Join Airstream Forums Today
Old 06-20-2011, 12:25 AM   #1
ottawa , Ontario
2000 25' safari fresh water leak
I was filling my fresh water tank which normally fills until water comes shooting out the overflow. however this time, the water started flowing out from around the tank. I don't see any leaks inside the trailer. did the tank spring a leak? did I do something wrong filling it.
next question, if it is the tank, anyone have a pics of removing the FWT?
d.
dcsawLoehr is offline   Reply With Quote
Old 06-20-2011, 12:36 AM   #2
ROBERTSUNRUS's Avatar
Lakewood , California
Images: 18
Hi, you might have filled it too fast with a hose with too much pressure. Or maybe it froze with a full tank. I would open one of the lower cabinet doors, where the filler hose is and see if this hose or maybe the vent hose has come loose or came off of the connection.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 06-20-2011, 03:53 AM   #3
2010 27' FB Classic
Ft.Worth , Texas
x2 on what SUNRUS said, and also that water fill tube tends to crack due to age and can cause a leak.
I been the right place, but it must have been the wrong time
Old 06-20-2011, 06:15 AM   #4
"CLOUDSPLITTER" (tahawus)
ROBERT CROSS's Avatar
Hoover Beach , "Niagara Frontier" NY
Images: 53
Found pretty much the same thing on our Classic...when FW tank is full, constant drip until level falls below lower vent hose connection....hose leaking around the clamp.
I can see it but can't get to it without major interior tear down.
If the clamp had been a worm style instead of crimp I think I would be able to "git-r-done".....oh well SIL.
Now listen real hard and shut off when it starts to gargle, or wait till it spits and drain some out.
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 06-20-2011, 07:21 AM   #5
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
This is probably a silly suggestion, but you didn't leave the drain petcock open a bit by any chance, did you? I usually leave mine open over winter and sometimes upon first filling in the spring remember to close it only because of the water draining out under the trailer ...
AirsDream is offline   Reply With Quote
Old 06-23-2011, 06:32 AM   #6
ottawa , Ontario
thanks
My airstream is stored about 45 minutes away, I hope to go have a look at it this weekend. I'll post what I find for others. hopefully as simple as a leaking vent. and not actually a cracked tank....
Fresh water tanks leaks fixed! chiefneon Fresh Water Systems 1 07-31-2011 07:02 PM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
Fresh water sensor location - '06 Safari SailorSteve Fresh Water Systems 0 03-29-2011 01:13 PM
Fresh water leak Stearns Fresh Water Systems 8 03-24-2011 09:52 AM
