I had McKesh at one time and ended up selling them after all kinds of trouble with the window glass hanging up on them and the window gaskets being deformed. Also, I am mostly alone and getting the right side mirror properly adjusted was always a hassle.
I went with slip-ons for a while; same right hand side problems, but less trouble than the McKesh. On a cost-performance basis, I would choose the slip-ons over the McKesh.
I bought the Schefenacker TTT mirrors for my present diesel and installed them myself. Hardest problem was getting the wire for the marker lights out of the door and through the accordian rubber tube. Entire installation took an afternoon. Heat, and adjustment is just like OEM.
They fit perfectly and I have many inquiries as to whether they are OEM and where I bought them. One thing I like is the flat right hand mirror that makes clearance judgement easier and the BIG convex mirror alongside to see traffic alongside.
This is one purchase I would make again in a flash.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Hi all, I returned from the Region 1 latest rally.One Problem with the M & M ,I almost had a accident with them on. I went for a ride in my truck to site see and I found they block my view when crossing a road against heavy Traffic.The solution is take them off and leave them in your trailer .for site seeing and use them , when towing with them.
CIPA has a mirror that looks just like the McKish. Part Number 11650. http://www.cipausa.com/
After using slip on mirrors on the Tundra, I finally switched to a pair of McKish. I like the McKish best. I take mine off when not towing. I had a close call one time while not towing the trailer.
Sam
__________________ Snorky II
Escondido, CA WBCCI #2055, VAC Charter Member FCU, WBCCI Unit #004 ESCAPEES SKP 58345 AIR #13642
08 Safari Sport 22, 03 Toyota Tundra
73 Argosy 22
We used a pair of McKesh mirrors for about six months and, during this period we towed our Airstream about 10,000 miles. I liked the McKesh and and they worked well. I always took them off when not towing and they usually held their position. When the right mirror did need adjustment, it was a pain, even with two people.
About a month ago, we were walking through the Camping World in Tallahassee when I saw the Tow N See mirrors on display. I decided to give them a try. I have now used these for about 2,000 miles. My McKesh mirrors are now for sale (PM me if you are interested). The Tow N See really work for me. They are super easy to install, remove, and store, The fact that they adjust with the inside electric control is really convenient. I have found my towing mirrors.
__________________ SuEllyn & Brian McCabe WBCCI #3628 --- AIR #14872 2005 25' Safari FB (Lucy) with HAHA 2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
What a coincidence to run into nazz300's thread. I HAVE nazz's McKesh mirrors now. He sold them on eBay when he bought a new TV with maxed out mirrors. Then I camped next to nazz at the Georgia rally, he recognized the mirrors and we found he was the eBayer I had bought from. It's a small world.
I can tell you, McKesh's are great even the second time around. Once I have the mirrors adjusted where I want, tighten them down and they stay put even between uses. Moosetags is right, they are a pain to adjust when necessary. Takes less than a minute for me to take them off or put them on. Never had any road vibration, they stay steady, no vehicle damage or window problems. I do take them off when not hitched, its just so easy.
I had originally thought about Tow-n-See, but based on what I had read at the time I went with McKesh and haven't been sorry. To anyone thinking about McKesh I would recommend getting the two convex mirrors with the package for maximum coverage.
...I had McKesh at one time and ended up selling them after all kinds of trouble with the window glass hanging up on them and the window gaskets being deformed. Also, I am mostly alone and getting the right side mirror properly adjusted was always a hassle.
I had the same problem and solved it by mounting a straight-action toggle clamp on them. It clamps up against the door trim and pulls the mirror frame away from the glass. Added benefit is that it was a firmer attachment with less vibration compared to the original.
__________________ John
If you need to turn on your air conditioner,you've gone too far south!
Regardless of which mirrors you are using consider the following tip if your AS permits. Danielle and I found a handy procedure that helps when we tow our AS - we open the front curtains and open the rear curtains. That allows us to see all the way through the trailer. Granted, this is not a substitute for mirrors, but it sure helps. In particular, when there's a small vehicle tailgating us I can see it through the rear view mirror but may miss it in the side view mirrors.
Lucius
Lucius and Danielle
AIR#25 WBCCI#16771
'92 - 29' Excella
'96 - GMC C2500 Suburban Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
Happy Holidays!!!! All the best to all of you!!!!!
Santa was nice to me and the TV, Kelly. Brought a pair of the Schefenecker mirrors... Of course we have had 15 inches of snow that has prevented the install.... but it will happen.... when???
They are the "Full Monte" version. Yes, they are pricy, in fact it took me about 12 months to go thru the other versions that are available - clip on, suction cup, etc....Chose the TTT's becuase they are going to look the most OEM, NO on/off, easy adjustability, and additional visibility with the running/ turn signals in LED.... Also, read every mirror thread there was on ASF, and there were several cogent comments from people that had actual experience with all the various mirrors, towing and not. Those were really important, since the sales hype ALWAYS advocates in the affirmative for their particular product. In the end I wanted a plug and play mirror that had all the advantages listed above, and NONE of the negatives.
Of course, that was a nearly $460 choice ( $491 w/tax) that some might not make. I've just run over too many of the slide on, suction, clip mirrors to count... I want my investment to appreciate, not vibrate off and get run over!
Pahaska, saw that one of your posts mentioned issues with the accordian tube. Could you elaborate?? I was thinking of taking the compressor and 'blowing' string thru the tube as a cable puller - would that work, in your opinion? I've seen that work in confined, convoluted runs.... Just thinking here... I am open to any suggestions.
Be safe out there!
Axel
That just might work. The instructions say to partially disconnect the accordian tube and I had a struggle, not only getting the wire through, but also getting the tube reattached.
I can't really give any advice since I can't remember what I did that finally made it work.
You will love the mirrors!
John W. Irwin
I've had them from day one on my tow vehicle. I'd get them again in a New York heartbeat. The only option I didn't get on mine was the in mirror blinking turn arrows... which would have added about another $70 to the cost. I must have gotten a great deal, because I paid about $400 including installation.
Being single, it's a pain in the neck to have to jump in and out six times to adjust the mirrors.
Another benefit that folks haven't mentioned is that you can adjust them for backing. Sometimes it's really good to look at the ground near your own bumper when you're trying to get your rig in straight or judge how close you are to the ball.
Several friends on my home campground who use removable mirrors have seen mine and asked about them. I pull out the mirrors, let them sit in the driver's seat and play with them....they are SOLD!
