Old 12-21-2015, 08:52 AM   #1
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
3P hitch - about to purchase!
While I have been very happy with my Equal-i-zer hitch, the time has come to upgrade, for the following reasons:
A. We have a big variance in our load depending where we are going and I am sick of constantly moving L-brackets and washers...
B. The current WD does not throw as much weight forward as I would like. More specifically, with the adjustments available I am either pushing too much forward or not enough!!!
C. Just want better control of the trailer. We tow a lot up and down mountains and I want a more secure set up, particularly as we sometimes end up in snow...
So with that being said, I have the following questions:
1. Our AS is parked on a driveway that has a slope front to back. this means when hitching/unhitching the TV is at a different angle of attack to the AS. Will the be an issue with he 3P hitch?
2. When backing on to the driveway I have to cut a tight turn, how does the reversing with a 3P hitch compare to a regular ball hitch? Will I be able to still cut an aggressive turn?
3. The 3P looks heavy, what kind of additional tongue weight am I looking at here?
4. Any idea what the distance between the jack on the AS and the end of the hitch will be? It would be nice if I could finally open the trunk on my Expedition....
Thanks!
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 12-21-2015, 09:04 AM   #2
Echelon73's Avatar
2010 30' Flying Cloud
Mocksville , North Carolina
See my answers below...
You will have to make sure the angle on the "stinger" matches the angle on the receiver box at the trailer when your trailer is at an angle like this. It is a little more tricky than level ground, depending on how steep the slope is, but once you get the hang of it not too bad. I have only run into one situation where this created a real pain. I had the distribution bars touching the ground to get the trailer level. If I ever have this situation again I will just put some blocks under the trailer tires before unhitching to reduce the effect of the slope, but this really is not a common problem for me.
You should have no problems backing it. Once you get the hang of the difference in backing it will become natural to you. I picked up on it quickly. Backing into tight spots has been no different for me than before I had the ProPride.
Someone else may be able to give exact numbers, but I would guess about 100 pounds more than a conventional hitch.
I do not have exact measurements, but I can open my tailgate now. Everyone else I know says the same of theirs. It is a nice bonus!
Thanks!
Echelon73 is offline   Reply With Quote
Old 12-21-2015, 09:06 AM   #3
Gsmblue's Avatar
Bend , Oregon
Thanks for the swift response!
on point 2, can you explain how the turning while backing up is different?
Once I get through this cup of coffee I will call up and place my order
Old 12-21-2015, 09:07 AM   #4
dznf0g's Avatar
Oswego , Illinois
HAHA adds about 100#s, IIRC...but a PP is a bit lighter. I'd guess about 75#s over an EQ (I used to have on, but can't remember the exact weight.
-Rich-
Old 12-21-2015, 09:14 AM   #5
Echelon73's Avatar
The hitch has to get settled to the direction you are backing. There is a slight delay to do this when changing directions. I just start turning the truck a little early to get the hitch "set" for the direction I am backing. Once it is set in the direction you are backing it responds like any other trailer. It is difficult to explain, but pretty easy to master after using it once or twice.
Old 12-21-2015, 09:17 AM   #6
Gsmblue's Avatar
Bend , Oregon
Thanks Echelon73, that makes total sense to me actually!
We are heading to BC on Boxing day, hoping I can take delivery of the 3P in time... It will also be the first trip with the wife driving the rig...
Old 12-21-2015, 09:23 AM   #7
Gsmblue's Avatar
Bend , Oregon
Just spoke with Sean, order being placed, but not going to get it in time for the trip to BC
Old 12-21-2015, 09:23 AM   #8
Echelon73's Avatar
Having a backup camera really helps for hitching. I also took about an 18" piece of wood and fashioned it to fit in the receiver box on the trailer. I have it designed so it projects the angle (up and down/ side to side) of the receiver box. This helps me line up. When I get close I just remove the piece of wood and then back up the rest of the way. It is not bad. On level ground backing straight in I do not even use the piece of wood anymore. The hitch makes the whole rig so much more stable going down the road. My truck probably tracks better towing the Airstream than it does when it is not attached. It is like having a really long wheelbase. It may not be for everyone, but I like mine and would not go back to a conventional hitch.
Old 12-21-2015, 09:27 AM   #9
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
1. You must have the stinger and the hitch head at the same level (relative to each other) to back in. You do this by moving the weight distribution jacks up or down to change the angle of the head. I think it helps to set the head about a 1/4" lower than the stinger (but still on the same level to each other) because the hitch head is reacting at it's lowest point of freeplay, it will lift as you back in. I also give the hitch head box and stinger a shot of CorrosionX lube each time to reduce friction and provide rust protection. Hitching ease is all about alignment of the hitch head and stinger, it will back in every time (if misaligned don't waste your time trying to force it in). To disengage the hitch, just before hooking up I use a tape measure to check the distance of my truck's front and rear wheel wells to the ground. To disconnect, after taking loose the connections and releasing the w.d. I lower/raise the tongue jack until I have those same measurements at the wheel well. Drive away every time without hanging up.
2. No problem, but you still can't go sharper than the hitch rotates or you will bend something.
3. Figure 100 lbs heavier overall, but the heavy weight is in the hitch head and w.d. system, which remains on the trailer tongue. You only have to take out the stinger from the truck. And when camping, unhook the hitch assembly and pull ahead about a foot, then slide the stinger back into the hitch head and leave it there. Minimum lifting.
4. I don't know about the Expedition, but there is plenty of room to lower the tail gate of our two pickups.
Doug and Cheryl
Old 12-21-2015, 09:27 AM   #10
Gsmblue's Avatar
Bend , Oregon
Again, thanks!
We do have a back up camera, which is so incredibly useful.
Order placed. Just wish I did it last week, no chance of getting it in time for the trip as we leave on Saturday and Sean thinks it will arrive with us on Monday.
Old 12-21-2015, 09:44 AM   #11
Gsmblue's Avatar
Bend , Oregon
Major props to Sean at ProPride. He just called me to let me know that he is going to get the hitch out to me today and providing 1400lb bars instead of 1000lb bars as that works better with 1/2 ton set ups. I may be up and running for this trip at the weekend!!!
So far I am blown away with the customer service!
Old 12-21-2015, 10:21 AM   #12
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
Love our PP! Can't say enough good stuff about Sean and his personal customer service!
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 12-21-2015, 10:35 AM   #13
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I think you'll find that the 1400# bars are better. You can dial in exactly how much you need - having the 1400s doesn't meant you'll be moving that much - but nice to have the ability to push as much to the front axle of your TV as you need. I started with the 1000# bars and recently changed to the 1400#ers and some adjustments by Colonial to the original installation. Much better!!!
SteveSueMac is online now   Reply With Quote
Old 12-21-2015, 10:53 AM   #14
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
3P or Blue Ox
We're pulling an AS 27 with a Ram 2500 diesel. When we bought the AS, we asked the AS dealer "What hitch to buy?" They recommended a Blue Ox Sway Pro, which we bought for approx. $600 with free shipping. All I can say is "It works! I don't know how it could be any better."
I first learned of Pro Pride & its 3P hitch from this stream of comments. I went to the Pro Pride website & learned that the 3P costs approx. $2,400 plus several $100 for shipping.
Query: What extra does the 3P provide over a Sway Pro for the additional $2,000? Mind you, I'm not commenting about the quality of a 3P --- I just don't understand its advantages over a Sway Pro. What am I not understanding?
Rgentum is offline   Reply With Quote
First Airstream purchase... need purchase tips, please. movin-in Buyer Guidelines 8 06-03-2010 05:09 PM
Possible purchase need purchase/deposit/title forms LiLNomad Dollars & Cents 5 05-28-2010 12:59 PM
Reese hitch or Equalizer hitch? mouth012006 Hitches, Couplers & Balls 4 03-04-2010 07:31 PM
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 04:40 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
