Old 01-06-2019, 06:10 PM   #1
2019 25' International
Providence , Rhode Island
2nd hitch type in consideration, any feedback?
I'm not easily swayed by much, but I need some feedback as my attention has been turned.
My dealer (even though he doesn't carry Blue ox line) was asked about the Blue Ox I'm considering and I wanted to get their thoughts on the BXW 1000 vs 1003 as I was trying to find out if the hitch is truly underslung or not on the model I'm having built as there some says yes, others no...etc etc.
I agreed to field a call from the Airstream tech and is recommending a trekker hitch, specifically this one:
https://www.eaz-lift.com/product-pag...r-hitch-1000lb
The main thing that really turned my head to this is there is no chain counting, easy to put the bars in place, easy adjustment and dynamic sway control and disconnect on reverse.
While the Blue Ox can do all but the dynamic disconnect over 10 degrees, IMO the lack of chain counting and rolling cam is what I'm truly thinking is the game changer to switch to that brand.
They said it will be $700 ish including install labor .....done and done....I know I can buy it for around $470 ish.....add the labor and we're back to around $700.
My question to the group, does anyone have an opinion or experience with this hitch? I am really digging it, but want to see if there are any red flags or gotchas.
Sorry to continue to beat this to death, times getting short and I just want to be sure before I choose incorrectly.
Thank you,
Chris
kittmaster is offline   Reply With Quote
Old 01-06-2019, 06:42 PM   #2
2019 30' International
Pennsylvania , Pennsylvania
Don't know anything about that hitch, but it's setup looks similar to my Equalizer.
majorairhead is offline   Reply With Quote
Old 01-06-2019, 07:03 PM   #3
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
That hitch is a clone of the Equl-i-zer hitch. Most AS dealers sell the EQ and the BO. Many recommend the EQ. Fastway also markets an alternative to the EQ.
The BO is superior except that the EQ type hitchs provide a bit more ground clearance and as you say, they are easier to hookup.
However, the EQ style hitch is too stiff for the AS. There is also a recent thread about hitch head weld failures and the Trecker looks to have a similar welded head configuration. If you decide to purchase the Trecker hitch, take driveways, speedbumps, chuckholes and similar transitions at slow speed and with care to reduce the stress on the TV receiver and tongue brackets.
Note, that the BO weight distribution change is just a different link in the chain and a bit of paint or tape eliminates the link counting. The EQ style hitch needs the head tilt or bar bracket adjusted to tune weight distribution and sway control.
If you want an alternate hitch, consider the Reese Centerline with Dual Cam sway control.
Keep up your research. Pat
Old 01-06-2019, 07:16 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I have never seen a Trekker so I can not compare it with the BO which I have been using for a couple of years and around 50K miles of towing. I am very pleased with the BO and their customer support. The link counting is very easy to resolve. I put a piece of duct tape on the link that goes into the bracket. No counting and a very simple setup.
Bottom line: Pick the hitch that will perform the best for you and provide a safe and comfortable towing experience.
Richard
Old 01-06-2019, 10:53 PM   #5
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
I was disappointed with the Reese dual cam, it always felt like it was “hunting “ it’s way down the road.
Your opinion may vary...
sheriff1 is offline   Reply With Quote
Old 01-06-2019, 11:33 PM   #6
PKI
PKI's Avatar
Originally Posted by sheriff1 View Post
--snip -- it always felt like it was “hunting “ it’s way down the road. --snip --
Any idea why that might have been the case?
Old 01-07-2019, 03:44 AM   #7
r carl's Avatar
Lin , Ne
Must be it needs readjusted, mine does not do that.
Old 01-07-2019, 06:18 AM   #8
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I too have been happy with my Reese Dual Cam on both a 20' and 25'.
As far as counting chain links, I put zip ties on the links I use so they're easy to pick out.
2012 Dodge Durango Hemi/AWD
Old 01-07-2019, 10:18 AM   #9
2001 34' Limited S/O
Burleson , Texas
Hitch I like...Pro Pride
I am pulling a 34' with a slide out using a heavy half ton Nissan. While it is maybe bigger than most half tons adding the Pro Pride Hitch has made it the best pulling combo I have ever had and that includes a lot of 1 ton setups.
Worth every penny.
kipziprip is offline   Reply With Quote
Old 01-07-2019, 11:24 AM   #10
1994 34' Excella
Warren , Manitoba
Have a look at the Husky Centreline. Very similar to Eq, but with a built in sway control. I have used for 5 years and am very pleased with it. Company is excellent to work with if you have any problems. Very easy hitch to set up, as well.
WBCCI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 01-07-2019, 12:03 PM   #11
meandher
2019 30' Classic
Miami , Florida
Thank you,
Chris
I don't hear anybody talking about the Anderson I do understand there is a boycott going on, but I still believe their product is good
and lighter and easier to set up ,which is important at my age
anybody has one ( bought before the sacrilege?
Docv is offline   Reply With Quote
Old 01-07-2019, 12:26 PM   #12
WBCCI # 23456
2000 30' Excella
Greeneville , Tennessee
Boycott Shmoycott. I have an Anderson Hitch and don't like it, it has little to no WD. It is very good for sway control. I have Anderson Levelers, love them. They made a goofy blunder by scratching their initials on a rock. They shouldn't have done that but what's done is done. My $0.02.
jimfa440 is offline   Reply With Quote
Old 01-07-2019, 12:43 PM   #13
2018 33' Classic
Medway , Massachusetts
I have one I am not using and happy to sell it to you ($250 plus shipping). It does have the 3” size receiver (fits F250 with trailer package).
M
MAHofer is offline   Reply With Quote
Old 01-07-2019, 01:07 PM   #14
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Size...🤔
Thirteen posts and no mention of what trailer we are supposed to advise on.🤓
16 to 33' Size would make a difference...😘
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
2nd a/c failed for 2nd time Bgibbs Furnaces, Heaters, Fireplaces & Air Conditioning 15 01-02-2019 05:23 PM
Type 3 Glass Bar in a Type 2 Hinge rasmuw Windows & Screens 0 12-09-2013 10:18 PM
Under Consideration: 1970 Sovereign Int'l carolynhazel Trailer Values 19 04-01-2012 10:01 PM
What Type of Restoration is Your Type? ankornuta General Repair Forum 16 11-21-2005 04:13 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
