Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2000 - 2004 Safari
Old 04-19-2019, 11:14 AM   #1
2000 25' Safari
Denver , North Carolina
Removing innards of cam style baggage door locks
Hi, I have ordered my replacement cam style locks from Vintage Trailer. They should be here soon. In the meantime, I've removed the locks. I had to measure them to order the right size. My problem is how to remove the inside piece so I can replace it.
The key will not turn, that was my clue that I had a problem. I entered the locker from the inside by removing the panel that supports the twin beds and the nightstand/drawer. That opened it up for easy access to the space. I was able to then remove the Phillips-head screw and latch.
I removed the star ring that holds the shaft to the door panel so everything came apart nicely. But before I get my replacement, how do I remove the old one? I'll get pictures later today if that will help explain where I'm stuck.
mbubbaca is offline   Reply With Quote
Old 04-19-2019, 05:22 PM   #2
2000 25' Safari
Pictures as follow up.
Here are some pictures
ID:	338557   Click image for larger version
ID:	338559   Click image for larger version
Old 04-19-2019, 09:17 PM   #3
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
I just recently rebuilt my similar lock on a 2003 model. Place the pictured part with the key side down and use some penetrating oil around the cylinder. Let it soak for awhile. Then, use the key in the lock to try turning the cylinder until it moves. Use light pressure against the screw hole end (finger will do) and the cylinder will come free when the shoulder alines with the clearance slot. It is a long "L" channel on it's side. The friction/resistance to movement is corrosion between the barrel and outer side.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
lock repair, lock replacement, locks
'87 Excella: Long baggage door cylinders? MohawkDaddy Doors & Locks 3 08-03-2015 06:38 PM
Reset gates of Baggage Door key cylinder? Ethel1960 Doors & Locks 2 06-02-2015 05:39 PM
Baggage locks papajon Exterior Storage Compartments & Access Doors 1 11-23-2011 10:21 PM
1953 Baggage Door Lock pinktrailer Exterior Storage Compartments & Access Doors 15 10-22-2010 02:15 PM
up for grabs 64 sovereign innards jhohnke Stoves, Ovens & Microwaves 5 08-23-2009 03:20 PM
