Old 09-29-2019, 01:52 PM   #1
2000 25' Safari
Denver , North Carolina
I want to use wine corks as a backsplash
I need a place to put my extensive "collection" of used wine corks. I have seen them used as a bar back and backsplash in a stick home. Any advice on what to use on the interior of my 2000 Safari backsplash? I know hot glue will not work since hot glue comes loose in a house that doesn't move. I don't imagine it would stand up to the shake, rattle, and roll of the road. If stick on tiles work what kind of glue is it? Any experience among the learned herd?
mbubbaca is offline   Reply With Quote
Old 09-29-2019, 02:14 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Gorilla glue?
Old 09-29-2019, 02:29 PM   #3
Long Island , New York
What is the existing backsplash material? Are you planning on lying the corks down, or standing them up? Lying down will decrease the counter space quite a bit IMO.
I would put a dab of clear silicon on each one, I think . . . need to know the intended orientation/location etc. first though.
"learned herd" ? Not sure I herd you right!
Peter
PS -- Also the new backsplash may be difficult to keep clean, especially if splashes from the sink can hit it and get trapped in the voids. [IMO FWIW]
Old 09-29-2019, 02:42 PM   #4
2000 25' Safari
Peter
The wall is standard AS interior. The corks would be lying down probably cut in half, longways. I considered silicon and the above-mentioned gorilla glue but I was hoping to get some real-life experience. I also considered polyurethane and sealing them in...again an idea that has probably been done before. I've recently read that even some of the stick on tiles come off. I know the double-stick tape that the PO used to hold down the flooring is failing,
Old 09-29-2019, 02:58 PM   #5
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Google is your friend...
I just googled Wine Cork Backsplash DIY and there’s a ton of hits. One used 1/4” plywood as a backing - it would bend to conform to the Airstream wall so you glue the corks to the plywood. Makes it easy to remove in the future if you change your mind.
https://www.google.com/search?q=wine...&client=safari
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB (traded)
2019 Ram 2500 Laramie Blue Ox 1500#
WBCCI# 10258
2020 Retirement Plan
jeffmc306 is offline   Reply With Quote
Old 09-29-2019, 03:10 PM   #6
So is that brushed aluminum or maybe stainless steel? And is the location at the counter where the sink is?
The devil is in the details IMO. If the corks are all sitting on the counter, and the backsplash is metal, then silicon is the option I would pick. You only need a dab on the end of each one at the wall -- like the size of a grape, but don't push the cork hard against the wall -- let the silicon keep somewhat of a solid shape. Unlike the other adhesives, silicon will remain somewhat flexible, and therefor removable later [cork-by-cork] if needed IMO.
The recent suggestion to use a plywood backer is good too, but that will bring problems of its own.
Peter
PS -- Caution -- Some silicon can interact with aluminum and cause damage [acetic acid based ones]. Thus it is specifically not recommended for exterior caulking on Airstreams, unless you are very sure of what you are doing.
https://www.google.com/search?q=sili...=airforums.com
Old 09-29-2019, 03:56 PM   #7
Half a Rivet Short
Carlisle , Pennsylvania
Hi
I realize a backsplash is a very personal sort of thing. One point that would give me pause is cleaning the beast. The kitchen area is *very* compact. grease, soap, "stuff" will wind up on the backsplash. Cleaning it could be pretty exciting. Even with some sort of urethane on it, it still could be exciting.
Old 09-30-2019, 09:11 AM   #8
journeydog's Avatar
2018 28' Tommy Bahama
Silver City , New Mexico
Be sure to drink the wine first...could be a really fun project!
Class A Safari Trek 2830 - SOLD, TC Lance 1010 - SOLD,
TT Arctic Fox 30U - SOLD, TT Forest River Mini - SOLD
Class B+ Pleasure Way P
ursuit - FS, $$$$ - GONE
If it ain't broke I can break it
A dime still makes a pretty good screwdriver
journeydog is offline   Reply With Quote
Old 09-30-2019, 09:33 AM   #9
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Well pop my cork! sounds like a nifty idea - have fun and provide pictures of the project so we can all learn
La Dolce Vita Brick & Mona
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150 SuperCrew FX4 Lariart (MaxTow) "Red Dragon"
Married With Airstream Blog Click Here
drbrick is offline   Reply With Quote
Old 09-30-2019, 09:45 AM   #10
2015 25' FB Flying Cloud
Huntley , Illinois
Fyi. Used corks attract ants and other critters. Think of that when in storage. It may look great but it will be an attraction for insects and rodents.
cegardner is offline   Reply With Quote
Old 09-30-2019, 10:18 AM   #11
Watertown , Massachusetts
Resale value
I once made the mistake of mounting my collection of wooden spoons on the wall of my house kitchen. When we sold the house, I was required to remove all of the mounts. It was a lot of work and I had to repaint the wall. A backsplash is a pretty personal choice. I would required that the backsplash be removed to consider buying your Airstream.
And as someone mentioned, a backsplash like that is likely to hold a lot of dirt and kitchen splashes.
sallye is offline   Reply With Quote
Old 09-30-2019, 12:55 PM   #12
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
We have used a silicone-like product called “Goop” for all manner of adhesive projects, including re-attaching a piece of broken limestone on an outdoor pizza oven.
banderabob is offline   Reply With Quote
Old 09-30-2019, 02:12 PM   #13
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
Hi
It might look nifty but I’m with Bob. Seems like a poor choice for a surface you’d have to clean frequently.
daleyocum is offline   Reply With Quote
Old 09-30-2019, 02:34 PM   #14
1982 31' Excella
Hillsboro , Texas
Get a thin plexiglass glue to that. Then attach to wall with removable command strips. Then it can be removed when you need to clean it. Remove and take outside wash and drip dry, and remount to wall.
C Gin Go is offline   Reply With Quote
Old 09-30-2019, 03:27 PM   #15
Wolfwhistle
Wolfwhistle's Avatar
2013 23' International
HILLIARD , Florida
I would use aluminum flashing cut to size then VHB 3M tape it to the wall. Now has the curve, silicone the corks to the flashing. It could then be removed. I absolutely would not silicon directly to the wall. You cannot get it off by any method I know about.
2018 Ford F150
2013 International Signature 23FB
A married man should forget his mistakes. There's no use in two people remembering the same thing!
Wolfwhistle is offline   Reply With Quote
Old 09-30-2019, 05:09 PM   #16
CC
1972 27' Overlander
Heinsburg , AB
I think the idea is a great one. Add visual interest and texture to the backsplash area of your airstream. As a crafty person with a little experience with cork in crafting, I would definitely put the cork on a surface and then attach to the wall area. Wine corks can detach from smooth surfaces with the wrong adhesion product. If your cork area needs serious cleaning or you tire of the look, a detachable base piece will be an advantage. Would love to see how this turns out.
Good luck,
CC
Camper Crazy is offline   Reply With Quote
Old 10-10-2019, 06:15 AM   #17
Old dog new tricks
2017 19' Flying Cloud
Banner elk , North Carolina
Great idea wrong place??
I do not know the layout of your AS but would you consider a different locale for the wall mounted corks? I think you will find that the backsplash needs to be wiped down a lot for grease and general yuck. But the refrigerator door (easily replaced as a slide out panel) or one of the cabinet fronts would be a cool, textural addition and keep the collection growing (even be sound dampening if things get crazy &#129322. I have not glued directly to the interior (use double sided tape or command strips for all my art additions) so would tend to take same tack unless doing the refrigerator. Netting is available for mosaic projects, give it a try.
POST THE FINAL pics!
Flying Pig is offline   Reply With Quote
Old 10-10-2019, 08:42 AM   #18
2014 22' FB Sport
Atlanta , Georgia
Do not use gorilla glue
I keep seeing people on this site talking about using Gorilla Glue. Belbein's First Rule of Glues: ***NEVER EVER USE GORILLA GLUE FOR ANYTHING.*** It's not really that good a glue, it foams and expands when you apply it, and it's a bitz to clean up. And if you have to remove it--and whenever you apply glue, you're eventually going to have to remove it--it's impossible without a blow torch.
I'd suggest this, if you insist on wine corks. Coat the to-be-glued-side of the corks with something impermeable: anything from epoxy to white glue. When it dries and only when it dries, THEN glue the corks on to whatever the backing you're going to use.
Wine corks would look cool, I agree. But to attach them to the structure? [Shudder] I personally wouldn't. I have an irrational fear of attaching anything to any of the original surfaces, in part because I know whatever I like today I'm going to hate in 3 months.
I like the idea of making them a hanging or a piece of wall art. (In fact, if you have one of the ASs that's big enough to have a privacy curtain, I think they'd be an awesomely cool privacy curtain. I might even do that. [I wonder if screw tops would be as awesome?])
Belbein is offline   Reply With Quote
Old Yesterday, 06:36 AM   #19
Bluffton , South Carolina
Agree with the above comments
cool idea, not sure about permanent attachment.
I would suggest 1/4" bendable - flexible plywood as the backer. The grain in each ply is oriented in the same direction allowing it to bend. Typical plywood has the grain in each ply oriented in opposing direction, providing its strength.
Should be a fun project.
https://www.columbiaforestproducts.c...nding-plywood/
WillZoom is offline   Reply With Quote
Anyone use wine barrel flooring? Watkins2292 Repairing/Replacing Floor &/or Frame 1 09-14-2017 09:59 AM
For You Wine Lovers - A Neat Wine Glass to Compliment the Airstream Frank&Mike Airstream Lifestyle 24 01-03-2016 08:20 PM
Tile Backsplash? Roadrunner Cabinets, Counter Tops & Furnishings 13 09-05-2011 08:46 PM
Pretty backsplash gottatrotter Cabinets, Counter Tops & Furnishings 11 09-01-2011 09:40 AM
Kitchen counter backsplash ideas Safari Tim Cabinets, Counter Tops & Furnishings 13 06-08-2005 03:50 PM
