Old 12-25-2015, 01:38 PM   #43
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I have never "immobilized " the PP when backing.. And when backing up my nearly 30 degree offset incline has caused no problem.
I figure if it won't back up, it won't stay put when braking either....only 3 years with ours and dozens of "landings"...
Now, the "respond" of the trailer is "delayed" when backing, but you soon get used to it...
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-25-2015, 01:45 PM   #44
2007 22' International CCD
Originally Posted by Llando88 View Post
Can you post a picture of this?
Never done it. I read that it can be done. I do my own work where possible, and the dealer I go to does not need me to pull the hitch. I wouldn't go to him if he did.
KE4GNK/AE
Old 12-25-2015, 01:50 PM   #45
3P hitch - about to purchase!
Originally Posted by rmkrum View Post
Just be sure to immobilize the ProPride swivel mechanism before attempting to back up. A couple locking pliers should do it.
The above is only applicable if you build and use a ball adapter for the end of the normal stinger. You don't want swiveling on the normal PP or Hensley pivot if you are pivoting on the ball adapter gimmick. Somewhere in the forums the lock the pivot bit was mentioned. Hensley can use a screwdriver the ProPride needs locking pliers. I don't need to do this--I maneuver the trailer at the dealer by letting them use my TV to do it. Or they use their truck and my stinger. The issue occurs when they try to use a forklift with a ball mounted on a tine.
KE4GNK/AE
Old 12-25-2015, 05:50 PM   #46
Llando88's Avatar
2016 30' Flying Cloud
Ok thanks for the clarification.
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
ďCharacter is doing the right thing when nobodyís looking. There are too many people who think that the only thing thatís right is to get by, and the only thing thatís wrong is to get caught.Ē - J.C. Watts Jr.
Llando88 is offline   Reply With Quote
Old 02-01-2016, 08:48 PM   #47
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Right, just back from our first trip using the 3P. here are my thoughts..
1. Towing was fine. no drama. a little better than my previous hitch.
2. Backing up was easer. A more natural feeling cut as I backed up. Managed to hit the spot perfect first time, the wife even noticed...
3. Installation - it is fickle. take time, go slow and careful.
4. Unhitching, it is a skill. Watch for the coupler tension on the ball.
5. Ground clearance, although it looked low, I had no problems. In fact, it was easier to back up my driveway incline.
6. Managed to dial in the WD perfectly on the scales. 7.5inches on the jacks and I was true as a die.
7. Safety chains needed extending by 5 links and a clevice.
8. 7-way cable just about reached, could do with an extra few inches...
That's it, that's all
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 02-01-2016, 09:18 PM   #48
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Sometimes it is really easy with good info...
Channing
WBCCI# 30676
Old 02-01-2016, 09:29 PM   #49
Starstream's Avatar
Spring , Texas
Originally Posted by Gsmblue View Post
4. Any idea what the distance between the jack on the AS and the end of the hitch will be? It would be nice if I could finally open the trunk on my Expedition....
The distance will very a little between years, models, and where you hitch is located on the expedition.
We have full access to the lift gate with The PP and AS hooked up.
Starstream is offline   Reply With Quote
Old 02-01-2016, 09:36 PM   #50
Ditto us. Prior hitch (Husky) was too close. Now we can easily open tailgate on the Tacoma.
KE4GNK/AE
Old 02-01-2016, 10:00 PM   #51
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Here is a photo showing the tongue weight of a '06 Safari 25 FB with a PP hitch.
I see that 1050# Dennis 4x4. Yep. I have a 2006 25' A and it is 990# but listed as 860# as per the CAT scale. True weight is important and one reason people should make sure they tow with a vehicle capable of towing the weight both in cargo/payload figure and in pulling ability.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 02-02-2016, 04:50 AM   #52
GLCMRANGER - Sue
2016 25' International
Littlestown , Pennsylvania
Gamble: I just ordered the 3P for April delivery on my TT. Sean (at Propride) recommended an extension kit (which included chain links, 7-way plug extension, etc) since he said most Airstreams needed them with my TV (Tundra). You might consider ordering one on their website.
glcmranger is offline   Reply With Quote
Old 02-02-2016, 05:53 AM   #53
Echelon73's Avatar
2010 30' Flying Cloud
Mocksville , North Carolina
I was able to loosen the tank cover a little and then get a few extra inches of cord running towards the vehicle. Then I just tightened the tank cover back down. I really do not have any extra cord, but it is enough that I do not plan on adding an extension. You may be able to do this with yours. I did have to add about five links to each safety chain though.
Echelon73 is offline   Reply With Quote
Old 02-02-2016, 06:25 AM   #54
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
Originally Posted by rodsterinfl View Post
I have a 2006 25' A and it is 990# but listed as 860# as per the CAT scale. True weight is important...
Would you elaborate more on the differences between these two weights. How was the 900 lb weight determined and what technique did you use to get the CAT scale weight?
Greg
greghoro is offline   Reply With Quote
Old 03-01-2016, 02:17 PM   #55
Gsmblue's Avatar
Bend , Oregon
I didn't want to clog up the 3p users thread so going back to my thread
I installed the hitch with the plates down with 2 holes above the hitch receiver shank and no washers on the pin. When I had the jacks wound up to ~7.5inches I did not have WD and the nose of the trailer was high about 1.5inches higher than the tail..
I dropped the shank down so only 1 hole was visible, wound the jacks to about 7.5 inches, have MUCH better WD but now the nose is lower than the tail by 1inch!
I think I need to play a little with the washers on the pin/rivet bit, but not sure what direction I should go in and whether I should have the hitch shank set with 1 hole visible or 2... any advise would be appreciated.
This is all made tricky by the fact I never, NEVER seem to have a level place to do this..
The attached pic is how it is set up now, nose a little low.
Name:	nose 2cm low.jpg
Old 03-01-2016, 02:20 PM   #56
Gsmblue's Avatar
Bend , Oregon
I was thinking maybe I need to raise the shank back to the 2 holes visible position and insert a washer, maybe?
First Airstream purchase... need purchase tips, please. movin-in Buyer Guidelines 8 06-03-2010 05:09 PM
Possible purchase need purchase/deposit/title forms LiLNomad Dollars & Cents 5 05-28-2010 12:59 PM
Reese hitch or Equalizer hitch? mouth012006 Hitches, Couplers & Balls 4 03-04-2010 07:31 PM
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 04:40 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
