Old 02-24-2013, 12:51 PM   #43
SafariSS's Avatar
2005 30' Safari
Houston Texas , Texas
Vonzellen...
Can you snap a pic of the hitch mod?
SafariSS is offline   Reply With Quote
Old 02-24-2013, 03:17 PM   #44
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Originally Posted by vonzellen View Post
I may be under powered, but I'll see how it works in the flatter areas of the East Coast and if I find I need more power I'll consider another TV. (my ML350 actually has pretty similar hp and torque to my 99 ford f150 5.2liter gas)
If you can, have a look at Andy's piece in the latest Airstream Life regarding TV power. You won't be underpowered....
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 02-24-2013, 07:44 PM   #45
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Click on my three images below my forum name. One is a photo of the support piece welded to the factory hitch by CanAm.
They dropped the air suspension tank and then put standoffs to miss the new 2" steel brace when reinstalling the air tank.
I have a Hensley hitch straight stinger. They cut about 4" off the part that went into the MB receiver and re-drilled the retainer bolt hole in the steel shaft. It was a little too close to the back of the car to use the Hensley supplied wrench for the over center braces, but a quick trip to a nearby Harbor Freight and I purchased an inexpensive 21" crescent wrench that worked just fine.
They also put a few degree bend downwards in the middle of the stinger to pretension the Hensley weight distribution system.
Old 02-24-2013, 08:00 PM   #46
SafariSS's Avatar
2005 30' Safari
Hitch Beef up?
thanks Switz,
I have seen the hitch beef up done a couple of ways, i like the over the air tank/bluetec tank. I only question the crossmember everyone is going to, looks as if it would be better to go to a subframe mount or rear body mount?
Old 02-25-2013, 09:00 AM   #47
1967 17' Caravel
2007 27' Safari FB SE
Landenberg , Pennsylvania
2012 Mercedes ML350 Hitch reinforcement
I tried to upload photos??? they all came out upside down and would only let me load 4?
I sent my self an email and pasted the email. If you send me an email I can send them to you directly.
2012 Mercedes ML350 Hitch Reinforcements as done by CanAm, London, Ontario
vonzellen is offline   Reply With Quote
Old 03-23-2013, 10:42 PM   #48
1967 17' Caravel
Mercedes ML 350 Gasser Update
Ok, So I went to CanAm and got my hitch beefed up so that I could go to Florida and pick up the 2007 25FB CCD that I bought sight unseen. After two full days of driving and endless planning to get out of town we arrive in Dover, Florida and in minutes found the trailer had rotted floors!!!!!!! I had asked the sales person to check this several times and was assured it was "perfect".
So after a few drinks, and an evening contemplating not having a trailer at all I made a few phone calls then next day and found a 2007 27FB Safari SE. It was much nicer than the first trailer, had $12,000 worth of solar/controller/inverter/charger/4 lifeline AGMs/etc. and was almost $10,000 less than the 25 CCD with rotten floors. Needless to say we bought it.
I was confident that the ML would pull it fine because Andy had told me it would. It came with an Equalizer Hitch which hitched up just fine and before long we were rolling.
I never really pulled a trailer of this size any distance before so I was nervous, but after a 10 day trip up the east coast I can say the ML350 (gasser) had plenty of power and towed it like a dream. There was a litter "pressure" each time a large truck came up behind us, but nothing too bad. There seemed to be minimal or no sway.
I can see why some felt that the ML gas might be OK on the east coast where it is relatively flat and than if I get in hilly areas I may wish I had something more, but for now it tows just great.
The 27' trailer with the equalizer hitch, once installed, lowered the car about one inch equally front and rear. Steering and handling seem sure and responsive.
I think if you have a ML350 you have a great tow vehicle and you don't have to go for the diesel blue tec.
By the way, mileage without the trailer on the road was 22.3 mgp at an average of 60 mph. With the trailer I got 12mpg at an average of 50 mph.
I hope this helps some of you contemplating the ML.
Old 03-28-2013, 09:39 AM   #49
switz's Avatar
2014 31' Classic
Images: 8
In contrast to some the big pickup TVs, my 2007 ML320 CDI diesel continues to get 30% better mileage than the same displacement gasoline engine - 28.5 mpg on the highway at 75+. My UK 2002 straight 6 E320 turbo diesel station wagon gets 30% better mileage than the same displacement gasoline engine running 95 Octane and has quicker acceleration. When I towed the trailer home, I saw better than 14 mpg through the mountains on I-10 from Los Angeles to Phoenix.
The ML diesel engine has the torque of the V8 gasoline engine of that model year which was a sub 18 mpg engine choice.
The small european designed 3 liter diesel engines in the pipeline will continue to get better fuel economy and have substantially more torque than the comparable sized gas engines. Since these diesels are typically turbocharged, there is no performance degradation in the mountains at altitude.
Old 05-06-2014, 09:19 AM   #50
2014 27' Flying Cloud
Calgary , Alberta
2008 ML 320 CDI pulling 27 ft beautifully
For those who wonder, I am towing in the Canadian Rockies with steep grades and serious wind blasts. My 2008 ML CDI is simply amazing. My trailer is not an airstream, it is more square, therefore more wind resistance. i just wanted to help folks here. It just makes you wonder how is it possible to be that stable, let alone the ease of pulling uphill. Standard suspension, airmatic is nice but if it breaks it's too expensive. no thanks. The low rpm torque is just perfect, I am in 6-7th gear most of the time and. Fuel economy is also great for what it pulls, at an average of 14-16 mpg. 17 on the flats with little wind. I monitor the transmission temp with an iphone app and a wifi Obd plug in. All normal. The trailer weighs 5400lbs loaded with firewood, tools, generator, etc but no water onboard. That would be close to 6000lbs. Weight distribution is key, I am using a distributor with chains, it works great. I am at the gross vehicle weight limits when fueled up, my wife and 2 little kids. Tongue wight is also close but careful loading in the trailer helps a lot. The batteries on the trailer tongue are very heavy so I am planning to move them under the trailer right on the axels. Would I recommend it? Absolutely, it gives you a lot of confidence, I used to drive semis and I know what I am doing. Would it last mechanically? I sure hope so, we'll see on a long term. So far so good.
Fuscus is offline   Reply With Quote
Old 05-06-2014, 09:44 AM   #51
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Just returned from a 3 month, 3,000+ mile trip around the Southwest with my 2006 ML500 towing my '90 25' Excella with a Blue Ox SwayPro. Experienced all kinds of conditions: high winds, steep grades, semi's passing at 75mph while I was doing 60mph, one emergency stop. Everything went smoothly. Averaged 13mpg cruising at 55-65mph.
Andy said the ML was a great tow vehicle and he was right.
Poppy
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 05-11-2014, 12:36 PM   #52
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
I traded in a 2012 Sierra Denali HD on a 2014 ML350 Bluetec. Drove from Denver to CanAm for the hitch reinforcement. I have always pulled with the most powerful SUVs and Trucks available for the last 20 years. For the life of me I do not know why other than bigger is better I guess, but we, my wife in particular, just got tired of the poor ride, hard to drive, hard to park, low mileage, doesn't fit in the garage big TVs when we only actually tow a tiny fraction of the time we use the vehicle. The ML does an amazing job pulling my 2012 25FB and there is no comparison to the overall enjoyment of driving the ML the other 98% of the time. I would never go back to an oversized TV again, especially not to pull an Airstream.
2012FB is offline   Reply With Quote
Old 05-16-2014, 10:06 AM   #53
2007 23' International CCD
cary , North Carolina
A few questions for you:
What kind of mileage are you getting towing and not towing ?
How is the ML in the snow ?
Steve
steve.thomps is offline   Reply With Quote
Old 05-17-2014, 07:07 AM   #54
1967 17' Caravel
2012 ML 350 milage
I'm getting about 23mpg without towing and about 11.5 towing a 2007 27 FB Safari SE.
I have not towed in the snow, but driving in the snow is easy.
Old 05-20-2014, 03:47 PM   #55
2015 30' FB FC Bunk
Golden , Colorado
Steve
Current summer daily driving is around 23. Winter highway mileage was about 25, towing depending on wind was between 13 and 16 doing 5 over most of the time. I actually seemed to be getting better mileage just below 80. This is one of my complaints. I think if I could keep it in 6th for towing I would also get better mileage due to being a little more in the sweet spot on the torque curve.
Driving is very heavy snow was no issue, other than the standard headlights do a poor job in the snow. Really need dedicated fog/driving lamps.
Old 05-20-2014, 05:53 PM   #56
Gainesville , Florida
Some would say towing at 80 is a tad fast. Be safe and careful. Jim
2012 airstream interstate 3500 van mercedes benz diesel chassis save huge sale eBay Watch Airstreams on eBay 0 02-01-2012 04:30 PM
2012 Airstream Interstate 3500 Mercedes Benz Class B Diesel Motorhome 18+ MPG eBay Watch Airstreams on eBay 0 01-28-2012 11:20 AM
2012 Mercedes Benz Diesel Airstream Interstate Class B Motorhome Mobile Office eBay Watch Airstreams on eBay 0 01-28-2012 11:20 AM
2012 airstream interstate 3500 van mercedes benz diesel chassis save huge sale eBay Watch Airstreams on eBay 0 12-23-2011 03:50 PM
2012 Airstream Interstate 3500 Mercedes Benz Class B Diesel Motorhome 18+ MPG eBay Watch Airstreams on eBay 0 11-12-2011 12:30 PM
