Old 03-05-2018, 06:33 PM   #211
2018 25' Flying Cloud
Hillsboro , Oregon
Tsunami,
Can you list the part numbers for your Gen-Y and Equalizer? I have a gas 2017 F-250 Crew 4x4 and am about to pick up a 25FB. I want to copy your setup.
Jason
Roguegaston is offline   Reply With Quote
Old 03-05-2018, 07:32 PM   #212
Hillsboro , Oregon
Which Blue Ox would pair with a 2017 F250 gasser crew cab 4x4 and a 2018 FC 25FB? Drop shank and bars? Thanks!
Old 03-06-2018, 09:49 AM   #213
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Your right on the border line with the tongue weights of that model. We used the 750lb bars for our last 2014 FB 25' AS and they worked fine. The 1000lb bars are likely recommended by BO, as your weight may be ~900lbs+ when loaded; need to weigh the trailer tongue weight loaded to confirm. If you go with the 1000lb bars they will be stiff for awhile, but they do break-in. We have them with our 28' and our F250 4x4. I'm sure someone with a newer 25' and BO can confirm.
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 03-07-2018, 05:32 AM   #214
2016 28' Flying Cloud
Brandenburg , Kentucky
Tsunami,
Jason
Here’s the web link to the hitch I purchased. Best to call them to confirm the hitch shank size you want. I used my existing Equalizer hitch from my previous AS/truck set up. It bolted directly to the Gen-Y.
https://genyhitch.com/shop/weight-di...on-drop-hitch/
Tsunami-v2 is offline   Reply With Quote
Old 05-29-2018, 10:31 AM   #215
Damien
tot2learn's Avatar
2012 27' FB International
Lafayette , Colorado
Originally Posted by Tsunami-v2 View Post
With the new cap and Cargo Slide installed Friday, it sure changed the dynamics of the truck on the ride home from the installers garage. The ride felt smoother and quieter. With just over 1100 miles on the Odometer, we loaded the bed up with camping equipment and tools that we normally take the traveling and did all the measurements prior to installing the hitch. Got the Equalizer all dialed-in and we set out for a leisurely drive. First thing I noticed was that the Gen-Y Weight Distribution Torsion shank really works! We drove over several different types of roads, highway, secondary, and neighborhood. The Gen-Y definitely smoothed out the trailer feed back. Impressed with the F250 power and how the Exhaust Brake worked. We drove about 100 mile. Attached is photo of Gen-Y with Equalizer WD head attached. More to follow as we take a couple more short trips before heading out for a few months journey.
Tsunami-v2, What spring bars do you have on your Equal-i-zer hitch? 1000lbs?
tot2learn is offline   Reply With Quote
Old 05-29-2018, 11:30 AM   #216
Durango , Colorado
Tsunami, Now that you have a little time with this setup, how do you like it?
Do you feel confident that you are getting good sway control?
I have the ProPride hitch which eliminates sway and provides good Weight Distribution but it is a solid link between truck and trailer. The ProPride with my F-250 beats my Airstream to death on just slightly rough roads.
I would love to have a smoother ride on truck and trailer which I am sure the Gen-Y provides but I am worried about losing the sway control that the ProPride provides.
RVDreamer is offline   Reply With Quote
Old 05-29-2018, 01:14 PM   #217
2007 22' International CCD
RVDreamer,
I suspect the basic reason the AS is getting beat to death is the relatively stiff suspension on the F-250, more than the ProPride system causing an issue. Any WD hitch is going to be a fairly stiff connection between the two vehicles. The hitch does have some flex in it because of the WD bars, but they won't do much to soften the ride of the truck.
Have you looked at truck tire pressure and the actual rear axle loading on the truck? If the load on the truck is real light compared to the axle rating, this could be part of the issue--maybe adjust tire pressure to soften it a bit...based on inflation tables for the tires you are using.
Old 05-31-2018, 06:18 PM   #218
I love the combination of the Gen-Y and the Equalizer. I have had this Equalizer hitch for 12 years and never had any issues with sway. The Gen-Y is everything thats advertised. It smoothes out the shock transfer between TV and AS.
Has anyone driven the 2017 Ford Super Duty yet ? MOS Tow Vehicles 10 08-25-2016 02:13 PM
2017 Ford Super Duty paiceman Tow Vehicles 13 08-07-2016 08:37 PM
2017 Ford Super Duty Review pappy19 Tow Vehicles 15 03-06-2016 05:59 PM
New 2008 Ford Super Duty Pick Ups TomR Tow Vehicles 27 11-20-2006 11:06 PM
