Originally Posted by 2airishuman
wow davidz71.....that is a nice job....and great pix......
it should fit a little better with that routed out....
how did you remove the small bit on the nk?
no secrets here......tell us more!
cheers
2air'
I took the center bracket and stinger to a machine shop locally and explained the problem. He took a few measurements and a few days later called to tell me the work was done. There is only about 1/32" between the bracket and the edge of the truck receiver when all are hooked up. I got the idea from a post on the Sunnybrook forum so I can't claim credit for this one.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
