Old 04-29-2014, 07:03 PM   #169
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Originally Posted by terryg View Post
Jim,
I've purchased DEF that meets Chrysler's spec. at our local Autozone. It sells for around $14.00 per 2.5 gal container w/spout.
Gmw Photos,
I agree with your recommendation to change the oil often. Chrysler says "up to 10,000 miles between oil changes. I've done two oil changes at 5000 mile intervals and am getting ready to do another one as I'm approaching 15,000 miles. A downside to the VM 3.0 engine is the cost of oil and filter. It uses a cartridge filter that sells anywhere from $45 to $60 currently. However, I have seen reports of some finding the filter online for as little as $30. The synthetic oil sells for around $9/qt. and the motor takes 8 quarts. My dealer is charging $99.00 for a oil/filter change and says he's doing it at a loss. The other local Chrysler dealer says he can't do it for less than $154 without losing money.
My only gripes so far with the Jeep are an annoying rattle in the overhead console (it's the sunglasses holder I think), and the poor Sirius/XM reception despite having the antenna replaced per a TSB addressing the issue. Oh yeah, I found out the hard way not to use the high capacity Diesel pumps with the large nozzles. It took less than a second to soak me with $0.29 cents worth of Diesel
Thank you Terry,
I have purchased DEF from my local Canadian Tire store for $20 in the same container. Although it is handy to use, I was just wondering if you had discovered availability when you were taking on fuel where it may be available in bulk and one could make one less trip to a store where he buys stuff he really doesn't need, which, according to my wife, is something that is only a male affliction.
Mobil1 ESP 5w30 meets the specifications for our diesels. I used the same oil in my 2008 Jeep Diesel and I used Mobil 1 in my previous Jeeps. The Synthetics really do seem to improve longevity but at a pretty steep price. Some guys on the Mercedes forums have figured out where to get both oil and filters on line at a much better price but I have forgotten where. I do my changes at 10,000 k since it's harder to forget.
I see that you have discovered that in some stations they put the truck nozzle on the outside and the car nozzle on the inside. They will eventually make improvements once more customers show up with Diesels. Jim
Jim Flower is offline   Reply With Quote
Old 04-29-2014, 07:10 PM   #170
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Smile Regenaration
Originally Posted by Jim Flower View Post
Hi Terry,
It looks like we have almost the same oil temps on a climb. My average mileage turned out to be 14.6 m/us gal. May be low due to the new engine. Also maybe because I was a little heavier than you. I was driving at 63 mph. Looks like it can only get better. Have you found an easy source for DEF? Jim
My GC did its first regeneration at 5000 miles. It now breaths easy and my fuel economy went up a lot.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 04-29-2014, 07:13 PM   #171
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Originally Posted by gmw photos View Post
Terry,
One would think that in time, the cost of the filters will come down. Hopefully.
As for the oil, I would be curious if Mobil 1 would meet the specs for this engine ? Do you have any knowledge of that ? I use it in my vehicles, and regularly buy it on sale in 5 qt containers at wally world for around $22.
As to the high flow nozzles at the truck stop....yes sir, I hear you. I often fuel the F350 there....and for sure I stand to the side and squeeze the lever with caution !
I used a coupon at the dealer they did the oil change and tire rotation for $29.95! Yes it's the proper oil and filter. The filter was $60 retail.
I chose America
Old 05-01-2014, 05:51 PM   #172
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
My GC came with 30k on the odometer but 16.8 hrs of running which would explain why the dealer had to do something to get the diesel exhaust filter unplugged. The Jeep sat in a holding facility near Detroit for 8 weeks during Feb., March, and April while the shipper tried to get his act together. The distance from the holding facility to the dealer was 5 hours tops. There seemed to be no exchange of information between the dealer and shipper. Since my driving to date has been 99% highway, I have seen no notification of regeneration taking place but it has gobbled up about 5 gallons of DEF. Man it's a beautiful engine. Jim
Old 05-01-2014, 05:54 PM   #173
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
One of these days, my iPad and I will learn how to work together. My previous post was in response to this quote. Jim
Old 05-01-2014, 06:00 PM   #174
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
The regen actually happened when my wife was driving and she thought something was wrong and called me. It's her daily driver maybe she drive 10 miles a day. So that would explain the regen
I chose America
Old 05-01-2014, 07:01 PM   #175
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
Yes, apparently they liked to be used. My wife put 25,000 k on her 2000 Jeep over a 10 year period. In November I had to replace the 10 year old tires which had no wear, due to age. When I gave her the Jeep in 2003 after I had used it for three years, it had 175,000 k on it. (Original tires and brakes) Being the good sport that I am, I did put new brakes and tires on it at that time just for her. In November we gave the Jeep with the new tires to my sister. Should keep her out of my hair for 10 years since she drives about the same amount as my wife. Jim
Old 05-01-2014, 07:07 PM   #176
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
You must be from the south. Up here in ohio they like to use salt and you may get 10 years top before it's rotted out
I chose America
Old 05-01-2014, 07:20 PM   #177
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
No. Canada. Ohio is south but our salt is about the same. I had to have the rocker panels replaced due to rust before we gave the Jeep to my sister. The 2000 Jeep was a replacement for the 1993 Jeep that I had given her but became a detriment to the neighbourhood as it rusted away in the driveway. The mechanics appear to out last the body. Jim
Old 05-05-2014, 07:08 AM   #178
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
During long hard pulls the coolant temp gauge will steadily climb to within 1 bar of the red zone and stay there. Likewise, the engine oil temp will climb to around 256 F and stay there.
This is the same experience I had on the test drive which is why this thread was started. So it would appear that the cooling issue was not fuel as suggested by the dealer and not a defective unit as suggested by others. This also confirms my suspicions as to why the dealer(s) ignored my questions challenging their explanation and my repeated requests to be put in contact with the regional Jeep rep.
The GC was my first choice and I was excited about it. If I was willing to go back to a truck, which I never will, the Dodge EcoDiesel would be my second choice. It is not an engine issue but an inadequate cooling design on the GC. I am confident the truck with tow mode and larger cooling system would be a great TV.
The rapid high heat and cooling cycles when towing are going to be the death of the engine. It is just a very unfortunate reality. I thought the more I test drove the GC the quicker the temp would rise which looking back I think it was due to heat soak on the engine and cooling system. This is too big an investment to run the risk in my book. Yes perhaps Jeep will honor the warranty to keep repairing the engine but who wants to go through that!
I did based on my serious concerns with the GC by the 2014 ML350 Bluetec and could not be more happier with it. We have towed Denver to Phoenix once and Denver to Breckenridge twice. The temp gage never moves. The engine is quiet and when stopping to refuel it is cool with no smells or temperature related crackling and popping.
On the GC I would roll the windows down and turn the interior heat to max high and make sure the AC is turned off as this might help a bit.
Best of wishes and happy towing.
2012FB is offline   Reply With Quote
Old 05-05-2014, 08:24 AM   #179
N/A , N/A
This would have been caught in the testing phase had Chrsyler implemented the SAE towing standards (Sadly only Toyota has). One of tests require the TV to go up a grade with trailer in tow, 2 passengers, AC on, maintain a certain speed, and not overheat.
rostam is offline   Reply With Quote
Old 05-05-2014, 11:56 AM   #180
K.C. , Missouri
If I were a betting person, I'd bet it was "caught" anyway, and they decided that it was worth the roll of the dice. A further bet would say that the vast majority of folks that buy GC's even with a diesel will not be towing, so Chyrsler figures their exposure to warranty claims because of this issue is very limited. It's all about risk management to them. Which is different than "making it right for all the users" of a given product line.
gmw photos is offline   Reply With Quote
Old 05-05-2014, 02:36 PM   #181
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
2014 Grand Cherokee Eco Diesel
Why all the second guessing jeep engineers. The engine still operates within design specs. It runs hotter, but so do gas engines these days. That's how they get the improved mpg. 2012fb's comments are only personal opinion.
Why post that you purchased a MB in the jeep thread?
I chose America
Old 05-05-2014, 02:52 PM   #182
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
. . . Why post that you purchased a MB in the jeep thread?
Because he was the original poster who started this thread on January 25, 2014 with the observation that the 2014 Grand Cherokee Eco Diesel Jeep he took for a test drive overheated going uphill. I appreciate his most recent post describing how he resolved that issue --by avoiding the jeep and purchasing a Mercedes that performed well for him. Too many threads in this Forum raise a problem and ask others for helpful advice, but never reveal the ultimate solution. For me its great to see a thread close that circle.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Aluma fiesta 2014 pdvasquez The Rally Zone 18 02-02-2014 05:41 AM
Used diesel for $20000 lpatkins Tow Vehicles 2 09-04-2011 02:26 PM
Airstream Land Yacht Diesel Repo Slide out Wash/dryer SAirstream Land Yacht Diesel R eBay Watch Airstreams on eBay 0 08-04-2011 07:10 PM
Diesel VS Propane Darkspeed LP Gas, Piping, Tanks & Regulators 22 07-09-2011 08:37 PM
Diesel Engine Programmers moosetags Tow Vehicles 34 05-23-2011 09:49 AM
