Go Back   Airstream Forums > Airstream Community Forums > Our Community > Community Polls
View Poll Results: What is the biggest maintenance problem concerning your trailer skin
Rivet - Gone 4 4.82%
Rivet - Loose 3 3.61%
Skin Crack (metal fatigue) 3 3.61%
Skin - Rip 2 2.41%
Seam - leak 16 19.28%
Seam - Loose 2 2.41%
Skin - Wrinkle 8 9.64%
Skin - Dent 31 37.35%
Skin - Polish 25 30.12%
Loose Exterior Items (moldings, hatch doors...) 6 7.23%
Multiple Choice Poll. Voters: 83. You may not vote on this poll
Old 06-23-2004, 08:24 AM   #1
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
"Problems Poll" Cont.
In this poll we will try and clarify what was identified as the number one maintenance problem "Skin Rips/Cracks/Dents" in our previous poll.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 06-23-2004, 12:49 PM   #2
1964 26' Overlander
1977 25' Tradewind
I forgot to add two other items.
Corrosion and clear coat problems.
Any comments on these?
Peace
Gary
Old 06-23-2004, 01:48 PM   #3
maxandgeorgia's Avatar
1995 30' Limited
Ashland , Missouri
Aware that our AS had probably not had polishing for a long time and that having to store it outside meant that leaf debris and bird poop were sure to happen, I decided to tackle wash and polish to add some protection to the skin. After spending the past week and a half polishing our AS up close and personally, I am aware of our clear coat problems, but really have no idea of solution. I have read in past posts about peeling clear coat. I see no peeling, but it seems as though it has just worn away in high places (up above, between awnings and white roof gutter) and on end caps and along the street side panels between sofa windows and center bath area. Some areas look like ghostly trickles have run down the side; others polish up after tons of hand rubbing to shiny bare metal. I see no single problem, just an assortment of clear coat issues. Any suggestions are appreciated. I was using Blue Magic, a bushel of cut up sweatshirts and blankets for polish/rub cloths, and more elbow grease than I thought I had! A surprise, when I reached the rear, above the red WBCCI numbers, I found 4 white stars and a shadow of a fifth one. These had been obscured under the layer of grime and corrosion. What do you suppose this means for our trailer and its first owner? The AS is only a '95 and we are its 3rd owner.
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
1978 Argosy Minuet, 6.0~Minnie/GPZWGN
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 06-23-2004, 02:30 PM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Greetings Max and Georgia!
The stars associated with WBCCI membership denote that a previous owner had been a WBCCI member for 25 years or more as each star represents 5 years of membership. I will soon be able to display two stars as it won't be too long before I will have been a member for ten years.
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 06-23-2004, 02:36 PM   #5
dmreilly10000's Avatar
1953 25' Cruiser
Canton , Mississippi
Images: 14
I agree with Janet's Husband. My biggest problems are corrosion and clear coat problems.
dmreilly10000 is offline   Reply With Quote
Old 06-23-2004, 02:54 PM   #6
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
I fail to see how a dent is a maintenence problem. Dents result from objects striking the trailer, or you driving the trailer into something.
There is nothing to "maintain".
Clearcoat failure is a maintenence problem.
Leaks at seams, and vent & skylight entry points, windows, awning hardware attachment points is a maintenence problem as you repair it, then after time, you have to maintain it to keep it functioning properly.
just my 2 cents....
dscluchfc is offline   Reply With Quote
Old 06-23-2004, 03:08 PM   #7
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
Don't really consider it a problem....but we spend the most time maintaining the polish ~
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 06-23-2004, 03:21 PM   #8
71_safari's Avatar
West Linn , Oregon
Images: 12
clearcoat
Yes, definitely clearcoat problems - it seems all the older ones have it, at least on top, unless thay have become manually polished "Objet's d' Art".
I'm too lazy and cheap for that
john
Currently living in SE Asia
1971 Safari 23 (sold)
71_safari is offline   Reply With Quote
Old 06-23-2004, 03:31 PM   #9
mtpalms's Avatar
1971 23' Safari
Joshua Tree , California
I think we have almost all of the listed problems except skin rip and seam leak. Mos of them are minor, and are on the 'get to them when we get to them' list. Our biggest problem is that the PO(s) replaced missing rivets with screws (not always stainless either) and they are constantly falling out. Usually the trim pieces around wheel wells and access doors, so we re-rivet as they go. That goes hand in hand with loose seams and exterior items.
Last time we got home from a trip, a piece of the belly pan was also hanging loose (unzipped) on the curb side. And the AC shroud had come loose - I guess it's not surprising, considering the wind blew 50 mph all the way home from Bishop to Joshua Tree.
The most annoying PO problem we have is a mismatched SOB plexiglass shade over the back window. We can't remove it without leaving a couple dozen screw holes that hold it and its bracing in place. It doesn't look bad as it is, but it doesn't look right, either. If you know what I mean.
It needs a wash and polish, and we got the stuff, but we're just too busy right now to get to it. Hopefully when we get my father-in-law's house done, we will have time.
mtpalms is offline   Reply With Quote
Old 06-23-2004, 04:37 PM   #10
Retired.
. , At Large
Corrosion. I have it, not much, but enough to be a problem. At least I don't have to worry about clearcoat!
Old 06-23-2004, 06:59 PM   #11
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Silicone!!!!
Filiform corrosion under the clearcoat and freakin' silicone that some PO must have gotten the case load prices on! I have a 31' Sovereign. I swear there is over 300 linear feet of silicone bead on it! And so far the only way I have found to remove it is painfully slow. All the rest of the items can be handled. Of course I come from a sheet metal background so I have a head start on that.
Aaron
WBCCI #XXXX AIR #2495
Old 06-23-2004, 08:30 PM   #12
1995 30' Limited
Ashland , Missouri
What is "filiform corrosion under the clearcoat"? Is this what I called ghostly trickles that seem to be under the surface? What is it, causes it, what do you do for it? I noticed quite a lot developing, if this is what you mean. Thanks.
maxandgeorgia
WDCU
Old 06-24-2004, 03:03 AM   #13
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Filiform is a hard crust "pocket" about the size of a bb that forms up under the clear coat. Somone posted a picture in a thread a while back. It may have been in the one about polishing. It will also occur quite frequently where the panel seams are. Not sure of the causes of it, but it requires heavy polishing or even sanding to remove. When I get home I will try to remember to post a picture of it.
Aaron
Old 06-24-2004, 09:45 AM   #14
1964 26' Overlander
1977 25' Tradewind
Aluminum Oxidation
It looks like we have 4 hits for corrosion of the skin.
Does anyone have ideas on how to deal with aluminum oxidation.
I have seen oxidation killers solutions specifically for aluminum but I have not used any. Does anyone have experience with them? Brands, Types, Methods of aplication...
Peace
Gary
And you think you got a deal... BobbyW Our Community 21 06-05-2002 07:54 PM
