Go Back   Airstream Forums > Airstream Community Forums > Our Community > Community Polls
View Poll Results: your towing speed
55mph 148 14.34%
60mph 384 37.21%
65mph 365 35.37%
70mph 107 10.37%
75 mph or faster 28 2.71%
Voters: 1032. You may not vote on this poll
Old 06-04-2007, 09:51 PM   #113
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
Profile:  2006 30' Safari
Fayetteville , Georgia
Originally Posted by AgZep
Ok, let's try another angle. Assuming you've reached your cruising speed (and are thus no longer accelerating), the overwhelming majority of the gas you're burning is being used to overcome aerodynamic drag. Drag increases exponentially with speed. To go twice as fast, you have to overcome four times as much aerodynamic resistance.
On our last trip, we got about 12 mpg at 55 mph. That's with a 28' trailer and a 3/4 ton big block gasser pickup. Do any of you with similar rigs who tow at 75 mph have reliable mileage data to compare? I'm curious how big the difference might be.
1 MPG with Power Stroke Diesel. 5,000 miles towing.
Family of Disney Fanatics
WBCCI# 4821
streamin across america
Old 06-04-2007, 10:10 PM   #114
ljmiii's Avatar
Profile:  2006 16' International CCD
New York , New York
My results are somewhat skewed because if I'm going faster than 65 then I'm in a convoy getting a draft from the trucks ahead of me.
I get about 15 MPG going solo at 65 or drafting at 70-75. My best result ever was 19 MPG following my parent's MoHo at a more or less constant 60 MPH going downhill and downwind into New Jersey in 70 degree weather. My worst was 13 MPG going mostly solo uphill and upwind into Ohio on a cold February day.
Somewhat interestingly (to me at least) I recently tried using higher octane petrol and I've been getting about 2-3 MPG better fuel economy - 27.5ish instead of 25MPG - when I'm not towing. I'm curious to see what the difference will be with my Bambi.
ljmiii is offline   Reply With Quote
Old 06-04-2007, 11:04 PM   #115
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Does this make sense?
Hi, according to this discussion my 6,300 GVWR Safari with four wheels and tires, load range D, can go 65 MPH with only 30 lbs air pressure and if I add 10 lbs more air pressure, 40 lbs, I can go 75 MPH?
I divided the 6,300 lbs GVWR by 4 putting an average weight of 1,575 lbs per tire. The chart shows at 1,600 lbs per tire I only need to have 30 lbs of air pressure to drive at 65 MPH. And by some of your statements by adding another 10 lbs air pressure I can now go 75 MPH. Airstream manual says to run 65 lbs air pressure and that is exactly what I do. I like to travel on the freeways between 60 to 65 MPH and may momentarily hit 70 MPH for a very short time and distance. If the tire can actually handle 65 MPH with only 30 lbs air pressure, I have a great safety margin. But I wouldn't count on it.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 06-04-2007, 11:45 PM   #116
Profile:  2005 28' International CCD
Las Cruces , New Mexico
MM,
1 mpg? Or do you mean 1 mpg different than my figures?
There's no practical way to test precisely, but I'm really curious to see how speed relates to fuel consumption. I'm sure a diesel does better whether towing or not, but I wonder if there's a different sensitivity to speed between diesels and gassers.
I was just looking at a recent Trailer Life test of a Nissan Pathfinder towing an SOB about the same size as our Airstream. The Pathfinder got 8.8 while towing, much lower than we get with an 8.1 gas V8 and a drastically heavier rig. I suspect the Pathfinder engine was working really hard under the load.
AgZep is offline   Reply With Quote
Old 06-05-2007, 12:36 AM   #117
C Johnson's Avatar
Profile:  1965 17' Caravel
Portland , Oregon
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Originally Posted by 53FlyingCloud
If I am not mistaken, there's a published list of state law for "towed trailer" speed limit which, is determined by the weight of the towed trailer. (Among other listed requirements, like brakes) Most states allow speed in the 50 to 55 mph speed range, with a few states allowing the higher speed. I would think that it would be prudent for one to check the list for the states that you plan to drive in and, thru...
Drive with care.
While I haven't heard of a list like that, I will say that CA. has a towed trailer speedlimit. It is a general speed limit, if you are towing , it is 55mph. Oregon does too but it only applies to commercial vehicles. Most towed trailer speed limits apply to commercial vehicles only.
Chris AIR # 7276 WBCCI # 7276
WBCCI Forum Save Wally Forum
Photos of Project 2k5 My Pictures
C Johnson is offline   Reply With Quote
Old 06-05-2007, 04:50 AM   #118
Profile:  , Minnesota
Images: 59
Of fifty states, more than half allow trailer towing at 65 mph or more. Seven allow towing at 70 mph, and one allows 75 mph.
Old 06-05-2007, 07:18 AM   #119
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
At 68-70 mph I get (thru about the last 10,000 miles) 10.6-10.8 towing my 31'.
I do use cruise control about 2/3 of the time
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 06-05-2007, 07:26 AM   #120
Silver Mist
LI Pets's Avatar
You are reading it right, that is the safety margin you have!
Can you count on it? yes as much as anything else.
I wouldn't follow AS on this tire pressure issue, follow the tire makers, they do the R&D.
IN your case I would run 40lbs it may be too soft for sway. I would run 50-55. THe reason I would use 65 if I don't need to is a little more safety margin sure.
But when you pump up to 65 look at the surface area of the tire on the ground, now do that with 55 you'll see it has more contact with the road.
Also you will get worn out in the center of the tire along with cupping if overinflated.
WBCCI
Old 06-05-2007, 11:01 AM   #121
MM,
My F-250 has a trip computer that calculates fuel consumption. If I tow at 75 MPH on the interstate I get 11.6 MPG's. If I tow at 70 MPH, I get 12.2 MPG's. If I tow at 65 MPH, I get 12.4 MPG's. My truck shifts into its final gear at approximately 63 MPH so I don't tow under about 65 MPH on the interstate. My RPM's are the same at 75 MPH as they are at 55 MPH. I have calculated the mileage manually and come up with virtually the same mileage as the trip computer. I keep a close watch on my transmission and water temp gages when I'm towing in the mountains. When I tow on two lane roads and undivided four lane highways, I always tow at the posted speed limit no matter what that speed is.
BTW, the table referenced above is a little askew. In Georgia, the speed limit for trailers is as posted. The Max Tow Speed is 55, but that is for tractor trailers and I have never seen it enforced.
WBCCI# 4821
Old 06-11-2007, 05:34 PM   #122
Profile:  1976 29' Ambassador
Cornwall , Ontario
We are towing a 1990, 34' Airstream limited and our speed is 55 mph. Seen to many RV's and tow vehicles in pieces off the road because of high speeds and improper hitches/sway bars. My 3/4 ton diesel Ford, 6 speed standard just loves it. Please drive carefully. Happy travelling, Ken
Ken Scott is offline   Reply With Quote
Old 06-12-2007, 08:18 AM   #123
Welcome to the forums Ken. Glad you found us and hope to see many post from you in the future.
WBCCI# 4821
Old 01-27-2008, 02:06 AM   #124
Profile:  2006 23' Safari SE
Brea , California
I tow at 65 I get under 12 If I tow at 55 I get almost 15 mpg on gas and its just a more pleasent drive. 55 is the speed limit in CA. If I'm going to have a good time just crusin' it's the right speed. Empty (no tow) to Las Vages and back at high speed (70-75) I get 19.5.
Glenn G is offline   Reply With Quote
Old 01-27-2008, 04:06 AM   #125
Profile:  2005 16' International CCD
Ogden , Utah
I voted 60 - but it's really more like 62 or 63. My Dodge Cummins feels 'in the groove' towing at those speeds. It certainly could go faster, but things feel right.
Not towing, the groove is 68 mph.
RDM16CCD is offline   Reply With Quote
Old 01-27-2008, 11:21 PM   #126
Images: 18
25 Mph
Hi, I tow at 25 MPH, in school zones, when children are present.
2005 Safari 25-B
Poll: Make of your tow vehicle John Community Polls 74 09-22-2007 01:25 PM
What type of tow vehicle do you use? John Community Polls 24 08-07-2005 09:37 PM
More on tow ratings ipso_facto Tow Vehicles 19 11-16-2004 05:11 PM
Airstream / Intrepid JD1 Tow Vehicles 90 05-09-2003 11:49 PM
OK- what does your A/S weigh & what's your tow vehicle John Our Community 17 03-19-2003 11:38 AM
