Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2003 Safari
Old 07-06-2003, 10:13 PM   #1
ajjohnsons
Profile:
Smile New 2003 Safari 25C
Hi Folks, I wanted to introduce myself. Ive been reading as much as I can, and I would like to say Thanks for all the information so far. I just towed our new Trailer home last week. So here come the questions.... Would any of you Airstream owners, especially the Safari owners, add anything to a Standard issue Trailer. I'm considering a Black Tank rinsing System of some kind. I'm pretty sure the LS package offered a better Water pump. and I have just ordered a Spare Tire.. Ok now here comes the Big question, and please no fightin Boys. I have a 2002 E-250 V8, after towing the Trailer home without any wieght distribution or Sway Control, I think a Reese Dual Cam should be more than enough. I drove a Trailer Truck for a living awhile ago, I just don't have any experience with these kinds of Set-ups. Thanks in Advance..........
ajjohnsons is offline   Reply With Quote
Old 07-07-2003, 06:47 AM   #2
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
New 2003 Safari 25C
Greetings!
Welcome to the Forums!
I have a 2002 E-250 V8, after towing it home without any wieght distribution or Sway Control, I think a Reese Dual Cam should be more than enough.
I have used the Reese Dual Cam System since 1995 with a trailer very similar in size to yours - - a 1964 Overlander (26' and 6,000 pounds) with a 3/4-ton 7.4 Litre Suburban. I am thrilled with the system, and would NEVER consider going back to friction sway control The Reese Dual Cam System is virtually trouble-free once it is properly setup - - periodic checks on torque on attachment hardware is all that is required. Unlike the friction sway controls that I have used, it does not have to be adjusted for wet pavement, windy conditions, or heavy truck traffic - - and it doesn't have to be removed when backing or maneuvering in tight quarters. I have been so well pleased with the system that I added it to my '78 Argosy Minuet after Reese confirmed that it could be used with smaller trailer so long as the hitch weight is at least 400 pounds.
Good luck with your decision!
Kevin
Kevin D. Allen
AIR #827
Old 07-07-2003, 07:06 AM   #3
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Re: New 2003 Safari 25C
Originally posted by ajjohnsons
Would any of you Airstream owners, especially the Safari owners, add anything to a Standard issue Trailor. I'm considering a Black Tank rinsing System of some kind.
Well you caught the spare which I consider mandatory. I added an extra Fantastic Fan. Having two provides a lot more air flow plus the ability to run one in the area you aren't occupying so that cuts down the sound levels. Power jack is also a great option. Cuts down on the crankin.
I pull with a Reese Dual Cam sway control. The newer style, which I would recommend for you, has no U-bolts which on many Safari's has been an issue because of the bolts needing to be placed in the area of the gas bottles.
Here is the link for a picture of that hitch.
http://www.reesehitch.com/Strait_Lin..._trunnion.html
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 07-07-2003, 12:26 PM   #4
JaceBeck
Profile:
Ditto all of the above.
Regarding the balck tank rinse...if it is not installed from the factory it will be $$$$ to put in later due to the labor costs of removing the aluminum belly, etc. You may want to check out the Flush King - www.flushking.com - which does an acceptable job without dragging hoses into the trailer.
Congratulations on your new purchase.
1999 Safari 25C
2001 Yukon SLT
WBCCI #2369
JaceBeck is offline   Reply With Quote
Old 07-07-2003, 01:05 PM   #5
RoadKingMoe
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
Yeah, the black water flush goes up into the bathroom cabinetry to an air break, and then back down to a nozzle that's mounted in the side of the tank. Would be a LOT of labor to install after assembly. The Flush King looks like a much cheaper alternative.
Maurice
AB8XA
WBCCI 5446
The Long, LONG Trailer
Old 07-07-2003, 01:15 PM   #6
Dr. Harold Becker
Profile:
re: Black Tank Rinsing System
...and see also
http://www.sewersolution.com/index.htm
Dr. Harold Becker is offline   Reply With Quote
Old 07-08-2003, 08:53 PM   #7
ajjohnsons
Profile:
Thanks for all the responses. I'm real proud to finally own an Airstream, and real glad this Forum exists. Being new at this I'm not sure how much help I can be to anyone else, but you never know.................
2003 Safari 25 Melvin P. Thorpe 2003 Safari 24 09-15-2007 11:53 AM
Axle bearing numbers, 2003 Safari 25 freud Axles 10 11-23-2003 04:34 PM
Hmmm... 2003 Chevy 1/2 ton burban & 27' Safari docbluedevil Tow Vehicles 7 10-02-2003 09:11 AM
2004 International CCD 25C Lug Nut Airstream Trailer Forums 4 07-16-2003 08:24 AM
New 2003 Safari LS dpope 2001 Safari 18 03-07-2003 08:22 AM
test
