08-14-2017, 09:03 AM
#21
Mantua
, Ohio
Uncommon?
08-14-2017, 09:09 AM
#22
1987 25' Sovereign
Fort Collins
It's not a matter of whether you can tow it -- it's how much weight you take off the front (steering) axle. I wouldn't recommend towing a trailer that large without WD.
Alumacoot
“We are confronted with insurmountable opportunities.”
08-14-2017, 10:05 AM
#23
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Originally Posted by avionstream
Uncommon?
Hi
I do have a tendency to latch onto a word ....
08-14-2017, 11:33 AM
#24
Tampa
When I hear "sway bar" I think of a link that prevents the axle from moving sideways on leaf springs. One side is attached to the frame and the other end to the axle. Very helpful in crosswinds.
But everyone veered into WD hitches, so I'm probably overthinking this.
08-14-2017, 12:26 PM
#25
Walnut Creek
Good thought - what you describe is a panhard rod and it has some other names. Basically it is as you describe, a link/strut that positions an axle so it does not move from side to side. Most prevalent on coil spring solid axle vehicles as the coils have little lateral resistance. Actually it does allow movement as the link is shorter or longer when the the axle goes up and down. Limited value on heavy stiff leaf springs. Not required on independent suspension designs.
AS nailed it in post 17.
Sway Bar should likely be referenced as a Sway Control Strut. It is a sliding assembly with a disk brake style pad and a screw assembly to push it against a friction surface. Look up "Sway Control " "Unit, Kit, or assembly" on Google.
Here is an example. http://sinisterdiesel.com/i-24087479...SABEgKJlvD_BwE
If that is not what the OP had in mind, we are both over thinking it, but I hope not. Pat
08-15-2017, 07:23 AM
#26
Rivet Polisher
1973 31' Sovereign
Mt Pleasant
, North Carolina
LOL! When I heard "sway bars"I was thinking about an new type of drinking establishment, like disco bars, sports bars, etc.
-Jim Pantas
1973 31 ft Sovereign
2009 Chevy Express 3500
08-15-2017, 07:33 AM
#27
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
I'll admit, *that's* an interpretation that did not occur to me
08-15-2017, 05:04 PM
#28
2007 22' International CCD
Corona
Any bar, given sufficient alcohol consumption, is potentially a "sway bar"......🤢
08-15-2017, 05:49 PM
#29
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
I've noticed that they generally become a "dang that floor came up and hit my face real fast" bar soon after that point.
08-16-2017, 06:56 AM
#30
Rivet Polisher
1973 31' Sovereign
Mt Pleasant
, North Carolina
Hi
I was at an establishment that had it's name painted on the ceiling, when I asked the bartender why he replied "So when you fall off the barstool you know where you are to call a cab!"
-Jim Pantas
08-16-2017, 07:40 AM
#31
1999 34' Excella
Hillsboro
http://auto.howstuffworks.com/auto-p...on-systems.htm
The above and subsequent pages they have links to, gives a basic overview/understanding of the dynamics/physics of what is happening when towing a trailer (the rig).. and the possibe importance of WD (weight distribution) in general.
From that rudimentary understanding, application in your setup may be better understood..
Peace and Blessings..
Channing
WBCCI# 30676
08-17-2017, 05:42 AM
#32
Rivet Polisher
1973 31' Sovereign
Mt Pleasant
, North Carolina
Good info, I was taught years ago that trailer towing problems are all about seafood:
Porpoising: Too much weight in the front of the trailer or back of the TV.
Fishtailing: Too much weight in the back of the trailer.
It's all about balance.
-Jim Pantas
08-17-2017, 08:32 AM
#33
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
One of the most difficult things to work out is: "Is it the road or my trailer?". Roads that feel ok with a modern suspension on a car may be crazy in a large truck or when towing a trailer. Sorting out what is road and what is weight / balance / hitch / setup related is a matter of experience. In some cases it's a matter of experience with *that* rig. I've found that the performance of my setup radically improves whenever I leave Pennsylvania
08-17-2017, 10:47 AM
#34
Walnut Creek
Bob - please add, is it the wind? and why is it different here than there? Pat
08-18-2017, 08:08 AM
#35
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Absolutely true. Unless you happen to be a sailor, watching the wind is not something you are used to doing. Wind driving in the hills is particularly tough to keep up with.
08-25-2017, 03:20 PM
#36
Serenity
2016 30' International
Lanesboro
Just a word of thanks to all of you who answered my question re "sway bars" (and all of the possible interpretations of those words). I got a WD hitch and what a difference; big improvement.
