Old 09-30-2017, 11:07 AM   #1
Avondale Estates , Georgia
7 pin adapter
Can I purchase an adapter for this at an auto parts store?
tinandson is offline   Reply With Quote
Old 09-30-2017, 11:10 AM   #2
Half a Rivet Short
Carlisle , Pennsylvania
You might consider changing your personal info from "looking" to a description of which AS you have. That would help people work out which parts you might be looking for.
What are you trying to adapt from?
What are you trying to adapt to?
In some cases a new cable or socket is a better answer.
Old 09-30-2017, 12:13 PM   #3
Mollysdad's Avatar
If you want to go from a 7 way spade (RV) in your vehicle to a 4 way flat (boat trailer, etc) there's an adapter.
If you only have the 4 way flat in your vehicle, then you can make your own adapter, but you won't have brakes or 12v.
There's not a commercially made one I know of because it's technically illegal.
is it possible to use the 4 pin connector on my car with an adapter? groovzilla Hitches, Couplers & Balls 8 11-25-2013 12:16 AM
7 Pin Round to 7 Blade Trailer Connector Adapter Needed Jeremy9107 Electrical - Systems, Generators, Batteries & Solar 14 07-25-2013 03:58 PM
Is there an adapter from the Airstream 7 pin on my '71 Safari to a 7 blade? MrJim 1969 - 1973 Safari 6 06-16-2013 08:15 PM
4 to 7 pin adapter ? Dan S Towing, Tow Vehicles & Hitches 24 03-10-2007 07:01 PM
7 pin connector adapter gparker Electrical - Systems, Generators, Batteries & Solar 2 12-16-2006 06:11 PM
