Old 06-23-2011, 10:06 PM   #1
1990 25' Excella
cave city , Kentucky
What kind of Television?
What kind of TV do I need to get? I mean will any TV do? Where to buy? I'd like a flat screen, but will it have to be heavy duty? Will the thing vibrate apart from the pounding of travel? I hope it stays in better shape then me. At my age, if I were a TV, I'd be a radio. By the way, there's never any thing worth watching on TV anyway is there?
unit13 is offline   Reply With Quote
Old 06-23-2011, 10:28 PM   #2
Ottawa , ON
Well, it could be as simple as,
  1. pick a convenient spot for the TV, where it can easily get power and signal
  2. Measure the largest TV that will fit in that spot (don't forget that TV screen sizes are still measured diagonally)
  3. Buy a TV, and one of the new mounts they will need
  4. Mount it, plug it in, fuss and fume about how there's nothing on!
Recommend to get one with a name brand you've heard of, buy it one of those credit cards that doubles your warrantee.
For off-air (not satellite), you'll need one of those forty-dollar boxes to make it work with your TV.
For satellite, you will need the patience of Job to set up the antenna, OR, be willing to fork over the big $$ to get one that seeks the satellites out automatically.
News and weather is what I like on them, plus DVDs I have made up of old movies recorded off-air.
ps: we just have a little 19" LCD bought for $169 2 years ago, that sits on the old swiveling wall bracket for a tube-style TV. When we travel, we put it to bed (in the bed, between the blankets), and never a problem...
Old 06-23-2011, 10:46 PM   #3
1990 36' Land Yacht
Dearborn Heights , Michigan
did canada go to a different digital Tv format than the U.S. ? used to be able to get chanel 9 (Windsor) but it disapeared can't pick it up with a digital or analog receiver. About the converter box, Tv sets sold in the US since about '05 are supposed to be digital and shouldn't need a converter for broadcast tv
"Silver Lining"
MrFixit is offline   Reply With Quote
Old 06-23-2011, 10:55 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
If you are going to buy a new TV, you should buy one that doesn't need one of the boxes. All but the very obscure (off brand) new TVs have an ATSC tuner that receives digital signals.
New in this case means something manufactured recently, not something that has been sitting around stores or warehouses for years but has never been sold. I've recently seen displays of old Cathode Ray Tube (CRT) TVs in WalMart or Fred's for very low prices. You couldn't pay me to haul one to the dump.
Only part of Aage's post I have any issue with. Lots of good advice in his post.
Personally, I would recommend a true 1080p HDTV. They're available as small as 22" now. 720p is cheaper but, contrary to what people selling 720p sets say, you really can see the difference even in the small screens. Maybe not if you sit a long way away, but with a small screen you're going to be sitting close. Just like computer monitors, sharper is better. The 22" monitor on my new computer at work is 1920 x 1080 resolution which is exactly the dimensions of 1080p. The 1080p TVs make great monitors too.
Vaughan
Old 06-23-2011, 10:56 PM   #5
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
This any good to you MrFixit?
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 06-23-2011, 10:56 PM   #6
MrUKToad's Avatar
Chatham , Ontario
Oops! forgot the link:
CBET-TV Channel 9 Windsor, ON - Michiguide.com Dials (TV)
Old 06-23-2011, 10:58 PM   #7
Chatham , Ontario
I'm not sure it answers your question, but here's some info on the change over to digital here in the Great White North:
Canadian over-the-air TV following U.S. down digital path - Canada - CBC News
Mrs. T is offline   Reply With Quote
Old 06-23-2011, 11:05 PM   #8
Ottawa , ON
Thanks for pointing that out, Vaughn, I was only going by what I had heard from my brother in Georgia.
We have yet to convert off-air to digital, but it's coming this fall, according to an ad the runs regularly here.
Old 06-23-2011, 11:19 PM   #9
1983 34' Excella
1967 24' Tradewind
Images: 32
You'll love it when you get used to it. The difference in image quality is huge. Lo-def TV is like going back to a 640 x 480 monitor on your computer.
Vaughan
Old 06-24-2011, 08:57 AM   #10
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Would recommend a LCD with LED backlighting.They are thinner, lighter, and put out less heat. We just bought a 24" Viore with built in DVD player to replace the stock 18" Toshiba. It runs on 12v or 120v.
Ahab is offline   Reply With Quote
Old 06-24-2011, 09:39 AM   #11
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
I'm with Ahab...LED is the way to go. Uses less juice and is much lighter. Anyone ever load up their DVR with recordings prior to departure and just use that as their entertainment container?
Phrunes is offline   Reply With Quote
Old 06-24-2011, 09:53 AM   #12
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
We bought a 22" LG LCD flat screen 3 years ago. It mounts onto swing out arms on the bedroom side of the bed room/galley devider. It can be viewed from the bedroom or the front of the coach. However, to minimize damage when traveling it very easily detaches and 'rides' under the bedspread and blanket on the bed. The tv also doubles as our home's bedroom tv.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 06-25-2011, 09:40 AM   #13
Ottawa , ON
As to LCD vs. Plasma, I would agree that an LCD makes more sense, since the single advantage of them is that they are better in daylight as far as "washout". Plasma needs a darker room for a satisfactory image.
In any event, I have yet to see a Plasma of less than 32", and I rarely see even that size in a TT, so it could be a moot point.
Old 06-25-2011, 10:15 AM   #14
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I've got an LG LCD that I carry with me. I've heard that extreme cold is not good for LCD's so I typically bring it in when I go into winter storage. I keep the TV in it's original shipping box when traveling (safely wedged between the bed and outer wall) and set it up on a cabinet above the fridge where the TV hookups are located. I'm not sure if the TV's that Airstream mounts are any more sturdy and temperature tolerant than mine is.
While I love digital TV, the real pain is finding the stations. Since our antennas are not omni directional, pointing the antenna in the wrong direction can obviously affect the number of channels available.
I notice that Wingard is now selling a sensing device that allows you to find TV signals without using the TV. Has anyone sprung for one of these yet???
SensarPro RFL-342 TV Signal Strength Meter
Jack
Jack Canavera
STL Mo.
AIR #56
What Kind of Folding Ladder to Buy? Jim Pona Our Community 10 07-20-2013 09:20 PM
1975 Excella 500 what kind of wood veener I have? Mypanhead Cabinets, Counter Tops & Furnishings 3 04-27-2011 09:38 PM
what kind of electric jack is this? Becky B. Jacks, Stabilizers, Lifting and Leveling 11 04-13-2011 05:06 PM
Picked up my Airstream today (Kind of) La.2Ak. Our Community 6 04-02-2011 07:51 PM
Airstream Public Television Story Corps Lothlorian Off Topic Forum 4 03-07-2011 08:31 PM
