11-27-2019, 03:50 PM
2015 25' International
2019 30' Classic
2021 23' Globetrotter
2021 Atlas
Flagstaff
2.5 vs 2 inch hitch
Just purchased a 2019 30’ classic and traded f150 for. 19 Ram 2500. My blue ox hitch is a 2” model, the receiver is a 2.5”. I can get a reducing sleeve but before I do is there any reason to switch the hitch to 2.5? The tongue wt of the classic is listed at 851 and the 2” blue ox is rated to 1500 lbs.
11-27-2019, 03:56 PM
2019 28' Flying Cloud
2014 22' FB Sport
Davie
, FL
Some people have complained that the reducing sleeve rattles, moves and wears out the pinhole.
BTW if you have a new RAM they provide a reducing sleeve. I found mine stored underneath the rear seat.
11-27-2019, 04:00 PM
2022 20' Basecamp
1968 17' Caravel
Los Osos
I use a 2.5 inch ball mount on my RAM 2500. I found that the 2 inch to 2.5 inch adapter had too much play especially with my RockTamers. I also use an anti-rattle hitch pin which pretty much eliminate all play.
Also, I've read that the adapter reduces towing capacity.
11-27-2019, 07:21 PM
2019 30' International
Pennsylvania
, Pennsylvania
Ford F250 here, however, I went with a 2.5 inch shank to eliminate the sleeve. The 2.5 inch shank in to that 2.5 inch hitch receiver is nothing short of heavy duty.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
11-27-2019, 09:35 PM
1995 25' Excella
xxxxx
, xxxxxx
I have a Ford with a 2.5". I use a 2" shank, a Ford brand reducer, and an anti-rattle clamp. Its rock solid.
11-28-2019, 07:18 AM
2019 30' Classic
Canfield
, Ohio
Everyone seems to have this problem. I went to a 2.5" shank to eliminate the adapter and still had some slop. This item solves the problem with or without the adapter and is very inexpensive.
One note: this may not work on some new Ram trucks. The chain hook holes interfere with putting this on. I will get a picture of this problem as my neighbor here drives one.
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
11-28-2019, 07:29 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
The 2" shank has a lower rating than the 2.5". When you drop down, you reduce accordingly. The "best" thing is to go spend $500 on a nice new 2.5" shank. Then you have crazy large capacity. You don't *need* that capacity, but you can have it ....
One fairly simple solution is to glue the reducer to the shank of the hitch you have now. Epoxy will do the trick. Line things up carefully while it still is wet. Make *very* sure it is dry before you put it back on the truck. If some dribbles into the hole for the retaining pin, it will drill out. That does not take care of the reducer vs truck slop. It does eliminate loosing the reducer if you pull the hitch regularly.
11-28-2019, 07:35 AM
2013 31' Classic
billings
, Montana
..if you go to 2.5” you will have less slop....using the 2” with adapter you have more slop...
11-28-2019, 07:53 AM
2000 25' Safari
Davidson County
, NC Highlands County, FL
Try the adapter. If you like it, use it. IMO, no reason to waste money.
When I had a Silverado 2500 I used the reducing adapter towing a 34'. I had no issues at all.
Alan
11-28-2019, 09:50 AM
2019 30' Classic
2021 Atlas
Flagstaff
2.5 vs 2”
Thanks for all the info and Happy Thanksgiving
11-28-2019, 11:16 AM
2019 25' Flying Cloud
Greeneville
, Tennessee
I agree with others, use the 2" adapter. My 30" has a 820# tongue weight and I use a 2" hitch.
11-28-2019, 12:23 PM
2019 30' Flying Cloud
Grass Lake
, Michigan
We use an extension adapter on our Ram 2500. It allows the tailgate to go down with trailer hitched up. The 2.5” shank that came with hitch was too short. Also use grade 8 bolts instead of hitch pins and no slop at all. Took some searching to get adapter with proper weight rating.
11-28-2019, 12:35 PM
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake
2.5 upgrade
When we traded our F-150 for the F-250 SuperDuty we elected to get the larger hitch shank. There is way to much slop as it is with a Ford Hitch did not want to play the reducer game each time I installed the hitch shank.
Happy Thanksgiving All-
11-28-2019, 12:47 PM
2022 20' Basecamp
1968 17' Caravel
Los Osos
I've used a variety of anti-rattle devices over the years. This anti-rattle hitch pin is hands down the best solution that I've tried. Works with both 2.5 and 2 inch ball mounts.
11-28-2019, 01:23 PM
2019 27' Globetrotter
McHenry
Went with Curt 2.5” drop shank for my Ram & BO
Hi 77domer,
I was in the same situation, moved up from 1500 to 2500 Ram and decided to get a Curt 2.5” drop shank. It’s nice and tight!
I just cut the last two holes off since I didn’t need it. The photo below is before I shortened it up.
Good luck and welcome to the forums and Airstream community!
Jeff
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
11-28-2019, 01:54 PM
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
Originally Posted by jeffmc306
Hi 77domer,
Jeff
Went with the 2 1/2” for the pro Pride hitch, great improvement.
11-28-2019, 02:42 PM
2006 28' International CCD
Saint Paul
if the receiver is loose/sloppy, wedge in several pennies till it's tight. When it loosens up again, and it will after a season or two, a few more pennies. It works and its cheap.
11-28-2019, 06:27 PM
Anna Maria
Have a welding shop allign and weld the sleeve in place. Problem solved.
And no using the sleeve doesn't reduce towing capacity.
11-29-2019, 07:43 AM
2020 25' Flying Cloud
Alexandria
This Winter I'm stick welding 4 pcs of 5/16" cold rolled around the 2", then taking into a shop to mill the unit to a tolerance fitting the 2-1/2" nicely.
11-29-2019, 09:46 AM
1976 31' Excella 500
Chappell Hill
My F350 has a 3” receiver. 2 adapters came with it. A 3” to 2-1/2” and a 2-1/2” to 2”. Double slop.
