Old 02-01-2015, 11:53 AM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
'06 Expedition 4 pin to 6 pin connector
Well I did it again. I truly disliked my 03 Chevy Trailblazer, so I traded it on an 06 Expedition 5.4 V8.
This one has the brake controller connector under the dash-- thats good.
But it has a 4 pin at the back. I need a 6 pin to connect to my 66 Overlander.
I see the 4 wires connected to the current plug and what looks like an extra wire taped off.. Would that be the other wire I need to connect? Its the blue one in the photo.
Guessing I only use 5 wires on the 6 pin .. thanks all
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 02-01-2015, 01:13 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
This might help,
http://countrytrailer.com/uploads/6wayplug.pdf
MICHAEL
Old 02-01-2015, 03:12 PM   #3
1974 Argosy 20
Kooskia , Idaho
In general the blue wire is the one which goes to the brake controller and should appear under the dash so it can be connected to the brake controller itself.
The last wire you need is the + 12 volts for the charge from the towing vehicle to the Airstream. So you will use 6 of the 7 pins on the typical cord. Usually the center large round pin is unused.
Brake/signal left
Brake/signal right
running lights
electric brakes
+ 12 volts
- 12 volts (ground)
Old 02-02-2015, 05:20 AM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Here is the "trailer exterior lights" wire color and position from my 66 Trade Wind manual. I forgot my Trade Wind has back up lights, so I needed a seventh wire.
The information should help you convert your Expedition from 4 pin to "seven pin" trailer connector.
Maybe this diagram will assist with the pin locations in our Airstream pigtail. The wire colors Airstream used in 66 aren't the same as used in newer trailers.
David
Name:	1404 Exterior Lights Diagram.jpg
Old 02-02-2015, 06:12 AM   #5
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Hard to tell from the picture, but it looks like your arrow goes to an inline fuse, if this is the case my guess is that would be a wire from your alternator to charge your coach batteries.
Not a wiring expert but been through this more times than I care to think about.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 02-02-2015, 08:48 AM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
On our TVs we have found the 'modular' kit for plugging directly into OEM works very well. That way you don't have to wire/solder.. just remove existing and plug in the new..
Peace and Blessings..
Channing
WBCCI# 30676
Old 02-02-2015, 09:14 AM   #7
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
can you post a link to that modular kit? Please
AIR #005
retired!
Old 02-02-2015, 09:19 AM   #8
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I found the adaptor on etrailer...guess I will go with it
AIR #005
retired!
Old 02-02-2015, 10:17 AM   #9
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
You might also need to install a relay in the relay/fuse box, check and make sure it has the relay for trailer power. Your Expedition doesn't have the full towing package, so it's not included. We had to add this relay when I added the 6 pin to our Expedition.
Damon
#4827
damonbeals is offline   Reply With Quote
Old 02-02-2015, 10:55 AM   #10
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Since I don't carry a trailer battery I probably don't need that relay. Just lights and brakes for us.
AIR #005
retired!
Old 02-02-2015, 11:07 AM   #11
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
So you don't have a breakaway switch for your brakes? (That wouldn't necessarily require the charging relay, but it WOULD need a battery to work.)
— David
Old 02-02-2015, 04:33 PM   #12
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
No battery , no breakaway brakes, not good..
Old 02-03-2015, 10:27 AM   #13
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
no battery.
AIR #005
retired!
Old 02-03-2015, 10:34 AM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Alan.. Is the breakaway brake a State requirement?
Channing
WBCCI# 30676
9 to 7 Pin Connector Lufletch Electrical - Systems, Generators, Batteries & Solar 7 07-22-2014 07:36 AM
6-pin connector to AS 7-pin eugnicfrlie Towing, Tow Vehicles & Hitches 6 04-15-2009 10:29 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 07:09 PM
Toyota Tundra 7 pin connector Bonitafarms Lights - Interior & Exterior 13 02-09-2005 05:14 AM
nine pin connector driftwood Electrical - Systems, Generators, Batteries & Solar 2 09-24-2003 11:45 AM
