Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella 500 > 1975-1976 Excella 500
Old 07-14-2008, 07:39 PM   #1
1976 31' Excella 500
Rockford , Michigan
Excella 500 remodel
We just bought a 1976 airstream and gutted it out completely. I need to find out about replacing all of the interior panels. Web sites and materials would help. Thanks.
Brad Mich. is offline   Reply With Quote
Old 07-14-2008, 08:41 PM   #2
The beginning of each Airstream rebuild project, is to make the trailer waterproof.
From there you can repair/replace other things as your time and budget permit.
Start your search early, before you need some of the items. Sometimes, what may seem to be an easy part to obtain, may quite well be difficult.
You should also start with a "service manual."
If the trailer has been parked for a long time, it may also need axles.
The following article will teach you how to check them out in less than a minute.
Dura Torque Axle
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-15-2008, 08:03 AM   #3
Rockford , Michigan
I removed the inner metal skin and need to replace it after the electric is updated. I dont know what my options are or where to find it. Any web sites?
Old 07-15-2008, 11:55 AM   #4
Please be careful of how you block up the trailer before taking the interior metal off.
If not, then when you start putting it back in, you will quickly find that the rivet holes not longer match.
The interior and exterior shell are important for strength.
If you remove some of the panels, the frame will sag.
If you ignore that and rerivet the interior metal as you wish, then you will lock that sag in place.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-15-2008, 01:03 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
Like Andy mentioned the frame alignment may now be off. Before you go any further I would get a laser level and jack and block the trailer back to true front to rear using the floor as the reference point unless you intend to remove the floor and then you can use the top of the frame.
I assume you are going to remove all of the insulation. If so this will give you a Great chance to flood the outside and look for leaks. Most likely you will want the insulation out if you are wiring.
2004 Excursion 4x4
Old 08-25-2008, 09:10 AM   #6
Rockford , Michigan
Thanks Andy and Howie, Im back to the remodel now and have it up on blocks at 6 points. The floor is out and am looking at the water tanks at this point. Fresh water tank is in bad shape and needs replacing. Grey water is okay but very very small. Black tank in good shape also. Cant find Fresh water tank and am considering putting one in the front under the bench I will be building soon. Dont know what to do about the grey water tank as my wife says it is not nearly big enough. Any suggestions?
Old 08-25-2008, 10:02 AM   #7
We have the tanks.
BUT, a serial number and photo's are a must, since your not sure of the year, and rear bath, center bath.
Also several changes were made during mid year production, in both 75 and 76.
From that info, we can help you. Depending on the exact layout of your tanks, there are others that could possibly fit.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-26-2008, 09:46 AM   #8
Rockford , Michigan
Hi Andy, The trailer number is E31-A6J-3130 and it is a center bath. Dont have photo yet but the AS number for the tank is 600571. I was told they are not made any more. Can I mix the black and grey water to give a little more quantity? 1976 31ft. Excella 500.
Old 08-26-2008, 10:48 AM   #9
We have that water tank made and always have them in stock.
If you want to mix the black and gray water, be prepared to have the black water come up into the shower.
The idea of mixing the two, is not a bad idea, it's a horrible smelly idea.
Two tanks are a must, or a tank with two separate sections.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-29-2008, 12:28 PM   #10
Rockford , Michigan
OK Thanks to Andy I have a new tank being delivered. Now the next ? is what monitor do I use? The sea level models wont work with the thin AS tanks I have. (Less than 4 inches) 3 tanks and pump switch prefered, maybe LP and Battery.
Old 08-29-2008, 01:42 PM   #11
Your trailer already has a water tank monitor.
Your tank has the same fittings as the original.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-02-2008, 07:06 AM   #12
Rockford , Michigan
I dont have ANY gauges in my camper. The po stripped everything out. The new tank and the black water tank have sensors in the tank but I dont have any control panel.
Old 09-02-2008, 12:16 PM   #13
There are brand X gauges that will monitor the black, gray, and fresh water tanks.
The go for about a little more than $100.00
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-17-2008, 04:17 PM   #14
Albuquerque , New Mexico
Another 1976 31' Excella 500 Remodel
Looks like we're in the same boat, or land yacht as the case may be. I can't tell you how thankful I was to come across you're thread before I pulled the skins off the interior. Very helpful. Im curious what you're plans are for the remodel. There is a lot to think about. Just tore the interior out and getting ready to pull the floor to check out the tanks. Any advice?
JJ
jjsantafe is offline   Reply With Quote
Old 09-17-2008, 06:29 PM   #15
JJ
You do not need to pull the floor, to check the tanks.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-18-2008, 06:27 AM   #16
Rockford , Michigan
Hello JJ, You are right on alot to think about. I am starting from the ground up on my remodel. As you have read I completely gutted the whole interior of mine. We are not going to replace anything origanal. The interior skins have been removed and the floor was pulled out, at that time I checked the water tanks and found the fresh water tank in bad shape. Andy is correct that you do not have to take out the floor to check the tanks but if the floor is bad and needs to be replaced as mine did than it sure makes them easier to inspect.
My progress has been slowed dramaticly due the many hours at work for the next 4 to 6 weeks but I will get back at it after that. I have purchased many of the new parts for the remodel but have not had time to install most of them yet.
If you need any info feel free to e-mail any time. I do have a service manual if that helps at all.
Old 12-12-2010, 09:13 AM   #17
1975 31' Excella 500
Mulhouse , Alsace
Hi guys,
I'd like to get a Airstream Excella 500 75-76 service manual.
If you've got one, please send me it!
thank you!
monsterboo is offline   Reply With Quote
Old 12-12-2010, 09:48 AM   #18
Originally Posted by monsterboo View Post
Hi guys,
thank you!
Service manuals are available from Airstream, through a dealer, unless your at the factory.
However, they are specific to all the models, except the Excella 500.
The wiring, plumbing, etc, is the same for the 31 foot Airstream as it is for the Excella 500, for about 99 percent.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-14-2010, 03:40 AM   #19
Mulhouse , France
Hello Andy, i have an excella 500 from 1976, and i must remodel it in a luxury hotel suite.
i am really beginner in this job and i have lots of troubles. hope you can help me. for instance, i found the service manual, but i can not find how i can remove the vista windows. Should i remove all the external rivet to remove it? all the window have bubbles inside, like a plastic uv film which is dry and destroyed. Should i order new window to the airstream company? what about all those rivets? can i find these olympic rivets and the tool to place them? thanks a lot for your advice and please apologise my bad english! i am based in France, Alsace.
anthony vest is offline   Reply With Quote
Old 12-14-2010, 04:01 AM   #20
x
XXXX , XXXX
Anthony here is a link to repairing the vista view windows.
http://www.airforums.com/forums/f454...ta+view+repair
You could also order new windows from any Airstream dealer. I reccomend INLAND RV in California. They are specialists in vintage Airstreams.
Inland RV Center - The Nations Leading Expert in Airstream Innovations
Airstreams are built using solid or buck rivets. Olympic rivets are used to replace exterior rivets without needing access to the interior. They install like pop rivets and must be shaved after installation.
Here is a link to a company that supplies solid rivets,olympic rivets,rivet tools and many more parts and tools that you will need.
Vintage Trailer Supply - Vintage travel trailer parts and supplies!
wasagachris is offline   Reply With Quote
'71 Excella 500 71excella500 1971-1972 Excella 500 4 04-25-2012 11:24 PM
Excella 500 WetcoastBob Member Introductions 5 08-18-2011 12:09 PM
'77 Excella 500 RockStar Member Introductions 12 05-19-2008 09:49 AM
79 Excella 500 Darol Member Introductions 4 06-06-2007 08:56 AM
78 Excella 500 davidz71 Our Community 2 10-17-2002 01:11 PM
