Old 12-22-2015, 02:40 PM   #29
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Rob,
From what I can tell, there are a few subtle difference between the 2 designs. The 2 that matter to me are:
1. 3P does not need holes drilled into the AS frame...
2. 3P has a wider angle of acceptance for the shank, so this should make it easier to hitch up.
I am sure others with more experience will be along shortly!!
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 12-22-2015, 03:13 PM   #30
2007 22' International CCD
To me, the pp hitch parts look stronger, and I also like the adjustable stinger. Not drilling holes in the A frame was a big plus. No bolts to shear off in case of excessive force.
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 12-22-2015, 03:24 PM   #31
dznf0g's Avatar
Oswego , Illinois
I got a haha used at a price I couldn't pass up. The lack of an adjustable stinger is the only flaw I have encountered. I got one of the few adjustable stingers for haha that Sean made up. Made the haha a different animal.
If I were buying new, it would be PP.
-Rich-
Old 12-23-2015, 05:56 AM   #32
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I also bought my HAHA used and it came with 1000# bars. The 1000# bars seem to work fine for throwing enough weight forward. I would think the heavier bars would just give a more harsh ride. I also have an adjustable stinger which is heavy but works fine.
Like Rich said above - if I bought new it would be the upgraded PP.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 12-23-2015, 06:06 AM   #33
dznf0g's Avatar
Oswego , Illinois
3P hitch - about to purchase!
I, too, have 1000pound bars and they are fine moving all the weight where I need it. And that's with 1050 receiver weight and the truck bed loaded with about 750 pounds and one passenger.
-Rich-
Old 12-23-2015, 08:46 AM   #34
Denis4x4's Avatar
Durango , Colorado
Here is a photo showing the tongue weight of a '06 Safari 25 FB with a PP hitch. The installation took about 4 hours. Probably half that time with a helper. I have the 1200# bars. Since I'm towing with a Grand Cherokee, I had the stinger sent with out the 5/8" receiver hole inorder to have it has close to the rear axle as possible. I'm a strong believer in getting accurate weights and find the numbers on the AS tags very misleading. Same goes for tongue weights.
If you don't go first class, your heirs will!
Denis4x4 is offline   Reply With Quote
Old 12-23-2015, 09:34 AM   #35
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Sean at ProPride recommended 1400# bars for our FC 25/Ram 1500 combo. We can get full restoration (measuring height) to our Ram's front axle even when trailer/truck loaded heavy (which we rarely do but has happened). The w.d. screw jacks allow easy adjustment for the load we have.
I recall Ron Gratz demonstrating the need for more w.d. tension when the w.d. bars are positioned further back from the receiver, as with the Hensley/ProPride. So the need to get the stinger as close as possible to the truck as well as larger w.d. bars than with many conventional hitches.
A soft ride for the Airstream should be a goal as well, but how might one measure it? Inland Andy from Inland Airstream says it's simple. Just stand on the hitch connection and bounce it a few times; should see a couple of inches of movement, if not the connection is too rigid. Sounds like a primitive approach to the question, maybe too simple but probably has merit.
So that's what I did, even with the ProPride 1400 lb bars and there is flexibility. Stuff doesn't get tossed around in the trailer and cabinet drawers and screws have never come undone. The ride, handling and braking of the combo is very good. It's a pleasure to drive, even on busy, windy interstates.
We'll settle for Sean's advice on the 1400 lb bars, Inland Andy's advice on how to check it for flexibility, and Andrew Thomson of Can-Am's advice for near full front restoration on our truck for best towing performance.
Doug and Cheryl
Old 12-23-2015, 04:58 PM   #36
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I cannot even imagine the ARROGANCE of a dealer telling someone that they wouldn't work on their trailer until the 3P was completely removed! While I have no reason to deal with Vogt RV, whoever owns it should get some feedback that this "policy" has now been made public to the Airstream community. So much for "customer service" from that dealership.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 12-23-2015, 06:09 PM   #37
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
That just don't make no sense.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 12-23-2015, 06:34 PM   #38
That would result in a cancellation of the appointment and me going elsewhere immediately. Won't put up with silliness.
KE4GNK/AE
Old 12-23-2015, 09:03 PM   #39
BoscoMN's Avatar
2015 19' Flying Cloud
2017 25' Flying Cloud
Rosemount , Minnesota
Thanks Doug for the info on Shorewood.
My only exposure to them had been that I started my wife's and my "let's look at a couple of RVs" by going out to Shorewood one Saturday. That ended our looking at anything that was not Airstream. Fortunately for our wallet/purse, that next week we found and purchased a very slightly used 2015 19' FC from a private party. We will be getting it out of storage for the first time in April. I have high hopes as a nerdy engineer and sometimes handyman to do the bulk of the work on the AS myself. I will be cautious in placing my trust with a dealer - thanks for the reminder.
BoscoMN is offline   Reply With Quote
Old 12-23-2015, 10:35 PM   #40
2016 30' Classic
Erie , Colorado
Making an adapter costs about $30. Basically a straight 2" extension sleeve and a hitch/ball lock piece and a couple of bolts. Put that on with the stinger in place and they shouldn't have any problem moving your trailer.
Mine looked similar to this one
http://www.airstreamclassifieds.com/...hitch-adapter/
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 12-23-2015, 11:16 PM   #41
Just be sure to immobilize the ProPride swivel mechanism before attempting to back up. A couple locking pliers should do it.
KE4GNK/AE
Old 12-25-2015, 12:40 PM   #42
Llando88's Avatar
2016 30' Flying Cloud
Can you post a picture of this?
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Llando88 is offline   Reply With Quote
First Airstream purchase... need purchase tips, please. movin-in Buyer Guidelines 8 06-03-2010 05:09 PM
Possible purchase need purchase/deposit/title forms LiLNomad Dollars & Cents 5 05-28-2010 12:59 PM
Reese hitch or Equalizer hitch? mouth012006 Hitches, Couplers & Balls 4 03-04-2010 07:31 PM
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 04:40 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
