Old 03-19-2018, 03:32 PM   #1
1965 26' Overlander
New Orleans , Louisiana
'65 Airstreams, Stabilizer
Looking at two different '65 Airstreams; a 26' and 28'. Wanting to get a stabilizer bar/hitch for smooth towing. The Airstreams are around 4,000 lbs. I'll be pulling which ever one I buy with a 2013 Yukon Denali XL (8,100 lbs towing capacity.). I'd prefer not to spend $2500 on a top of the line set up. What suggestions do you have? Any sub $500 or $250 options that I won't regret?
I think they both would have a 2" ball. What would be the dimensions of the frame? Saw one option that required I provide the dimensions of the frame I'd be attaching it to.
Thanks for your help.
McleishNOLA is offline   Reply With Quote
Old 03-19-2018, 03:37 PM   #2
2007 22' International CCD
Have a look at Equal-Iizer or Dual Cam setups. With that heavy a truck they would probably work ok. I tow with a 1/2 ton Toyota Tacoma, and I need to add a lot of hitch stability to pull it off. A-B testing on the same rout convinced me of that..
Or, alternatively, look for a USED Hensley Manufacturing or ProPride hitch system at a much lower cost. Rebuilding one to like-new condition is not that hard...
Old 03-19-2018, 08:08 PM   #3
1965 26' Overlander
Thanks for the suggestions. Ebay or Craigslist if looking for a used Hensley or ProPride?
Old 03-19-2018, 09:57 PM   #4
1965 26' Overlander
How about an Anderson Hitch? https://andersenhitches.com/Catalog/...ion-hitch.aspx
Old 03-19-2018, 10:06 PM   #5
Anyplace you can find one, also check AS classified part of this forum. Don’t skimp on a hitch.
Two trips with a not-so-good hitch system, I decided a serious upgrade was necessary for my family’s safety. I could afford a better hitch. The better truck was out of reach, unfortunately.
Old 03-20-2018, 12:34 AM   #6
1980 24' Caravelle
vallejo , California
welcome to the formuns, yes both of those models use a 2'' ball. i have used a reese.an equalize and an e-z lift. all worked well. many report good results with the blue oz. the hensly and PP hitchs are good, but for those of us who boondock, they are not to good; we loose to much ground-clearance. if you will stay on paved roads or good gravel roads the hensly/PP can't be beat if you can afford them. kurt
ke6gkv is offline   Reply With Quote
Old 03-20-2018, 05:51 AM   #7
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
My Equalizer has served me well for 9 years. I chose it over the Reese for several reasons after lots of researching the topic back in the day. Sorry I don't remember the specifics now. Good product and good service if you have questions on the install and set up. The company has lots of videos on Youtube about the hitch and how to set it up.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
steering stabilizer ALANSD Mechanics Corner - Engines, Transmission & More... 34 04-01-2014 09:48 AM
New Airstreams vs old Airstreams Denis4x4 Forum Admin, News and Member Account Info 10 07-18-2013 06:49 AM
The Airstreams are Coming!! The Airstreams are Coming!! j54mark Airstream "In the News" 7 07-07-2005 07:06 AM
Steering Stabilizer rdm Mechanics Corner - Engines, Transmission & More... 2 09-17-2004 06:03 PM
steering stabilizer cooperhawk Mechanics Corner - Engines, Transmission & More... 3 07-17-2003 04:37 PM
