Old 02-19-2015, 10:05 PM   #1
2002 25' Classic
Kalama , Washington
'01 Dodge Cummins lift pump failures
Bought this truck new. Had a 54g TransferFlow fuel tank installed. Now has 155K miles. Have replaced the fuel lift pump three times. Dodge claims a redesign installed in the tank instead of on the engine block has cured what Cummins claims is an undersized tank to engine fuel line. My Dodge service center says the tank mounted pump can not be installed in my tank. TransferFlow tech dept sees no reason it can't.
Do any of you have any experience to share here? But for the lift pump concern, I'd prefer to keep our truck. Thanks in advance for any insights.
Brian
nwclassic is offline   Reply With Quote
Old 02-20-2015, 06:21 AM   #2
Gainesville , Florida
Try the turbo diesel forum.
Old 02-20-2015, 10:50 AM   #3
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Www.tdr1.com. Join as trial member, search or post question.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 02-20-2015, 11:08 AM   #4
Tuco's Avatar
1988 32' Excella
Ojai , California
Place the lift pump between the tank and engine. Our 5.9 had this arrangement when we bought it. It's easy to install there and allows easy access to an inline filter placed before the pump. There are several to chose from and as stated by other posters the TDR and Dodge Cummins Diesel forums can help. You also should consider a fuel pressure gauge to monitor pressures to the injector pump.
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 265k+ (The Beast)
Tuco is offline   Reply With Quote
Old 02-20-2015, 09:09 PM   #5
2002 25' Classic
Kalama , Washington
Good help, everyone. Many thanks.
Brian
Old 02-21-2015, 03:29 PM   #6
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
An old tried and proven remedy that has been used to cure sluggish and tired lift pumps on a great many Detroit and other diesel systems for decades is to install an inline 12 volt fuel pump between the tank and engine , powered through a relay that is activated when the system is turned on. It does not have to be higher pressure than supplied by a low cost electric in line fuel pump from just about any parts stores . All the ones I have personally installed were for gasoline , and they work just fine for diesel. I have one that's still in use after 30 years .
dannydimitt is offline   Reply With Quote
Old 02-21-2015, 04:55 PM   #7
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Our shop truck has had an issue with the lift pump, and Dodge has repositioned it on the frame rail, next to the tank. They say there is a TSB that outlines this procedure. According to Dodge, the original location was at the front edge of the cab, near the engine.
Old 02-21-2015, 08:41 PM   #8
2002 25' Classic
Kalama , Washington
Thanks Danny, Terry. Great material to share with local Dodge service dept. next week!
Brian
Air 'Bags' - too lift or not to lift JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 04-09-2013 10:09 AM
To Cummins or Not to Cummins?? Help!! On the brink! big_john Tow Vehicles 33 03-23-2010 08:20 PM
Dodge Cummins Brad Hunt Tow Vehicles 33 12-19-2007 07:57 AM
First impressions of my new Dodge/Cummins tow vehicle idahosafari Tow Vehicles 14 04-17-2004 08:31 AM
Will 2000 Dodge RAM 2500 with Cummins 5.9L tow A/S well? idahosafari Tow Vehicles 23 03-11-2004 02:34 PM
