Old 04-24-2015, 03:16 PM   #15
Longboard6's Avatar
2015 23' FB Flying Cloud
Sacramento , California
Gee, you bring up a point I had not considered. How did you come by this info? I'm do for the 90K service this summer. Is your info common knowledge with the Toyota service people? Thanks again,
Longboard6
Longboard6 is offline   Reply With Quote
Old 04-24-2015, 05:29 PM   #16
Longboard6's Avatar
I checked 90K service on my 4Runner and found they replace timing belt. I will check on the water pump issue as well as idler cable (which I believe is loose). Thanks for cluing me in on this aspect.
Old 04-24-2015, 07:08 PM   #17
richw46's Avatar
Lexington , Kentucky
Originally Posted by KJRitchie View Post
Toyota recommends 90k or a certain number of years which ever comes first. If the timing belt fails the engine is ruined. The Tundra has a different design and doesn't require the same maintenance.
Kelvin
The 4.7L V8 is an interference engine so you don't want to take a chance on a belt breaking. 90K or 9 years, whichever comes first. It would definitely be expensive. The 4.7L was used in the 03-05 4Runner. Not sure if the 06 had a V8. The Tundra uses the same 4.7L. They are all interference engines so you should follow the required maintenance schedule. Please see attachment for the 2006 Tundra 4.7L V8
You can use the tool at the Gates site to see if your engine is interference.
Auto Parts Interchange | Gates Corporation
Select the application button, then choose Passenger cars and Light Trucks and fill in the rest of the boxes for your vehicle
Name:	tundra 2006 V8.jpg
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Using a 4Runner to tow a Flying Cloud 23FB tschabarum Towing, Tow Vehicles & Hitches 32 03-04-2013 06:08 PM
Can a 4Runner V6 tow a Safari? safarimawn Tow Vehicles 14 02-19-2010 12:30 PM
Tow Mirror for 4Runner lewisj Tow Vehicles 10 04-07-2009 11:13 AM
Side Mirrors for 4Runner kitchenclose Tow Vehicles 6 01-21-2007 06:26 PM
4Runner tow vehicle inflt 1997 - 2004 Bambi 24 05-18-2005 10:15 AM
