Old 08-10-2013, 04:16 PM   #1
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
55 mph safe?
So I drove my new truck an hour up interstate 59 north with the fam to a drive in movie theatre last night - great fun although kids are still a tad you for a movie starting at 8am outdoors
Anyway - I drove at 62-65mph on the 70mph highway - that wasn't bad really - people were passing of course
But at 55 it would be a bit crazy people passing at 75-85 mph often?
Clearly there are control and other safety and fuel efficiency benefits of this speed - but on such highways can it be actually unsafe?
What speed do you tow in such highways and perhaps share point of view and experience - thanks
PharmGeek is offline   Reply With Quote
Old 08-10-2013, 04:16 PM   #2
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
At the drive in
Old 08-10-2013, 04:22 PM   #3
interstateflyer's Avatar
2017 25' International
Los Osos , California
55-65.
Closer to 55 if temps are over 90F on the flats.
55 in mountains. As a general rule of thumb....downhill shouldn't exceed uphill speed.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 08-10-2013, 05:15 PM   #4
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
When you are towing, there is this big object hiding the truck from those coming up from behind. Most of the big rigs are being governed to sub 65 speeds for fuel savings. So the public is being conditioned to larger vehicles running slower.
Your pickup or car should, unless the flashers are on to warn folks you are slow, be running close to the speed limit under "normal" weather conditions.
Old 08-10-2013, 05:38 PM   #5
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
"Your pickup or car should, unless the flashers are on to warn folks you are slow, be running close to the speed limit under "normal" weather conditions."
Coming back from TEXAS to CALIFORNIA a lot of the time the speed limit is 80mph - running close to the speed limit pulling a 31' trailer? No way Jose!
Silver Hawk is offline   Reply With Quote
Old 08-10-2013, 05:48 PM   #6
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I think he may have meant the pickup or car by itself...
Old 08-10-2013, 05:50 PM   #7
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
My reading of the post was that the cars are conditioned to react to say an AS towing slower fine - but without a trailer run near or at the speed limit..
Correct switz?
Old 08-10-2013, 05:54 PM   #8
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I tow about 60 and most folks end up passing me. I really don't consider it unsafe since I consider myself readily observable to most folks coming up behind me. I really believe in leaving myself the ability to compensate if adversity presents itself. That's anything from having to make an evasive maneuver, being able to stop if something happens in front of me on the road, or perhaps a blown tire. You have a lot of momentum with that trailer in tow and your vehicle towing is not going to react the same as it does when you are driving it solo.
I had an 18 wheeler in front of me blow two tires. I successfully dodged the flying rubber while towing without any consequences. It scared the heck out me since I just reacted. At the time I was doing 55. I guarantee you that adding 15 mph to my speed at the time would have negated my reaction time and I would have had some considerable damage inflicted by those large hunks of the tire that that truck was peeling off.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-10-2013, 06:04 PM   #9
dznf0g's Avatar
Oswego , Illinois
-Rich-
Old 08-10-2013, 06:05 PM   #10
1981 31' Excella II
New Market , Alabama
With the P3 hitch you should be fine at 70 on flat interstate. Uncontrolled sway and following too close will mess you up. The sway is a non issue with the hitch. I can't drive 55. In the mountains or curvy narrow two lanes then that is different. Learn what your rig is capable of. Make a few quick lane changes and hard stops so you know how the thing will handle at the limits of the envelope. If you are young and have decent reflexes you should not have to drive 55. Don't go out and hit the speed limiter on your truck the first day while pulling the trailer. Work up to it and get comfortable. The Airstream is going to handle better than just about anything out there.
I usually stay around 65. Sometimes on flat FL interstate I will hit 70. I also tend to speed up going down hills so I don't have to put my foot in it to get up the next hill. Momentum is your friend an enemy.
Perry
Old 08-10-2013, 06:50 PM   #11
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Originally Posted by perryg114 View Post
With the P3 hitch you should be fine at 70...
DW has a great saying that seems applicable here. "Just because you can doesn't mean you should."
Even with the 3P - I wouldn't recommend much above 60. It's not so much the forward motion as it is the hard stops when some dimwit wants to save 30 seconds and jumps in front of you from your blind side...
You're all adults. Do as you see fit. I'd vote for keeping it slow and safe Brits camping after all - not a night in Times Square :-)
SteveSueMac is online now   Reply With Quote
Old 08-10-2013, 06:58 PM   #12
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
With my ProPride I am usually at 65 which is the tire limit speed for trailer tires. I also use a pressure monitor to keep track of tire temps and pressure.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 08-10-2013, 07:15 PM   #13
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I drive posted speed limits and outside of the big rigs I am usually the slowest thing on the road, and that is without towing. If I am towing I will slow it down a bit more to give me more reaction time. If traffic is getting too heavy on the interstates I will get off and drive the alternate US highways if they are available. I travel primarily east of the Mississippi so YMMV.
Aaron
WBCCI #XXXX AIR #2495
Old 08-10-2013, 07:33 PM   #14
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
1800-2000 RPM, 60-63mph. Find the engines sweet spot.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Putting a safe in 2012 27' FB Int Jordanparson General Interior Topics 5 02-24-2012 10:33 PM
Floor safe info vonprum General Motorhome Topics 14 01-03-2012 02:38 PM
Be safe in 2011! kevin242 Tires 5 05-19-2011 12:27 PM
Nice, safe campground near New Orleans AUTAILGATER On The Road... 4 01-21-2011 10:34 PM
