-2006, 04:25 PM   #27
mtnman
OK, here is an update. I found 1 bulb in the right rear turn signal fixture shorting out and another one not making contact. The one making the short had a terminal wire hitting the side of the socket due to a worn out insulator. I also found that the Hoppy adapter on the truck is still giving trouble, its shorting or just plain failing. I can make all the lights on the coach light up and work fine using the flat 4 prong plug on the side of the 7-pin plug.
I think this problem is resolved!
mtnman
1978 24ft Argosy brakes juel Brakes & Brake Controllers 6 10-31-2004 04:14 PM
Need 7 pin wiring help. TBKP's Overlander Electrical - Systems, Generators, Batteries & Solar 3 04-21-2003 01:27 PM
Hot Water Heater Exhaust Damage Road Ruler Water Heaters, Filters & Pumps 11 11-11-2002 02:27 PM
Door hinge pin. wyhjr Doors & Locks 3 10-20-2002 03:36 PM
Hinge pin movement jcanavera Doors & Locks 15 10-04-2002 10:26 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
