Old 06-25-2015, 04:27 AM   #1
1972 Argosy 22
Shalimar , Florida
Access to leaky pipes
Brand new 72 argosy owner, have a slow drip coming out of the left rear part of the belly pan when hooked to city water. Figure the connections leak, but is there a way to access this plumbing withou removing the pan? Thanks Jim
Andersojd is offline   Reply With Quote
Old 06-25-2015, 08:40 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Welcome to the Forums!
I'm no expert on Argosys, but the 70's era trailers were all put to gether roughly on the same pattern so I will offer you some general advice.
Your fresh water inlet will lead into the frame, but will come up into the interior of the trailer under the cabinetry in the bathroom, almost immediately. So before worrying about dropping the bellypan, open up the bathroom cabinets, and look for a tangle of plumbing in the streetside rear corner. If you can't identify anything leaking there, then yes, the leak may be in that ~12" of line between the bumper trunk and where it enters goes through the floor. You might try removing the aluminum baffle in the bumper trunk that separates the trunk compartment from the interior of the trailer frame. Once that is done, you should be able to see the water line and identify where it is leaking. Of course, at this point you may still need to drop/cut the belly pan to do the repair.
Good luck!
Old 06-25-2015, 08:43 AM   #3
bellastream's Avatar
1969 31' Sovereign
Auburn , Washington
All the water plumbing is above the floor behind cabinets and things chances are you have a leak above the floor that is flowing around the edges of your floor and coming out under your trailer
bellastream is offline   Reply With Quote
Old 06-26-2015, 04:47 AM   #4
1972 Argosy 22
Shalimar , Florida
Thanks to you both will get on it today
leaky leaky leaky Zellia All Argosy Trailers 8 08-07-2015 05:25 AM
Busted pipes and access... KyMoonshine Plumbing - Systems & Fixtures 18 08-26-2012 08:41 AM
Exhaust pipes to exit left but where? Astrodokk Airstream Motorhome Forums 6 10-18-2003 08:21 AM
frozen pipes kooblekidz Airstream Motorhome Forums 4 01-20-2003 10:56 AM
Two PVC pipes? John Fresh Water Systems 11 12-06-2002 04:59 PM
