Old 01-21-2013, 08:15 AM   #1
rowdyATX's Avatar
1956 26' Cruiser/Overlander
1961 28' Ambassador
'59 Flying Cloud - trailer jacks and spare tire
In preparing my trailer, I'm considering mounting 2 jacks on the front and 2 on the rear of the trailer.
I'm also thinking a out mounting a spare tire mount up near the hitch.
I don't want to overkill my trailer with jacks if not necessary but I'd like it to be a stable camper. I'd appreciate any thoughts?
rowdyATX is offline   Reply With Quote
Old 01-21-2013, 08:18 AM   #2
Stabilizing jacks are a must.
Carrying a spare, under the front, is the way to go, as thousands of others have.
Old 01-21-2013, 09:07 AM   #3
rowdyATX's Avatar
1961 28' Ambassador
Thank you!Any RV shops around central Texas?
Old 01-21-2013, 09:09 AM   #4
rowdyATX's Avatar
1961 28' Ambassador
Do you have a photo of a spare tire mounted under the front?
Old 01-21-2013, 10:19 AM   #5
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Rowdy,
Congratulations on your new trailer! Is this the on that the guy had in San Angelo that was off the frame?
To answer your question, Texas RV Supply in San Antonio or Top's vintage trailers in Harker Heights Vintage traveler's restoration in Johnson City are the only shops in Central Texas I would reccomend.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 01-21-2013, 10:20 AM   #6
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
All three shops have websites
Bruce
Old 01-21-2013, 11:50 AM   #7
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
I'm working out the details of putting a new split AC in the Safari. It will, because the compressor will on the A frame tongue, require the tire carrier be under the frame. Instead of the usual tire gizmo commercially made ($$$), I am working on using a tire assembly off a newer F-150. A simple cable, that is cranked, will allow the tire to be pulled up tight to the trailer or lowered to the ground for removal. Ford has been using this system for 20+ years so it's proven, it's just a matter of making the mods to fit the trailer. Sorry once a hotrodder always a hotrodder. Hard to beat cheap and dependable.
goshawks00 is offline   Reply With Quote
Old 01-21-2013, 01:23 PM   #8
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
goshawks-
When you get that done please post. It is not so much the $$$ for the carrier, it is the laying on the ground and wrestleing that tire into the carrier and then putting it up and putting the holding pins in.
Bruce
Old 01-21-2013, 08:57 PM   #9
rowdyATX's Avatar
1961 28' Ambassador
Thanks for your info, Andy and everyone else.
As I have taken a step back to research and come up with a plan, in order to get the trailer in shape I am going to need to mount a couple of holding tanks on the trailer, install a new front jack and also, as you mentioned, stabilizer jacks. Most of the jacks I see are scissor jacks and may be overkill for by 22ft trailer.
Can you advise me on the tanks and stabilizers??
Thank you!
Rowdy
