View Poll Results: Which chemicals do you prefer? Also, formaldehyde or non?
Liquid 13 37.14%
Dry 9 25.71%
Drop-in 8 22.86%
Formaldehyde 4 11.43%
Non-Formaldehyde 26 74.29%
Multiple Choice Poll. Voters: 35. You may not vote on this poll
Old 04-10-2006, 05:45 PM   #1
nazz300's Avatar
Decherd , Tennessee
I'm new to AS's and it can be confusing when it comes to putting chemicals in the black and grey water tanks. Do you prefer liquid or dry or the drop-ins for the toilet and/or grey tank? Do you put an odor eating chemical in as well or is there a good 2-in-1 product that you use? Do you use the same product in both tanks or is one better for the black tank and another for the grey tank?
And what about a formaldehyde or non-formaldehyde product. Which do you prefer?
Help, I'm so confused!
--Nazz
nazz300 is offline   Reply With Quote
Old 04-10-2006, 06:58 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I prefer the non-formeldehyde stuff. What I use in our tank is a product called "Odorles". It works in both the black and grey tank, and is basically an enzyme that helps break down the contents of the tank. You can ge it at most RV supply places. I like it because it does not contain the really bad harsh chemicals.
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 04-10-2006, 07:47 PM   #3
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Like Overlander63 I prefer the Odorless. I tried the Thetford and Camco? stuff sold at Walmart but found that I liked the Odorless best because it neutralized the smell in the tanks without masking it with other smells such as lemon.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 04-10-2006, 08:17 PM   #4
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
It's spelled Odorlos and even though it might be a bit more expensive, we get the 10 pack of 4 ounce packets which are easy to use.
I'll be honest that it isn't as effective fighting odor as the formaldehyde-based Thetford product, but the latter is not only environmentally-unfriendly even in municipal sewers, but can cause real problems for campgrounds that have their own septic systems.
Maurice
Old 04-10-2006, 08:41 PM   #5
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
The PO of my trailer was using potty tabs and they seem to work very well plus a lubricant for the valve.
A friend of mine who is a member of a SOB camping club says the club has used "BIZ" dry detergent for years. I have been using it for a year with no odorous effects. The box says it contains biodegradable anionic surfactants, enzymes, a color safe oxygen bleach, & brightening agents. (I'm sure we need the brightening agents )
At this point in my trial, it is working quite well.
wingfoot321 is offline   Reply With Quote
Old 04-10-2006, 08:49 PM   #6
WayWard Wind's Avatar
2004 25' Safari
then there is-----
Dave S. from A/S had an article, in the BB, some time ago about using liquid dish soap and water softner. We've been using it for some time and it appears to work quite well. We recently full timed for 5 months and had no problems . Seems it lubricates the valve as it works.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 04-10-2006, 10:10 PM   #7
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Isn't there a rumor?
Isn't there a rumor that Airstream owners think theirs doesn't stink?
Seriously I use ordinary septic tank digestive enzymes in the black tank.... it really is a small septic tank, why use hugely expensive stuff? The septic tank enzymes are dirt cheap (ohmygod another horrible pun) compared to the specialized RV stuff.
Using the tank flushers (oh these newfangled things that the vintagers distain!) when camping is really the most important thing, and eeeeeuuwh! you wouldn't believe how much more comes out after you think the tank is reasonably clean.
Paula Ford
Old 04-11-2006, 05:28 AM   #8
Well Preserved
1993 21' Sovereign
That's the stuff. I tried spelling it that way, but it just didn't look right.
Old 04-12-2006, 02:14 PM   #9
nazz300's Avatar
Decherd , Tennessee
Thanks for the input thus far. It looks like I'm leaning toward the Odorlos product.
--Nazz
Old 04-12-2006, 04:29 PM   #10
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
Odor-con
I recently switched to Odor-con... It simply has worked great at only 1 1/2 capfulls per use!!
http://www.3rodorcon.com/index.html
I'm sure others on the forums have good experience with this product too.
Kevin
Bambi_Bandit is offline   Reply With Quote
Old 04-12-2006, 04:57 PM   #11
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Rid-X liquid enzyme treatment for septic tanks. A little bottle treats a HUGE tank, so I just use a little splash of it. Seems to work fine.
Stephanie
Old 04-12-2006, 06:44 PM   #12
Over59's Avatar
Putnam , Connecticut
Images: 37
None. The marine electric head pumps to the black tank. There is no air connection between the head and the tank. I wonder how often foks check their vent stacks to make sure the end isn't to far into the tank...
Over59 is offline   Reply With Quote
Old 10-11-2006, 03:12 PM   #13
ScottW's Avatar
Hernando , Mississippi
I use two chemicals: Pine-Sol for the black tank, and Odoban for the grey tank. Pine-Sol (regular, not the lemon scent) is inexpensive, has no offensive smell and contains 15% pine oil which helps lubricate the valves. Odoban (at Sam's Club) kills 99.9% of the germs, has a pleasant smell and is compatible with all RV tanks. Both work fine for us, and we never (knock wood) have had any odor problems, even here in the deep south with the temps/humidity.
Scott
ScottW is offline   Reply With Quote
Old 10-12-2006, 03:48 PM   #14
Frank S
peoria , Illinois
Hi--We use liquid Tide. Works for us.--Frank S
Frank S is offline   Reply With Quote
Do you use holding tank chemicals? John Waste Systems, Tanks & Totes 15 10-14-2007 02:00 AM
Household chemicals Yes, yes or No, No? thecatsandi On The Road... 3 03-27-2006 07:01 PM
Toilet chemicals gwsullivan Waste Systems, Tanks & Totes 33 02-24-2005 12:28 PM
What Kind of Finish do you Prefer? JohnG Community Polls 10 09-11-2004 07:04 PM
Storage Advice? Mr. Bliss Our Community 8 04-18-2003 08:15 AM
