Old 11-21-2013, 09:00 AM   #169
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I actually obey the posted limit on ramps because you can actually get a speeding ticket for speeding on the ramp...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-21-2013, 09:04 AM   #170
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Most signs on ramps are advisory signs, not speed limit signs. If they are speed limit signs, yes, I do obey them.
John W. Irwin
WBCCI #9632
Old 11-21-2013, 09:07 AM   #171
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Since towing is much more complex than driving an automobile, and anything that goes wrong takes longer to correct, I always adher to the exit ramp posted speeds. In any case why not do it? You will only be on the ramp a minute or so. I cannot remember anytime that the posted speed was too fast to exit comfortably with the trailer.
Ken
Old 11-21-2013, 09:34 AM   #172
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Originally Posted by IanPoulin View Post
Sorry, no - I am asking how realistic these posted signs are for individuals towing their airstreams; do they find they need to be bang on target to the reccommendation or what level of wiggle room they find they have.
Ian
Ok, thanks Ian.
The limits are set for those vehicles with a high centre of gravity (COG) and a propensity for toppling over; some speed limit signs are accompanied by a yellow graphic sign to warn truckers that if they fail to heed the limit, they may well tip over.
Towing a relatively low COG Airstream, though, I think you have a bit of wiggle room in there. Coming from the UK where there are few off ramp speed limits (mostly because the turns are not that tight), I was surprised how low those limits here are set. Personally I try to judge it to be on or marginally over the limit but am prepared to knock off a bit more speed if things are getting a bit hairy.
There's a bad one off Ontario 401, heading west and west of London, as you turn onto Colonel Talbot Road (co-incidentally to go to CanAm RV). There's very little straight ramp before you hit the bend going right and it's quite tight. The real issue is the slightly adverse camber, which adds to the fun. It says 40Km/hr and I make sure I'm doing absolutely no more than that!
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 11-21-2013, 10:09 AM   #173
Len and Jeanne
Len n Jeanne's Avatar
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley , British Columbia
I don't think you can go wrong following the speed limit, unless the driving conditions are so rotten that slower is better.
Len n Jeanne is offline   Reply With Quote
Old 11-21-2013, 10:43 AM   #174
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Our posted caution/suggested ramp speed signs are mostly I think pretty reasonable...the ones that say 25mph here in my area are ones really quite sharp of a turn...The ones I use frequently that interchange say 459 with 20/59 are more often posted yellow at 45mph....and that is about what I found myself pulling through them...maybe 50 - it is a very very mild turn, barely can call it a turn really...
I suspect that for ones posted as 25mph, going for even in an airstream would be pushing it...
In my daily driver, my car, I go through that ramp from 20/59 to 459 most every time at 65-70mph....
PharmGeek is offline   Reply With Quote
Old 11-21-2013, 12:18 PM   #175
m.hony's Avatar
2013 30' Classic
There is only one circumstance under which I speed-
Those annoying stretches of road that have speed limit sign, advisory sign, speed limit sign...
You don't know what to do...
TAC #MS-10
Airforums #70955
Old 11-21-2013, 12:25 PM   #176
m.hony's Avatar
2013 30' Classic
I obey speed limits even in work zones where no work is taking place-
Like for several years Highway 82 in Alabama from the Mississippi line to Tuscaloosa and on Interstate 20/59 from Tuscaloosa to Birmingham had work zone speed limit signs, but no road work.
You can still get a double fine...
TAC #MS-10
Airforums #70955
Old 11-22-2013, 06:04 AM   #177
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
When towing a utility trailer or the Airstream I've always found that it is best to heed the recommended speed on the exit ramps. Some of those can quickly get pretty steep/sharp and I don't want to be hitting the brakes in a curve.
When driving a car you can usually do about 10 mph over the recommended speed and not have any troubles.
Normally the recommended speeds seem pretty reasonable because the road departments are trying to warn the driver of adverse road condition or a section of road when the driver should take a bit more caution.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 11-22-2013, 06:32 AM   #178
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
When 'streamin, curves/turns I try to use the "posted" ramp speed in unfamiliar places.
There is a phenomenon referred to as "speed soak".... It happens especially when transitioning from very high speeds to slower.
If after a long span of driving, you have ever felt "oops, I misjudged my speed and came in "too hot", you have experienced "speed soak".... Perhaps to some degree.
One thing I know from flying, boating, motorcycling...and other sports, "the slower I am going when I hit something, the lest it will hurt my pride, body, possessions and pocket book.
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-22-2013, 07:04 AM   #179
IanPoulin's Avatar
Aldie , Virginia
In computer programming/systems environment the term is ohnosecond - that being the variable measurement of time between hitting the return key and realizing fully what you just did.
2011 Airstream International Serenity 28'
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 11-26-2013, 04:07 PM   #180
Streamliner
Markj55's Avatar
2006 19' Safari SE
Santee , California
Also know as drunk..... Time to put this thread to bed?
Markj55 is offline   Reply With Quote
Old 11-26-2013, 04:57 PM   #181
Will_Brule's Avatar
2014 25' FB Flying Cloud
Palestine , Texas
I usually adhere to the posting. I don't think it really slows me down much. If I were in a hurry, I would travel by Corvette or airplane.
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
I've spent my life leading folks astray."
Will_Brule is offline   Reply With Quote
Old 11-26-2013, 05:11 PM   #182
m.hony's Avatar
2013 30' Classic
It really doesn't cost much time to drive the speed limit.
5-10 minutes on a short trip-
1 hour in a full day of driving-
It really isn't that big of a deal-
A small price to pay for fuel savings and extra safety-
TAC #MS-10
Airforums #70955
Putting a safe in 2012 27' FB Int Jordanparson General Interior Topics 5 02-24-2012 10:33 PM
Floor safe info vonprum General Motorhome Topics 14 01-03-2012 02:38 PM
Be safe in 2011! kevin242 Tires 5 05-19-2011 12:27 PM
Nice, safe campground near New Orleans AUTAILGATER On The Road... 4 01-21-2011 10:34 PM
