Old 11-29-2019, 01:48 PM   #21
2019 25' Flying Cloud
Wilmington , North Carolina
My TV is also a 2019 Ram 2500 with a 2.5" Class V hitch receiver. When we picked up our 2019 25 Flying Cloud they initially set it up with a reduction sleeve on my TV and had the 2" hitch. I talked to the technician, and he agreed to change out the part of the stabilizing hitch with a class V 2.5" - after it was all said and done, he did state if it were his rig he would prefer no reduction sleeve, not because it doesn't work well, but it's just one less piece of gear you have to keep track of...
Good luck!
etojeo is offline   Reply With Quote
Old 11-29-2019, 06:34 PM   #22
2019 27' International
Western , North Carolina
And I’ve decided to keep the 2” with a sleeve for my F350 so I can plug it into the front 2” receiver just in case.
2019 International Serenity 27 FBQ “Serenity”
2019 Ford F-350 Platinum
JonDNC is offline   Reply With Quote
Old 11-29-2019, 09:05 PM   #23
Life is a Highway's Avatar
Lady Lake , Florida
Solid Shank
I’m looking for a antil ratle solution however this pin system is for a hollow shank not a solid correct?
Originally Posted by SilverWind View Post
I've used a variety of anti-rattle devices over the years. This anti-rattle hitch pin is hands down the best solution that I've tried. Works with both 2.5 and 2 inch ball mounts.
Life is a Highway is offline   Reply With Quote
Old 12-02-2019, 01:44 PM   #24
2016 30' International
Florence , Alabama
My issue with the BlueOx 2.5” is it didn’t have enough drop on it. The 2” model has a lot more drop available - not sure why.
joshjack is offline   Reply With Quote
Old 12-02-2019, 06:07 PM   #25
UncleBad's Avatar
2018 27' Tommy Bahama
Oro Valley , Arizona
2.5 vs 2 inch hitch
I have wondered that myself. The 2.5 and the drop works with my current 2012 F250, however I am at the last hole. I will deal with that problem if I ever upgrade my truck.
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
UncleBad is offline   Reply With Quote
Old 12-02-2019, 06:13 PM   #26
UncleBad's Avatar
2.5 vs 2 inch hitch
I went with the 2.5 because of the factory sticker on my hitch. It calls out the difference in capacities when using an adapter and when you are not using the adapter. I liked the bigger numbers “without adapter”....
Old 12-02-2019, 09:57 PM   #27
2017 30' International
Charlotte , North Carolina
I could feel the slop in the reducer when moving out from a stop.
Bought the 2.5 shank and all is nice and tight.
2500HD, Equalizer, and 30 ft International.
Al U. Minium is offline   Reply With Quote
Old Yesterday, 12:18 AM   #28
2016 30' Flying Cloud
Byron , California
For you Blue Ox owners, something to keep in mind when you need more drop because of a taller TV.
Most of the major brands of tow shanks are compatible with other brands.
I moved from a 2008 2500 Chev to a 2019 F250 couple weeks ago. I needed about 4 more inches of drop to tow my 30 FC level again. I didn't want to do the reducer sleeve thing for my 2 1/2 in receiver, so I came to the same solution as Jeff in post 15. The Curt 2.5 inch brand shank fits the Blue Ox hitch assembly perfectly and has plenty of adjustment. The only 2.5 inch shank BO makes is a 2 inch drop, which worked for my older Chevy, but no where near what I needed for the F250
As a side note, with the taller tailgate on the Ford, I had to turn the Husky jack 90 degrees to open tailgate while hitched with the BO/Curt assembly
obytheway is offline   Reply With Quote
15 inch tires v 16 inch tires CEG Tires 29 07-28-2018 05:50 AM
15 inch vs 16 inch wheels goliad1 Wheels, Hubs & Bearings 42 10-24-2017 11:55 PM
2014 Classic tire/rim change from 15 inch to 16 inch ratchet Tires 32 04-06-2017 08:14 AM
14 inch or not to 14 inch wheels.. jimshaner@ms 1961 - 1963 Bambi 0 08-25-2013 10:19 PM
16 inch wheel 7 inch width? Wiremanranch Wheels, Hubs & Bearings 2 03-24-2013 06:16 PM
