Old 11-18-2005, 09:57 AM   #1
volvophile's Avatar
colorado springs , Colorado
Images: 14
what is the bumper to hitch length
Hi yall,
I'm new to the forum to help me decide on wich one of these to buy, so I have a couple of stupid questions up my sleave
At the moment, I'm looking at a "75 Excella 500 31'
Is 31' the length of the vessel or the length of the whole Shananay from bumper to hitch?
It might sound like I'm picking nits, but I have a 34.5' driveway, so that extra toung length comes into play.
Also does anyone have links to a photo of the frame modificaions they did to keep the back end from drooping?
I'm trying to get an idea of what to look for when I do a visual inspection of this thing.
Dave.
volvophile is offline   Reply With Quote
Old 11-18-2005, 10:05 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Dave, welcome to the forums.
Trailer length is measured from tip of tongue to end of bumper, or overall length. A 31' coach will be 31' total, with about 28' being the trailer.
Old 11-18-2005, 10:06 AM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Originally Posted by volvophile
Hi yall,
Dave.
DAve,
Airstreams are measured from bumper to balll. Therefore the total length of the Excella is 31'. However, having said that the length is even feet and can be from just over 30' to just under 32'.
Bill
Just my personal opinion
wkerfoot is online now   Reply With Quote
Old 11-18-2005, 10:41 AM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
If it a rear bath you could have a problem. Mid bath not as much a problem. The frame modification is a reinforcing plate bolted to the web that hangs down between the wheels. I think yoou can still buy one from Airstream or make one yourself. The modification to the back is two bolts that install between the c channel on the bottom of the body and the frame. To due it the Airstream way you need to cut away the outside or inside of the body to get at the c channel and then drill thru c channel and frame and install bolts with a c-channel stress spreading washer like piece. This causes the body to take some of the load off the frame. The frame is holding up the rear mounted gray and black water tanks and they (when filled) are the major cause of overloading and bending the frame between the axles when the trailer goes over a signifigant bump or hole. Dynamic stress can be two to three times the static stress. A faster way is to drill thru the bottom frame or the rear acces door, c channel and frame member below it. Then install the stress spreading 4" by 1" "washer" in the bottom channel of the door and bolt thru it to the steel cross member below it. This usually overloads the door frame leading to distortion and other possible damage but it is a quick fix. I have also seem people install rods all the way from the back window frame all the way down inside the wall to the frame. There is a link somewhere on this forum to the tech service bulletin from Airstream.
Old 11-18-2005, 11:02 AM   #5
Remember Burma Shave!
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Fort Myers , SW.Florida
Images: 35
Rivet
Volvophile,
Try this link for a start on the separation:
http://www.airforums.com/forum...end+seperation
Then try an advanced search.
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 11-18-2005, 09:48 PM   #6
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Understand that Airstream over the years has not always stated the true length of a trailer in the model description. For example I have a 30' Classic Slide out. Actual length? The same as the 31' Classic. Just slightly shy of 31'.
Jack
Jack Canavera
STL Mo.
AIR #56
Hitch height Chuck Hitches, Couplers & Balls 20 04-09-2016 10:21 PM
Hensley Arrow Hitch Les Hitches, Couplers & Balls 116 12-14-2015 07:41 AM
Hitch problem wyhjr Hitches, Couplers & Balls 8 07-22-2002 05:29 PM
Hitch inspections 83Excella Hitches, Couplers & Balls 3 07-09-2002 03:05 PM
Handy hitch step Pahaska Our Community 0 06-26-2002 05:44 PM
